Timing chain on the 2.3? - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 07-25-2004, 11:11 PM   #1
yodavader
Fan#: 4261
What I Drive: 2001 Civic
FF Reputation: 1 yodavader Good Standing Member
If I undestand correctly the 2.3 PZEV is equipped with a timing chain?
yodavader is offline
Old 07-25-2004, 11:20 PM   #2
eggyolk
Fan#: 1298
What I Drive: 03' ZX3 2.3
FF Reputation: 1 eggyolk Good Standing Member
yes
03' EggYolk Yellow ZX3 2.3 Duratec
Eibach Pro-Kit springs
FocusSport Cool-Flo Intake/FocusSport Exhaust
Draxas race header
eggyolk is offline
Old 07-27-2004, 12:19 AM   #3
sieben
sieben's Avatar
Fan#: 8152
What I Drive: 2004 Liquid Grey ZTS Sedan
FF Reputation: 1 sieben Good Standing Member
Re: Timing chain on the 2.3?
I would say the change is for the better, well as in reliability issues. I know from experience a busted timing belt can ruin an engine quick. I love my PZEV.
sieben is offline
Old 07-27-2004, 12:48 AM   #4
yodavader
Fan#: 4261
I agree completely! I did not intend to sound like I preferred a timing belt. They can be fairly expensive to replace. Having the timing chain eliminates one costly maintenance issue during the life of the car.
Old 07-27-2004, 12:59 AM   #5
03Z_ex_Three
03Z_ex_Three's Avatar
Fan#: 45
What I Drive: Liquid Grey 03 ZX3
FF Reputation: 1 03Z_ex_Three Good Standing Member
That is very true. The reason I don't like the belt is because if you ever do bust it, then you can have tons of problems, such as the piston hitting the valves.
The only time I dont like Bush is when Im at the "Y".
03Z_ex_Three is offline
Old 07-27-2004, 10:53 AM   #6
soffiler
Registered User
soffiler's Avatar
Fan#: 372
What I Drive: '03 ZX3 PZEV 5-spd Twilight Blue; '97 F-250 4x4 w/ 351 V8 & AT
FF Reputation: 1 soffiler Good Standing Member
Hold on, folks. There are two kinds of engines with timing belts: intereference, and non-intereference. If you happen to be talking about an intereference engine, then you WILL have tons of problems, specifically the pistons hitting the valves. There is no maybe about it. Then again, if it is a non-intereference engine, the pistons and valves cannot hit each other. As it turns out, the Zetec is non-intereference, so the only real worry is getting stranded on the side of the road if a timing belt breaks. The only time there might be serious trouble with a Zetec is if you have made any changes to increase compression ratio, or if you are using a higher-lift cam. Now, the Duratec is a different story. It is an intereference engine. We are thankful to have the greater reliability of the timing chain.
soffiler is offline
Old 07-27-2004, 03:16 PM   #7
aero_student
Fan#: 1979
What I Drive: '03 Focus ZX3 PZEV
FF Reputation: 1 aero_student Good Standing Member
The duratec is an interference engine.
MarcyMotorsport:CAI, balanced 11.6:1 motor with ranger crank, cosworth flywheel, tumble flap delete, supertec valve springs, crane cams, clutch master stg I clutch, protoype MarcyMotorsport 2.5" exhaust, FC throttlebody, Quaife, svt bumpers and brakes, full energy bushings, etc.
aero_student is offline
Old 07-27-2004, 05:15 PM   #8
Lil PZEV
Lil PZEV's Avatar
Fan#: 242
What I Drive: 2003 TwiBlue 2.3 ZX3
FF Reputation: 15 Lil PZEV Great Standing Member
Buy-Sell-Trade Rating: (14)
He knew that, mentioned it right near the last sentence. So basically ours is a metal chain as opposed to the more "wearable" rubber belt like the serpentine or something? Sounds like a good deal... where is this in our engine by the way?
Lil PZEV is offline
Old 07-27-2004, 05:53 PM   #9
aero_student
Fan#: 1979
under the valve cover
Old 07-28-2004, 01:24 PM   #10
soffiler
Registered User
soffiler's Avatar
Fan#: 372
Well, the cams are under the valve cover, so sure, a portion of the timing chain must be there too. It's not the majority of the chain. The whole rest of it lives under the "front cover" of the engine, since the timing chain is driven by a sprocket on the crankshaft internally, just before the cranksaft emerges from the front of the engine to drive the accessory drive pulley.
soffiler is offline
Similar Threads
SPI Timing Belt Change How to untenops SPI Performance (2000-2004) 41 12-05-2013 08:25 PM
Timing Belt Info Spanky6935 General Technical Chat 13 09-30-2011 11:54 PM
Just got a CEL for codes P1381 and P1383 Sir Not Appearing General Technical Chat 2 12-07-2009 08:21 AM
HOW TO: Install Crane Cams and Springs/Retainers honhon DURATEC Performance (2003-2007) 215 10-06-2008 10:09 AM
2007 Focus ST 2.3L Duratec - Timing Chain or Timing Belt? metroplex DURATEC Performance (2003-2007) 5 10-04-2006 10:09 AM
