Sponsored by Tire Rack
Go Back   Focus Fanatics > Ford Focus Discussions > Wheels, Tires, Brakes & Suspension - Sponsored By Tire Rack
Wheels, Tires, Brakes & Suspension - Sponsored By Tire Rack The place to go for answers on wheel types, tire sizes, suspension issues and more.
Sponsored By:
Tire Rack
Thread Tools Search this Thread Display Modes
Old 06-24-2009, 10:52 PM   #1
SMITHBOY76908
МНЕ НАДО ПЕРЕРЫВ!!!
SMITHBOY76908's Avatar
Fan#: 56301
What I Drive: 2007 Turbo ZX3 & 1993 Mustang LX
FF Reputation: 18 SMITHBOY76908 Great Standing Member
How-To: FSwerks Front Lower Stress Bar Installation
I did a search for this when I bought the bar, and it didn't turn up a How-To so I figured I'd be the one to do it.
Part Installed: FSwerks Front Lower Stress Bar
On what: 2007 Ford Focus Stage 2 Turbo
Tools required:
  • 18mm and 22mm wrenches
  • 18mm socket
  • Breaker bar
  • BFH
  • Tools necessary to remove wheels (optional)
  • 1/2" Impact (optional)
  • 12pk Yeungling Bottles
Time: 30 minutes / 20 minutes with Impact
Effect: Much improved rigidity in the front. Less wheel hop and torque steer.
Since I am in the Army, I have the luxury of having a automotive skill center (do-it-yourself workshop) here on base. I understand that not everyone has that luxury and has to make do with what tools they have available, therefore I am listing the use of a 1/2" Impact as optional.
I would also like to apologize in advance for some of the pictures as they are not the best. I had a pretty bad glare on the camera.
1) I rented a lift and got the car off the ground.
These are the bolts that the bar bolts up to. For those of you running the FSwerks turbo kit, it may be beneficial to unbolt the charge pipe on the passenger side as it can get in the way of the passenger side bolt.
2) I took the front wheels off in order to get easier access to the control arm bolts. My lugs required a 12mm allen socket, but it's different for most. It is still possible to do this without removing the wheels, however, it is more difficult not having the freedom of movement and visibility.
3) I used the 18mm socket w/ the breaker bar on the bolt while using the closed end of a 22mm wrench to hold the nut in place on the back side of the control arm. I used the breaker bar to get the bolt loose and then used a 3/8" rachet to work it on out, because the charge pipe for the FSwerks turbo kit made it impossible to fit the impact in there. It may be easier for non-boosted setups. The control arm can fight back a little but it wasn't too bad.
4) Repeat the same process on the other side. I was able to use an impact on the driver side to remove the bolt.
5) Place the FSwerks front lower stress bar in place and run the bolts through on each end. You may have to wiggle the control arm a bit to make the bolt go through or use a hammer on the bolt (hence the BFH).
6) I used the 22mm wrench to hold the bolt in place again while using the impact or rachet to tighten the bolts back up. The bolts have to be torqued to 120ft-lbs.
7) Take a step back and marvel at your accomplishment. Then go take your fofo for a test drive and enjoy how stable the front end feels.
I noticed a difference after installing the stress bar. I found that the car is slightly more rigid and stable when taking sharp corners, however the biggest difference I found was in launching. The car sticks the ground much better, and the bar has almost eliminated the torque steer. The wheel hop, although still there, is considerably less, and I can shift first to second at 7k+ without torque steer or wheel hop. For the price, it's definitely a must have. I can't wait to take her out to the dragway and see how good the 60ft time will be. Thanks for reading.
2007 Focus ZX3 - FSW Stg 2, 13.52 @ 105mph
1993 Mustang LX - 5.0, cam, 3.73
Originally Posted by flattusmaximus78 View Post
Little 105mph focus doing work on blown mustangs lol. I loveee it.
SMITHBOY76908 is offline   Reply With Quote
Old 06-24-2009, 11:12 PM   #2
SMITHBOY76908
МНЕ НАДО ПЕРЕРЫВ!!!
Fan#: 56301
Here's also a couple other suspension mods I've done in the past week.
FSwerks Rear Stress Bar
Steeda Rear Sway Bar Kit
Old 06-24-2009, 11:26 PM   #3
roosterst
фанатик
roosterst's Avatar
Fan#: 61461
What I Drive: '05 CD silver ZX3 ST
FF Reputation: 73 roosterst Excellent Standing Member
Buy-Sell-Trade Rating: (13)
Very nice write up. I plan on doing this in the future, and this will really help.
Stock ATX w 91 tune = 16.643 @ 82.72mph
roosterst is offline   Reply With Quote
Old 06-25-2009, 12:03 AM   #4
kenzx3
Moderator
kenzx3's Avatar
Fan#: 42651
What I Drive: '03 Silver ZX3, '07 Gray SAP ZX3
FF Reputation: 120 kenzx3 Excellent Standing Memberkenzx3 Excellent Standing Member
Buy-Sell-Trade Rating: (42)
I will add it to the Official How-To Archive on here, nice write up Byrce
TRASH IN THE WATER 2010: When Foci Invade H2Oi - Ocean City, MD - September 24-26th
Presented by: FocusRising.com
FOCUS RISING 2010: The Summer's Best Focus Gathering - Carlisle, PA - June 4-6th
Sponsored by: FSWERKS, Ford Motor Company, Hendricks Design Studio, Golden Mile Performance
kenzx3 is offline   Reply With Quote
Old 06-25-2009, 12:54 AM   #5
05yellowd20
Fan#: 62464
What I Drive: 2005 Yellow ZX3 2.0 Duratec
FF Reputation: 15 05yellowd20 Great Standing Member
Buy-Sell-Trade Rating: (4)
VERY nice write up.
05yellowd20 is offline   Reply With Quote
Old 06-25-2009, 12:30 PM   #6
lightning2nd
love my red focus
lightning2nd's Avatar
Fan#: 54938
What I Drive: 2006 Red ZX4 SES w/SAP
FF Reputation: 3 lightning2nd Good Standing Member
good job man
Built on 1-18-06
06' Red ZX4 SES 2.0L Duratec
member of Focus Nation / Sedan Revolution#105 / Sap Crew#23 / Team Duratec#189 / Midwest Crew#31
lightning2nd is offline   Reply With Quote
Old 06-25-2009, 01:50 PM   #7
musclecarjohn
musclecarjohn's Avatar
Fan#: 47551
What I Drive: '07 ZX3,many,many musclecars
FF Reputation: 5 musclecarjohn Good Standing Member
Good job,I just did mine recently too...you should know if using NEW bolts,the Ford shop manual (I work for Ford) says torque to 159 ft lbs and this should only be done with the wheels LOADED and ON THE GROUND so you don't run the risk of tearing the rubber bushings.
I intially torqued mine with the wheels unsuspended to 89lbs (which I read on FSWerks site) then I loosened them while it was on the alignment rack here at work and re-torqued to 159 ft lbs,again...on new bolts.
'07 ZX3 Cloud 9 White SES 120A pkg...Team Duratec #02
'69 Camaro Z/28 Yellow/431 RWHP Aug '07 CHP cover car
'70 Camaro Z/28 Orange/Jan '08 CHP featured car
'70 Chevelle SS454 Red/ Jan '11 CHP featured car
musclecarjohn is offline   Reply With Quote
Old 06-25-2009, 02:03 PM   #8
SMITHBOY76908
МНЕ НАДО ПЕРЕРЫВ!!!
Fan#: 56301
120ft-lbs is what is recommended with the stress bar. You don't need to torque the bolts to 159ft-lbs since the stress bar is reducing the movement of the control arms, which was the main purpose of the high torque setting without it.
Thanks for the comments guys.
Old 06-25-2009, 02:21 PM   #9
Roland07
Roland07's Avatar
Fan#: 51147
What I Drive: 2007 Pitch Black ZX3
FF Reputation: 51 Roland07 Excellent Standing Member
Excellent write-up. I could have used this a couple weeks ago... haha. =)
It does make a nice difference, doesn't it? See if you can get someone to weld those Steeda brackets for you, or you'll be getting some clunks.
Goal: To have as much fun building the car as I do driving it.
Phase: Drivetrain
L.O.T.H. #9
Roland07 is offline   Reply With Quote
Old 06-25-2009, 07:54 PM   #10
Jeremy R
Jeremy R's Avatar
Fan#: 45931
What I Drive: 05 black ZX3 SES
FF Reputation: 6 Jeremy R Good Standing Member
Buy-Sell-Trade Rating: (7)
awesome write up, man!
Maple Grove Raceway (6/25/10) my best times:
RT: .057 60': 2.406 1/8: 10.322 1/4: 16.006 MPH: 86.62
Originally Posted by rgavi717 View Post
Friends say to me, " slow down, seriously, we are gonna die or the car will fall apart"
Jeremy R is offline   Reply With Quote
Old 06-25-2009, 08:33 PM   #11
SMITHBOY76908
МНЕ НАДО ПЕРЕРЫВ!!!
Fan#: 56301
Yeah, I probably should but honestly, it only clanks when I hit speedbumps too fast and such so I'm not really worried about it. Hearing it just reminds me its there.
Old 06-25-2009, 08:38 PM   #12
warneej
Where Da Gold At?
warneej's Avatar
Fan#: 20372
What I Drive: 04 ZX3 D23E, 03 Yellow EAP SVT
FF Reputation: 196 warneej Excellent Standing Memberwarneej Excellent Standing Member
Buy-Sell-Trade Rating: (9)
lower your damn car!
Buy yourself an SVT Piranha badge, all the cool kids are doing it.
Disciple of the "Push harder, suck less" school of autocross.
173.4whp
gump
crew #6
warneej is offline   Reply With Quote
Bookmarks
Search this Thread:
Advanced Search
Similar Threads
Halp! FSWerks lower front bar came with no instructions! Roland07 Wheels, Tires, Brakes & Suspension - Sponsored By Tire Rack 12 06-11-2009 10:59 AM
Timing Belt Info Spanky6935 Ford Focus Technical Chat 11 04-29-2009 09:26 AM
focussport front lower stress bar damryteirace Wheels, Tires, Brakes & Suspension - Sponsored By Tire Rack 8 08-05-2008 11:42 AM
Focussport lower front stress bar jetrinka Wheels, Tires, Brakes & Suspension - Sponsored By Tire Rack 5 06-10-2008 07:27 PM
fs... focus sport upper front stress bar thegreg Archive 20 01-05-2007 11:58 AM
Copyright 2002-2010 FocusFanatics.com. All Rights Reserved : Terms of Use : Privacy Policy : Advertise Information : Site Map
