New ignition cylinder keys reprogram HELP - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 06-13-2009, 03:22 PM   #1
FocusFreak09
Flat Black King
FocusFreak09's Avatar
Fan#: 51243
What I Drive: 2001 Chevy Silverado
Points 14,335, Level 77
Points: 14,335, Level: 77 Points: 14,335, Level: 77 Points: 14,335, Level: 77
Level Up 72% Completed
FF Reputation: 30 FocusFreak09 Great Standing Member
Buy-Sell-Trade Rating: (9)
My ignition cylinder locked up on me and i got a new one from autozone. It came with new keys and before i take out the old one i need to know how to reprogram the new pats keys to the car so when i replace it then i can use the new keys. Any help would be appreciated. I already called some locksmiths but they charge way to much.
R.I.P. Izzy
R.I.P. Flat black focus
Stretch&Poke=
FocusFreak09 is offline
Old 06-13-2009, 04:08 PM   #2
Rabbitccc
Rabbitccc's Avatar
Fan#: 44508
What I Drive: 01 Blue SE / 09 Black Coupe SE
Points 8,638, Level 62
Points: 8,638, Level: 62 Points: 8,638, Level: 62 Points: 8,638, Level: 62
Level Up 63% Completed
FF Reputation: 28 Rabbitccc Great Standing Member
Buy-Sell-Trade Rating: (32)
If the ignition cylinder is locked you can't program them yourself. Your going to have to have a dealer do it.
The process of programming them is by putting the old key in and turing it to ON Like 3 times then putting in the new key and doing it.
o/_____\o
(8Oo)FORD(oO8)---SEDAN REVOLUTION
U_{=SR114=}_U----Upgrades In Profile
Rabbitccc is offline
Old 06-13-2009, 04:50 PM   #3
iminhell
C2H5OH
iminhell's Avatar
Fan#: 36222
Points 18,933, Level 87
Points: 18,933, Level: 87 Points: 18,933, Level: 87 Points: 18,933, Level: 87
Level Up 17% Completed
Forum Activity 11%
Buy-Sell-Trade Rating: (4)
http://www.focusfanatics.com/forum/showthread.php?t=193090
121,000 members and still no sponsored racing.
iminhell is offline
Old 06-13-2009, 04:58 PM   #4
FocusFreak09
Flat Black King
Fan#: 51243
ok well basically this is what i have done. i have replaced the old ignition cylinder with a new one, now when i go to start the car it wont. i put the old key up to it to see if it will work but it dont. what did i do wrong?
R.I.P. Izzy
Stretch&Poke=
Old 06-13-2009, 05:17 PM   #5
TerryB
TerryB's Avatar
Fan#: 34559
What I Drive: Red '01 ZX3
Points 5,249, Level 46
Points: 5,249, Level: 46 Points: 5,249, Level: 46 Points: 5,249, Level: 46
Level Up 50% Completed
FF Reputation: 68 TerryB Excellent Standing Member
I'm dealing with the same exact thing right now. There is a little green connector behind the cylinder. Hold the key sideways, teeth pointing towards the dash. I held mine in all different positions until I figured it out. I do not have a new cylinder yet. I'm turning the ignition with a screw driver for now with as I have removed the cylinder.
TerryB is offline
Old 06-13-2009, 05:20 PM   #6
FocusFreak09
Flat Black King
Fan#: 51243
well i tried putting the key up to the pats thing but it still wont start. i have no clue. it needs to work some how or i cant go anywhere. whenever i put the key in and turn it to start it the red led just blinks for along time and trhe car wont start.
R.I.P. Izzy
Stretch&Poke=
Old 06-13-2009, 05:43 PM   #7
the Duff
the Duff's Avatar
Fan#: 60423
What I Drive: 2009 Silver SES Coupe
FF Reputation: 3 the Duff Good Standing Member
Try this. Your gonna need two original (already programmed) keys or it won't work. Your also gonna need some quick hands, a buddy might be in order. Take the pats transponder off the steering column but leave it plugged in. With your new ignition cylinder installed turn the key to the run position for three seconds holding an original key up to the now dangling transponder ring. The theft light will be solid for three seconds and turn off if your holding the key correctly. Turn the ignition off. Now turn it back to the run position and hold your second original/programmed key up to the transponder. Again, if held correctly the theft light will be on for three than off. Now do the same thing again with one of your new keys. That key should now be programmed. You'll know if not, the theft light will be flashing. This should all be done in about 15 to 20 seconds. Make sure the theft light goes on then goes off before going to the next step. If it starts flashing, do it over again, but wait a good five minutes before the next attempt. This is what we call "two then new." Do the "two then new" with your other key and now your set. If you can't get this to work it's dealer time.
the Duff is offline
Old 06-13-2009, 05:54 PM   #8
FocusFreak09
Flat Black King
Fan#: 51243
ok now quick question, i am gonna try what u just told me but im not sure if the new keys have a chip in it or not. i got the cylunder from autozone and it came with keys.
R.I.P. Izzy
Stretch&Poke=
Old 06-13-2009, 06:08 PM   #9
Rabbitccc
Rabbitccc's Avatar
Fan#: 44508
If they don't look almost exactly like the originals, then they probably don't have a chip.
o/_____\o
Old 06-13-2009, 06:10 PM   #10
FocusFreak09
Flat Black King
Fan#: 51243
well they look exactly like the originals and it has a lil blue thing just like the originals but those are black. i took it out a lil and it has a lil deal in there that looks like an led and i also found this website that says what im looking for which im gonna try soon. http://www.fordf150.net/howto/patskey.php
R.I.P. Izzy
Stretch&Poke=
Similar Threads
Engine Light zummracer General Technical Chat 18 12-10-2013 10:08 PM
Every trouble code defined 03OrangeSVT General Forced Induction 9 05-25-2011 01:53 PM
Hesitation/Loss of Power lindleypoolman General Technical Chat 19 03-25-2009 03:02 AM
Ignition Cylinder Fix Question taziwac Ford Focus & General Car Chat 6 04-06-2007 09:56 PM
