write up for AEM wideband for datalogging - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 06-17-2009, 09:57 PM   #1
gottaride28
gottaride28's Avatar
Fan#: 21892
What I Drive: 2005, Grey/orange, ZX3 ses
Points 3,822, Level 39
Points: 3,822, Level: 39 Points: 3,822, Level: 39 Points: 3,822, Level: 39
Level Up 15% Completed
FF Reputation: 1 gottaride28 Good Standing Member
Buy-Sell-Trade Rating: (6)
I know few people were having issues with the AEM as well myself. I got mine to work today so i took a few notes for people.
Your gonna need a mini 9 din cable you can purchase off the focus sport website. Your cable will probably come in a package that looks like this
its kinda hard to read but you can make out the image ill type the rest for you. On the picture it gives you the wires that the cable is TYPICALLY (from top to bottom) Analog 2 is typically black wire, Analog 1 is typically blue, and Ground is typically red wire.
Even if you contact sct about this they will give you the same information.
ok with my findings the wires have changed. here some illistrations of what i found using a mulit meter. I would strongly suggest doing the same for anyone that may buy a cable.
Above shows all the same pins as the last one but the color of the wires have changed so this means (top to bottom)
Analog 2 was grey
Analog 1 was green
ground was brown
(remember this is what i found in my cable this is probably why everything says "typically")
The rest of the pins read like so (bellow illistration)
once you have figured out the wire colors that match up to the pins we need, (three pins shown on first two pictures) splice into them attaching your own wires that will be able to directly hook up to your AEM gauge wires.
white wire on the AEM gauge is the volt wire. You want to attach your analog 1 wire from your din nine to this wire. (again with a multi meter you can check your AEM gauge to make sure its reading anywhere between 0-5 volts when the car is running)
Next take the ground wire from your din nine cable and ground it somewhere on the car.
Your analog 2 wire will not be used.
Next this was the only other problem that i incountered was that the cable was not pluging into my xcal2 all the way. to fix this, i just trimed the plugs rubber srounding a little as so...
im not sure if it was just me but the pins had a hard time keeping a connection if i didnt modify this. (check it out before doing this it may not be totally nesscary)
Dont plug it in just yet plug in your xcal2 to your car link it up to the computer fire up livelink and follow all the same things you usually would but when your marking which configurations you need make sure you mark analog1 with it.
So now your graph page pops up NOW plug your din nine cable into your xcal2
select all your configurations when you check mark analog1, right click it next and there will be two options for you to select. Select configurations i believe its called click that one and a second box will pop up for you to enter your formula
enter the formula just as:
v*2+10
press ok
now in one of your gauges right click, go to signal and press analog 1 so you can watch the gauge once you start up the car to see if your actuall AEM gauge matches the gauge on the computer.
and there you go thats how i got my AEM gauge to datalog
really hopes this helps anyone out there that was having troubles.
-Zack-
Team Octane
Focus Revolution
gottaride28 is offline
Old 06-17-2009, 10:37 PM   #2
hardSVT
Turbo Freak
hardSVT's Avatar
Fan#: 53566
What I Drive: 03 svtf
Points 13,954, Level 76
Points: 13,954, Level: 76 Points: 13,954, Level: 76 Points: 13,954, Level: 76
Level Up 76% Completed
Level up: 76% Level up: 76% Level up: 76%
FF Reputation: 5 hardSVT Good Standing Member
Buy-Sell-Trade Rating: (7)
i love u!
thanks!
RIP SVT
300hp mazdaspeed3
Rocco's built turbo zetec mine now!
hardSVT is offline
Old 06-18-2009, 12:45 AM   #3
SMITHBOY76908
SMITHBOY76908's Avatar
Fan#: 56301
What I Drive: 2007 Turbo ZX3
Points 14,482, Level 78
Points: 14,482, Level: 78 Points: 14,482, Level: 78 Points: 14,482, Level: 78
Level Up 8% Completed
FF Reputation: 18 SMITHBOY76908 Great Standing Member
Buy-Sell-Trade Rating: (4)
I did everything here. Still no signal. I think I have a basterd Xcal2. I've pretty much given up on getting a datalog of it. It's adjusted to between 11.5-11.7 now so no worries.
Russia... is... awesome!
SMITHBOY76908 is offline
Old 06-18-2009, 02:02 AM   #4
gottaride28
Fan#: 21892
no worries man your welcome!
Team Octane
Focus Revolution
Old 06-19-2009, 10:30 AM   #5
tetra
pwned
tetra's Avatar
Fan#: 60621
What I Drive: 2009 Black Clearcoat SES Sedan
Points 13,912, Level 76
Points: 13,912, Level: 76 Points: 13,912, Level: 76 Points: 13,912, Level: 76
Level Up 66% Completed
FF Reputation: 10 tetra Great Standing Member
Thanks for this write-up dude. Perfect timing, my AEM wideband is coming in the mail as we speak. It seems Brad is having trouble logging his A/F with the X3 because of the 2008+ aspect. I hope I don't run into this with the AEM!
tetra is offline
Old 06-19-2009, 11:14 AM   #6
UnFocusedST
Fear the TurboSnail!
UnFocusedST's Avatar
Fan#: 40342
What I Drive: 2013 Performance Blue Focus ST
Points 6,437, Level 52
Points: 6,437, Level: 52 Points: 6,437, Level: 52 Points: 6,437, Level: 52
Level Up 44% Completed
Forum Activity 17%
Activity: 17% Activity: 17% Activity: 17%
FF Reputation: 13 UnFocusedST Great Standing Member
Buy-Sell-Trade Rating: (14)
Okay now what about us who use the Xcal 3. That is perfect for the Xcal 2 though. Nice wright up.
Team Duratec #17
Hatch Nation #17
Midwest Crew #55
Boosted Crew #118
UnFocusedST is online now
Old 06-19-2009, 11:53 AM   #7
pistolgripbmx
pistolgripbmx's Avatar
Fan#: 49331
What I Drive: 86 ranger, 2007 focus zx3 s
FF Reputation: 38 pistolgripbmx Great Standing Member
Buy-Sell-Trade Rating: (8)
FOR X3
http://www.tricktuners.com/data_logging_info.htm
I had to go thru and check all the wires and find out what the colors were for each pin. had to buy the cable on ebay, NO ONE in my area had one at all.
all the rest is the same, except instead of 10+2*V for the conversion, you need to use 8.68V+10.
teamduratec #143!
focus sport cool-flo, f2 v.3 header, trubendz 2.5 SS, frpp 1.5" front sportline rear, vf rear engine mount, 93oct Focus Power tune
pistolgripbmx is offline
Old 06-20-2009, 03:06 PM   #8
gottaride28
Fan#: 21892
no problem guys gald i could help as for the x3 guys i have no clue sorry to say hope all goes well with your install!!!
Team Octane
Focus Revolution
Old 08-02-2009, 05:58 PM   #9
HaveBlue83
Guest
Fan#: 1358
What I Drive: a car
FF Reputation: 70 HaveBlue83 Excellent Standing Member
Buy-Sell-Trade Rating: (12)
so ALL we hook up is the white wire and that sends the signal to the Xcal? i don't need the blue wire to be connected? it's a lil vauge there for me....u said analog 2 wont be used so i am to assume that's the blue wire?
on the AEM gauge wiring we have:
Blue wire = ? (not used?)
red wire = switched power
white wire = signal from AEM to the Xcal for datalogging
black wire = ground
then u enter the formula and select wideband. and thats it right?
HaveBlue83 is offline
Old 08-02-2009, 08:23 PM   #10
pistolgripbmx
Fan#: 49331
yup!
teamduratec #143!
Similar Threads
a short lil write up about shortening the stock IB5 shifter Josh912 SPI Performance (2000-2004) 0 09-30-2007 07:38 AM
nice write up on a 02 svtf with dyno's svt4real SVT Performance (2002-2004) 10 04-11-2004 01:50 AM
