AntiFreeze tester, propylene vs. ethylene difference - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 06-30-2009, 10:12 PM   #1
a_2000_se
a_2000_se's Avatar
Fan#: 62964
What I Drive: 2000 SE SOHC SPI, Compression @ 164
Points 4,699, Level 43
Points: 4,699, Level: 43 Points: 4,699, Level: 43 Points: 4,699, Level: 43
Level Up 75% Completed
Forum Activity 5%
FF Reputation: 15 a_2000_se Great Standing Member
I searched but did not find......
I just came to find that you can't use the same AntiFreeze tester for PROPYLENE glycol based antifreeze (Prestone) as ETHYLENE glycol based antifreeze (PEAK) even though they are both "Green". It has something to do with different specific gravity.
I came across this this past weekend when refilling my cooling system. Checker had Peak AntiFreeze on sale, two 50/50 mix gallons for $10. On the back of the container it said good to -34 F. After refilling my coolant system I check it and only had 3 balls floating with one sllooooowlllyy decending, Roughly -15 F or so but definitely not -34 F. I even stuck the tested in the container to make sure it wasn't being diluted by my system. Got the same 3 and a half balls floating.
So I looked it up and sure enough found that the two won't test the same with the standard testers. Anyone got a Refractometer.....
Anyone have a conversion for the Ball Values?
My testers balls values are: 20 5 -10 -25 -40 (be nice).
Does Heat affect the test value?
and finally: Can you mix Green with Green antifreeze, as I always though you could, even though they are PROPYLENE/ETHYLENE based?
Both companies are now offering products that are compatible with ANY antifreeze/ coolant regardless of color. But what about testers?
Member of the Dropped Valve Seat Club.
Replaced #4 Piston, Rings, Rod+Bearings, AERA Re-Manufactured Cylinder Head and a light Hone. Then CLEANED the hell out of everything.
60k+ miles.
a_2000_se is offline
Old 07-08-2009, 10:03 PM   #2
iminhell
C2H5OH
iminhell's Avatar
Fan#: 36222
Points 18,648, Level 86
Points: 18,648, Level: 86 Points: 18,648, Level: 86 Points: 18,648, Level: 86
Level Up 60% Completed
Forum Activity 19%
Buy-Sell-Trade Rating: (4)
Chances are you've been using Ethylene Glycol the whole time being it's the more common type.
Prestone Low-Tox is the only antifreeze they make that is Polypropylene Glycol. All the others are Ethylene.
I'd blame the tester on being old?
OH, you're not playing dumb ...
iminhell is offline
Old 07-08-2009, 10:22 PM   #3
whynotthinkwhynot
Captain TMI
whynotthinkwhynot's Avatar
Fan#: 18416
Points 27,736, Level 98
Level Up 39% Completed
Forum Activity 5%
Propylene anti-freeze is going to be much more expensive since that particular compound is used in many other applications. It's also commonly used in medicines, and it's similarity to ethylene glycol is what inspired a Chinese drug manufacturer to produce some medicines using cheaper ethylene glycol. This resulted in deaths of over 100 people in Peru before someone finally figured it out.
If you're worried about it, then open up the popcock, drain half a gallon or so of coolant, and add straight coolant- not mix- to replace it.
I love my neighborhood puppies, but I've never used non-toxic anti-freeze. Whenever I have to do a job on one of the vehicles that will result in spilled coolant, I make sure once I've spilled it that I use a hose to wash it away and keep the hose on until I can't see green anywhere.
Be eclectic.
You're special aren't you.
whynotthinkwhynot is offline
Old 07-12-2009, 11:14 PM   #4
a_2000_se
a_2000_se's Avatar
Fan#: 62964
Forum Activity 5%
Old - yeah it's at least 10 years old. It may be time for a new one but not too worried about it though because the tester is reading low - in my favor.
60k+ miles.
Old 07-19-2009, 06:24 PM   #5
a_2000_se
a_2000_se's Avatar
Fan#: 62964
Forum Activity 5%
So I buy another "BALL" antifreeze tester. A brand new still in the original package 'VICTOR' red bulb squeeze type with 5 colored balls, part number 00330-8. Victor is made by 'Bell Automotive Products Inc.'
It has the same temperature range for each ball as my old one. But the new one only had two 'two' balls floating for a 50/50 pre-mix of PEAK anti-freeze compared to my 10 plus year old one that 3 and a half balls floating. PEAK says their pre-mix is good to -34 degrees F. So either the testers aren't worth the $1.49 they sell for or PEAK is a little light on the glycol. I'm leaning toward 'cheap tester'.
It would be a little difficult for PEAK to be in bed with BELL in the hope to sell more antifreeze when they pre-mix their product and say it's good to -34.
-lol- enough of this topic.
60k+ miles.
Old 12-06-2012, 04:32 PM   #6
Fisher calassic
Fan#: 107034
What I Drive: 2011 white Savana
FF Reputation: 1 Fisher calassic Good Standing Member
I have been having the same problem and went back to the auto store to complain. There were good enough to open a 100% and a 50/50 and had the same results, the 50/50 tested -10 to-15 and the full strength tested -25. I took my mix THAT WAS MORE THAN 50%, because I kept adding anti freeze to try and get the mixture correct to my tester, to a mechanic friend of mine and He tested it with a ethylene glycol tester from snap on tools and it tested -60 degrees F. there does seem to be a big difference in the type of tester. I haven't confirmed yet what the anti freeze ( Ethylene or propylene) was that we tested with the store tester, but I will.
Fisher calassic is offline
