Building bottom end - tips please - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 06-14-2009, 10:21 PM   #1
sporadic
sporadic's Avatar
Fan#: 12724
What I Drive: 06 Sonic Blue ZX5 SES turbo
Points 13,029, Level 74
Points: 13,029, Level: 74 Points: 13,029, Level: 74 Points: 13,029, Level: 74
Level Up 45% Completed
Level up: 45% Level up: 45% Level up: 45%
Forum Activity 7%
FF Reputation: 62 sporadic Excellent Standing Member
Buy-Sell-Trade Rating: (12)
If you've seen my turbo build thread you know I'm not new to turning a wrench.
It just happens that I've never needed to crack open the bottom end of a engine for an overhaul.
In the upcoming weeks I'll be installing forged internals in my 2.0, after an overboost issue that left my rings a bit lacking. (it still runs)
I'll have some help from a friend who has rebuilt old VW Beetles engines so I'm not going in completely blind.
What I really need help with is a parts list - what I'll need for the build that I
might not think of.
I'm leaning towards a kit from F2 that includes pistons, rods, bearings etc for $945 here (link).
I'm open to suggestions, but Cosworth is out of the question.
My engine only has 32k miles on it. Should I need a head gasket?
The only thing I know it needs is rings.
I'm mainly going forged for the longitevity/reliability factor. I don't plan on going over 15psi.
What compression ratio would everyone suggest?
It's a daily driver. I don't want to go too low so it's not a dog when not in boost.
It sees far more time out of boost than in.
All comments, links, and tips appreciated.
2006 sonic blue zx5 GT2871r turbo.
sporadic is online now
Old 06-14-2009, 10:39 PM   #2
inis
Fan#: 32050
What I Drive: 00 Zx2 s/r (yellow)
Points 2,858, Level 32
Points: 2,858, Level: 32 Points: 2,858, Level: 32 Points: 2,858, Level: 32
Level Up 72% Completed
FF Reputation: 1 inis Good Standing Member
personally I think it really depends goals of the car. If your just looking to up the boost and be safe about it on a DD ..then you can do this for a pretty decent price.
F2 kit imo is kinda high priced, getting the stuff seperately will probally come out cheaper.
Eagle rods w/rod bolts = 300 shipped
Pistons can range from 350-700
Heres a decent deal, I'd prefer JE pistons over supertechs
http://cgi.ebay.com/ebaymotors/JE-Pi...Q5fAccessories
Rod and crank bearings will set you back around 125 for a basic set, 150 for a premium set, and around 240 for something like cali-coated bearings.
Arp studs for the bottom end should be 75ish
Yes get a new head gasket, go with a OEM gasket. Seems everyone is having the best luck with them. Wanting to take the c/r down a notch (rough est .5 c/r) get a svt hg. CFM is a good place to get that.
Also get head studs, might as well while your there. I think they're a 100ish.
Front and rear seals in a fel-pro I think are both under 50.00
Depends your wallet, I'd do every gasket but the cam cover (because it can be changed later) I think all in all you can do it all for under 100 using fel-pro brand.
Thats all I can think of right now. Look to spend around 1200-1500 all said and done.
inis is online now
Old 06-14-2009, 10:41 PM   #3
sporadic
sporadic's Avatar
Fan#: 12724
Forum Activity 7%
Thanks, but I have a Duratec so a few of those recommendations may not be the same between engines.
I'll definitely check prices closer and look into JE.
Old 06-14-2009, 10:43 PM   #4
inis
Fan#: 32050
ha , I didn't think to look at that.
If I come across anything I'll post it up for ya.
inis is online now
Old 06-14-2009, 10:47 PM   #5
sporadic
sporadic's Avatar
Fan#: 12724
Forum Activity 7%
Also if anyone has experience with the 2.0 Duratec internals and knows which parts let loose first please chime in.
Such as if I can stick with stock rods and just go with forged pistons.
Not that I'm trying to go cheap, but I'm also not one to waste money when not necessary.
I mainly ask because even with an overboost episode the stock pistons/rods didn't let loose, the rings did.
Old 06-14-2009, 11:43 PM   #6
1turbofocus
FF Affiliate
1turbofocus's Avatar
Fan#: 1123
Points 52,570, Level 100
Points: 52,570, Level: 100 Points: 52,570, Level: 100 Points: 52,570, Level: 100
Level Up 0% Completed
Forum Activity 57%
Activity: 57% Activity: 57% Activity: 57%
Buy-Sell-Trade Rating: (28)
No you cant keep the stock rods
Forged Pistons / Go over size
Eagle Rods
ARP head and main studs
Stock gasket set / use the felpro seals much better then Fords
Squair the block there off
Stock oil pump
Thats all you should need
There is a lot of talk about bearings and so far its all BS , Just get some regular Clevite/ Mich77 bearings and your fine
Customer Support
AIM: hpdyno
Email: hpdyno@aol.com
Phone: 704-249-3745
Site: focus-power.com
Elder 1turbofocus
1turbofocus is offline
Old 06-15-2009, 12:41 AM   #7
sporadic
sporadic's Avatar
Fan#: 12724
Forum Activity 7%
Thanks Tom. Why oversize?
Don't I need to bore the block for that?
I don't think I need to go to that expense for a block with 32k miles on it.
Old 06-15-2009, 12:59 AM   #8
sporadic
sporadic's Avatar
Fan#: 12724
Forum Activity 7%
I'd like some input on compression ratio.
I'm fine with the power I have/had, which was 204whp/224tq @ 10psi on 91 octane, unfortunately it nose-dived after 5200rpm.
I'm not sure whether it is the small turbo or a timing issue in the tune. Randy @ FS said tune.
I want to stick with 91 octane because that's common here instead of 93.
Of course I'd like to tune for a 93-95 octane tune for when I run it at the drag strip once a year or so.
Old 06-15-2009, 10:21 AM   #9
Roushturboedzx3
I Fab Too Much
Roushturboedzx3's Avatar
Fan#: 42814
What I Drive: 2002 Liquid Gray ZX3
Points 14,483, Level 78
Points: 14,483, Level: 78 Points: 14,483, Level: 78 Points: 14,483, Level: 78
Level Up 9% Completed
FF Reputation: 20 Roushturboedzx3 Great Standing Member
Buy-Sell-Trade Rating: (18)
Yes i would deff bore and hone the block is not expensive at all do it right the first time. and 9:1 compression would be good for you
New: 2012 Mustang GT premium
SOLD:RACE GAS 602whp 501tq Pump Gas SAE 454whp
Garrett GT3582r, Topmount, built motor, Ported head,Tuned by Fernando@RacingPartsSolution
I may not be the baddest, but the baddest dont Fu** with me
Roushturboedzx3 is offline
Old 06-15-2009, 10:22 AM   #10
1turbofocus
FF Affiliate
Fan#: 1123
Forum Activity 57%
If this is mostly a street driven car then I would do 9 to 9.2 compression , at some point you will be upping the boost
Yes do a new bore job and over size pistons with 32,000 wont matter what size you go to I just wouldnt do STD , it wont cost that much more
Customer Support
AIM: hpdyno
Phone: 704-249-3745
Elder 1turbofocus
Tags
bottom end , forged , internals , turbo
Similar Threads
You're doing it wrong! AKA Rice Reports(Post autofails here!) mattsstang87 Ford Focus & General Car Chat 15330 03-01-2015 07:10 PM
Front end Rattle fixed Ed60 Wheels & Tires 2 05-02-2007 12:25 AM
Do all Focus's have the split rear BOTTOM cushion? InFocus66 Ford Focus & General Car Chat 8 02-09-2007 08:58 AM
stock end links vs. prothane end links scironzts Wheels & Tires 4 06-04-2004 12:15 PM
