clunk/pop noise in front suspension - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 06-20-2009, 08:04 PM   #1
redmenaceII
redmenaceII's Avatar
Fan#: 57875
What I Drive: 2005 Bright Red ZX5
FF Reputation: 1 redmenaceII Good Standing Member
Cool clunk/pop noise in front suspension
In the past few weeks I have replaced the sway bar end link kits, the passenger side motor mount(had to change the idler pulley, found a bad mount) the lower torque mount and the trans. mount. Yesterday I started driving my 50 mile commute, when I started hearing this clunking noise anytime the car would hit a bump, or an uneven road surface in the highway. Took the car straight to the shop, and we first determined that it was the LH strut and strut mount. Purchased one new Monroe Sensa Trac strut and strut mount, and it seemed that it had taken care of the problem. This morning the noise returned after going over some bumps on the way to work. It happens at low speeds and at highway speeds some times. Anybody has an idea what else could be wrong? Thanks in advance!!!
05' Red ZX5 now with 5% tint all around, more mods to come!
Last Of The Hatches#75, yeah!!!! Team Duratec#913!!!!!!
redmenaceII is offline
Old 06-20-2009, 08:11 PM   #2
Obocecha
Obocecha's Avatar
Fan#: 28484
What I Drive: 2002 Yellow ZX3
Points 1,641, Level 23
Points: 1,641, Level: 23 Points: 1,641, Level: 23 Points: 1,641, Level: 23
Level Up 41% Completed
Level up: 41% Level up: 41% Level up: 41%
FF Reputation: 15 Obocecha Great Standing Member
Buy-Sell-Trade Rating: (9)
I was going to say the sway bar end links but I see you've already replaced them. The only other thing that I can think of that clunks while driving would be a worn out ball joint. Check for play by using a pry bar in between the control arm and hub.
'02 Yellow ZX3
'85 Supra 6M-GTE
Obocecha is offline
Old 06-20-2009, 08:25 PM   #3
redmenaceII
Fan#: 57875
I forgot to mention, she has 81K miles, the last 25K have been driven mostly in the highway. I don't know if the mileage has to do with the wear of the ball joints.
Old 06-21-2009, 09:53 AM   #4
racer1735
racer1735's Avatar
Fan#: 13782
What I Drive: 2004 Sonic Blue SVT
FF Reputation: 5 racer1735 Good Standing Member
I've read that the strut bearings are a source of 'clunking', as well. I have 102k miles and am about to find out....replacing struts and mount/bearings in the next couple of weeks.
As a rule of thumb, if your steering is still 'tight', the ball joints are probably still good.
When you've run out of mods, it's time to get something new.
racer1735 is offline
Old 06-21-2009, 11:06 AM   #5
bosengel
bosengel's Avatar
Fan#: 41513
What I Drive: 2000 ZX3 Kona / 1999 Toyota Corolla
FF Reputation: 8 bosengel Good Standing Member
My driver's side front bearing has gone out and it is definately a clucking/popping sound. Esp. when turning and going over a rough road.
Joel - Webmaster
Focal Distortion - A Ford Sport Compact Community in Las Vegas
2000 Amazon Green ZX3 Kona
bosengel is offline
Old 06-21-2009, 12:04 PM   #6
Obocecha
Obocecha's Avatar
Fan#: 28484
I would say the tie rod ends would have a much larger effect on steering than the ball joint would. My steering still felt like new but was clunking like crazy because of a severely worn ball joint.
'02 Yellow ZX3
'85 Supra 6M-GTE
Obocecha is offline
Old 06-24-2009, 12:08 PM   #7
redmenaceII
Fan#: 57875
Thanks for the help guys. I took the car to a different mechanic, actually a suspension and alignment shop that I had dealt in the past before, and he(new mechanic) was able to find the problem: A loose sway bar link kit!!!!!!!!!! Once they rolled the car to the ramp, he heard the noise. He checked ball joints for play and steering and immediately saw the loose link kit. A new lock nut and 15 dollars later I was on the road again!!!
Old 01-31-2013, 10:17 AM   #8
Celtictexan
Fan#: 99816
What I Drive: 2010
FF Reputation: 1 Celtictexan Good Standing Member
Im just under 36k on my 2010 and have clunking popping noise in both my rear and front. Im pretty sure its all suspension noise. I'm taking it in soon so I'll report what happens.
Celtictexan is offline
Similar Threads
Popping noise in the front end myfirstfocus General Technical Chat 27 11-10-2011 05:21 PM
The Ford Focus - General History and Information S2 Ford Focus & General Car Chat 1 11-14-2008 03:04 PM
2002 Ford Focus SE: noise from the front passenger-side wheel area Options jsimon General Technical Chat 3 10-26-2008 10:34 AM
front suspension sounds UGLY!!! dwdgsi03 Brakes, Suspension & Body Chassis 3 06-02-2004 10:32 AM
