Installing Automatic Headlamp System - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 07-23-2004, 05:13 PM   #1
SeannyC
Fan#: 10644
What I Drive: 2002 Ford Focus Zx3
FF Reputation: 1 SeannyC Good Standing Member
So I'm thinking about buying the Automatic Headlamp System from Ford's accessory website.
My question is, has anybody here actually installed on of these before. Can i get some instructions or advice?
Also, if I were to bring it to a dealer or some place to get it installed, how much would it cost. Does anybody have an idea?
thanks
SeannyC is offline
Old 07-24-2004, 12:49 PM   #2
mySVT
mySVT's Avatar
Fan#: 5557
What I Drive: 2013 Ingot Silver ST
Points 2,446, Level 29
Points: 2,446, Level: 29 Points: 2,446, Level: 29 Points: 2,446, Level: 29
Level Up 98% Completed
FF Reputation: 1 mySVT Good Standing Member
I just installed this on my car, and it's pretty sweet. I won't say it's the easiest install, but I could give you some pointers and maybe it will be easier for you. You have to find and splice into about 8 wires, most under the dash either in the ignition harness or kick panel. It will help if you have a multimeter to find the wires you need. The hardest one to get to is the wire to the parking brake switch. This is so your lights will not come on (DRLs or full headlights) until you release the parking brake. Someone on another thread was saying he didn't like his because at a drive in movie, he couldn't turn the car on (for a/c or to roll down windows, etc) without his headlights coming on. The parking brake switch on this system solves that problem. I have no idea what your dealer might charge, but it might be worth looking into.
SVT SQUAD #12 '13 Silver Focus ST3, moonroof
Old: 03 Silver SVT ZX5 #1459/2173, HIDs, Moonroof, Audiophile. Mods: Hawk pads, Waynes Tune, K&N filter
Older: 02 Silver ZX5 Premium, Leather, Moonroof
mySVT is offline
Old 07-24-2004, 04:46 PM   #3
SeannyC
Fan#: 10644
thanks
SeannyC is offline
Old 07-25-2004, 09:32 AM   #4
SeannyC
Fan#: 10644
can you tell me what came in the package? Did it include instructions?
SeannyC is offline
Old 07-25-2004, 12:35 PM   #5
mySVT
mySVT's Avatar
Fan#: 5557
The Control Module with a pigtail of about 8 wires on it, a little bag of conncetors and multi-lingual instructions. There was a grid that showed what color and where to find the wires you need to splice into for most Ford cars & trucks, but the Focus for some reason wasn't on there. So that's why it took me a little longer to figure out what wires to connect to. Other than that, the instructions were pretty clear.
mySVT is offline
Old 07-28-2004, 08:46 PM   #6
SeannyC
Fan#: 10644
So i'm planning on installing this myself. Were there any problems that you ran into, any difficult parts of the instalation? Or was it all pretty straight forward and simple?
Any tips would be helpfull.
SeannyC is offline
Old 07-28-2004, 09:56 PM   #7
mySVT
mySVT's Avatar
Fan#: 5557
The hardest part for me was getting to that parking brake switch/wire, which included having to remove the center console. I'm not sure how hard yours will be to get off (my SVT console is different than yours), but that should be your biggest obstacle. I don't think it is a must-do, so you might try without it to see how it works. It would just make your DRLs come on immediately when you start the car. Actually I think there is a 3-4 second delay for the sensor to determine if it is dark or not. BTW, is your car manual or auto trans? If it is auto, you may never use your parking brake anyway - I know a lot who don't - so that might decide for you. If you still want to do the PB switch with an auto, it may be harder than a manual to get off, and I can't help you much there. Enough about the PB switch.
Of the remaining wires, one (ground) is best to go behind the kick panel. You will see a couple of wires bolted to the body there, undo one and put the ground wire (in an eye connector) on the bolt to. The other 5 or 6 wires all went to either the headlight switch (which is easy to get to) and the ignition wire harness (kinda easy, but the wires are in there tight). To get to all of these you will want to take off the panel under the steering wheel. 4 screws and its off, but to take it out you have to unhook the connector under the fuse door and unbolt the hood release. Next take off the small panel around the headlight switch that includes the left a/c vent. There is one screw then just pop it out (there are 2 or 3 clips) and tilt to left to get vent out. Then 3 screws on headlight switch. Here is where you will need a multi-meter to find the wires the instructions call for. I mounted the module with the little tie straps that come with it to one of the metal frame pieces of the dash.
The only other real issue I had was where to hook one wire that was supposed to go to the 'multi-function' switch - ie hi-beam, low-beam switch. I still haven't found that one for sure, but after trying without it, I found that I could just wire it to the same as the head light wires and it worked fine.
Well, that should be enough to either get you started or get you thoroughly confused. I will try to post some pics of where I put the day/night sensor.
I tried finding the posts I got this from but I couldn't so here is the text. It should help with wiring, but doesn't have everything.
Code:
|       ITEM      |     WIRE COLOR     |POL|       WIRE LOCATION        |
|              12V|red                 |+  |ignition harness            |
|          STARTER|gray/black          |+  |ignition harness            |
|         IGNITION|green/yellow        |+  |ignition harness            |
|        ACCESSORY|yellow              |+  |ignition harness            |
|       POWER LOCK|black/red           |-  |drivers kick panel          |
|     POWER UNLOCK|black/yellow        |-  |drivers kick panel          |
|       LOCK MOTOR|yellow/black        |   |drivers kick panel          |
|     UNLOCK MOTOR|white/black         |   |drivers kick panel          |
|    DISARM DEFEAT|white/black         |   |passengers kick panel       |
| PARKING LIGHTS +|orange/yellow       |   |headlight switch            |
| PARKING LIGHTS -|                    |   |                            |
|       HEADLIGHTS|grn/blu(L),grn/yel(H|+  |steering column *3          |
|     DOOR TRIGGER|black/blue          |-  |low in drivers kick panel   |
| DOME SUPERVISION|use door trigger    |   |                            |
|  TRUNK/HATCH PIN|black/white         |-  |trunk light                 |
|         HOOD PIN|black/yellow *4     |-  |keyless module *1           |
|TRNK/HTCH RELEASE|black/yellow        |-  |switch or keyless module *1 |
|  FCTRY ALARM ARM|                    |   |                            |
|FCTRY ALRM DISARM|                    |   |                            |
| DISARM NO UNLOCK|                    |   |                            |
|       TACHOMETER|black/green         |   |ignition coil               |
|      SPEED SENSE|white/green         |   |radio                       |
|       BRAKE WIRE|lt. green/red       |+  |brake switch *2             |
|     HORN TRIGGER|black/blue          |-  |steering column             |
|           WIPERS|white/green         |+  |steering column             |
|  LF WINDOW UP/DN|yellow - white      |A  |in drivers door at motor    |
|  RF WINDOW UP/DN|yel/pur - wht/pur   |A  |drivers switch or kick panel|
|  LR WINDOW UP/DN|yel/blu - wht/blu   |A  |drivers switch or kick panel|
|  RR WINDOW UP/DN|yellow - white      |A  |drivers switch or kick panel|
| SUN RF OPN/CLOSE|                    |   |                            |
|   SUN ROOF LIMIT|                    |   |                            |
|        RADIO 12V|orange/black (thick)|+  |radio                       |
|     RADIO GROUND|blk/yel & blk/grn   |-  |radio                       |
|     RADIO SWITCH|yellow/green        |+  |radio                       |
| RADIO ILLUMINATE|orange/black (thin) |+  |radio                       |
|    POWER ANTENNA|                    |   |                            |
|       LF SPEAKER|wht/blk - gry/blk   |   |radio                       |
|       RF SPEAKER|wht/red - gry/red   |   |radio                       |
|       LR SPEAKER|wht/pur - gry/wht   |   |radio                       |
|       RR SPEAKER|white - gray        |   |radio                       |
NOTE: This vehicle is equipped with a passive immobilizer that needs to be bypassed
for remote start operation only. Use DEI part number 555S to bypass.
*1 Keyless module is behind the glove box to the right.
*2 To meter the brake wire, must turn ignition on.
*3 Low beam at the headlight switch is green/red.
*4 Only if equipped with factory alarm.
from another post:
Constant 12 volts RED IGNITION SWITCH HARNESS
Ignition 12 volts GREEN/YELLOW IGNITION SWITCH HARNESS
Starter GRAY/BLACK IGNITION SWITCH HARNESS
Dome Light BLACK/BLUE (-) DRIVERS KICK PANEL
Trunk Pin Switch BLACK/BLUE (-) DRIVERS KICK PANEL
Parking Lamp ORANGE/YELLOW (+) AT HEADLIGHT SWITCH
Power Lock BLACK/ORANGE DRIVERS KICK PANEL* #201
Power Unlock BLACK/YELLOW DRIVERS KICK PANEL
mySVT is offline
Old 07-28-2004, 09:58 PM   #8
SeannyC
Fan#: 10644
hod damn! thanks!
Its an auto so the PB switch isn't a big deal. hopefully getting to those wires won't be to hard.
SeannyC is offline
Old 07-28-2004, 10:58 PM   #9
mySVT
mySVT's Avatar
Fan#: 5557
View of sensor from drivers seat
mySVT is offline
Old 07-28-2004, 11:07 PM   #10
mySVT
mySVT's Avatar
Fan#: 5557
From outside looking down thru windshield
mySVT is offline
Similar Threads
Need help with this code. 9318 DomestikZx3 General Technical Chat 17 07-11-2012 10:59 AM
Ford Focus and C Segment News/Press Release. DrkKnight614 Ford Focus & General Car Chat 9 03-01-2010 10:51 PM
The Exhaust Thread, Talk, Discussion, and Information honhon DURATEC Performance (2003-2007) 31 09-20-2008 05:36 PM
DTC Codes (Detailed Descriptions) S2 General Technical Chat 13 12-11-2006 12:06 PM
