VCT fail + front O2 slow (P1381 P1383 P0133) - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 06-06-2009, 07:59 PM   #1
mellephants
omn-nom-nomnomnomnom
mellephants's Avatar
Fan#: 52400
What I Drive: 12 SE, 91 DR350S, 74 CL360
Points 11,048, Level 69
Points: 11,048, Level: 69 Points: 11,048, Level: 69 Points: 11,048, Level: 69
Level Up 50% Completed
FF Reputation: 12 mellephants Great Standing Member
Buy-Sell-Trade Rating: (15)
2002 SVTF w JRSC + BBK, still running the FRPP tune, I have PRP, just waiting for enough spare time to start tuning. If this should be in Technical Chat or SVT Performance, please move it for me!
First off, I'm suddenly throwing P1381 and P1383, and car feels slow (especially at higher rpms... eg my car will not spin the tires if I roll to WOT at 4k in 1st, normally that would be a gross waste of tire). I blame the VCT solenoid, because unplugging it has no noticeable affect on power (just throws a P1380, which disappears when reconnected, indicating that the solenoid wiring is fine).
I reset the DTCs, and took a short test drive. Only P1383 came back. Is retardation of the intake cam consistent with my symptoms (lack of upper RPM power)?
I'm thinking about doing Tom's VCT Eliminator, rather not screw with this anymore since the pros and cons are sort of a toss-up. New solenoids are something like $60, and his eliminator kit is $100 I think. I wouldn't necessarily have to buy another cam gear, either; I already have an adjustable exhaust cam gear, at 0, so I could just dig up the OEM cam gear to use.
Secondly, I noticed an EXCESSIVE amount of oil coming from my crankcase ventilation. I was running a JR plate + draft tube, now I've got a bottle on the hose to collect the oil. I get about 3oz from only 5 minutes of driving. I'm thinking my ringlands might be fubared, going out to do a compression check as soon as she cools off a bit. This has been a known issue for awhile now, last time I checked I had something like 90-120-120-120. EDIT: Current compression:
80-130-125-127
And finally, I'm ALSO getting a P0133, which did not return after clearing. Not too worried about it, just gonna wait to see if it comes back... I guess since I'm at 77k now, I might need to order a new Motorcraft sensor. Oh- the FRPP tune runs horribly rich, so it could be causing this, too.
P0133 - HO2S Sensor Circuit Slow Response (HO2S-11)
The HEGO Monitor checks the HO2S Sensor frequency and amplitude. If during testing the frequency and amplitude were to fall below a calibrated limit, the test will fail. Contaminated HO2S sensor.
Exhaust leaks.
Shorted /open wiring.
Improper fueling.
MAF sensor.
Deteriorating HO2S sensor.
Inlet air leaks.
P1380 - Variable Cam Timing Solenoid A Circuit Malfunction
The comprehensive component monitor(CCM) monitors the VCT circuit to the PCM for high and low voltage. If during testing voltage was to fall below a calibrated limit a calibrated amount of time the test will fail.
Open or short VCT circuit
Open VPWR circuit
Damaged PCM
Open or short VCT solenoid valve
P1381 - Variable Cam Timing Over-advanced (Bank 1)
The comprehensive component monitor (CCM) monitors the VCT position for an over-advanced camshaft timing. The test fails when the camshaft timing exceeds a maximum calibrated value or remains in an advanced position.
Cam timing improperly set
No oil flow to the VCT piston chamber
Low oil pressure
VCT solenoid valve stuck closed
Camshaft advance mechanism binding (VCT unit)
P1383 - Variable Cam Timing Over-retarded (Bank 1)
The comprehensive component monitor (CCM) monitors the VCT position for over-retarded camshaft timing. The test fails when the camshaft timing exceeds a maximum calibrated value or remains in an retarded position.
Continuous oil flow to the VCT piston chamber
VCT solenoid valve stuck open
SCT PRP FTMFW!
mellephants is offline
Old 06-06-2009, 10:23 PM   #2
1turbofocus
FF Affiliate
1turbofocus's Avatar
Fan#: 1123
Points 51,841, Level 100
Points: 51,841, Level: 100 Points: 51,841, Level: 100 Points: 51,841, Level: 100
Level Up 0% Completed
Forum Activity 31%
Activity: 31% Activity: 31% Activity: 31%
Buy-Sell-Trade Rating: (28)
The o2 slow in most cases means the o2 is bad and time to change it , you will find your self changeing them more with FI
With my VCT Elim you will have a VERY LOPPY idle when gears are adjusted right because of the large Cams the SVT has , it will be a MUST to adjust them on a dyno
Customer Support
AIM: hpdyno
Email: hpdyno@aol.com
Phone: 704-249-3745
Site: focus-power.com
Elder 1turbofocus
1turbofocus is online now
Old 06-06-2009, 11:39 PM   #3
mellephants
Fan#: 52400
Ok, ordering a motorcraft front O2. Thanks.
Interesting. I wouldn't expect a lopey idle to mandate dyno tuning... What drawbacks would I encounter doing a street tune without VCT? Just idling issues, or open loop operation too?
Also, do you think I would be it would be a waste of time re-using someone else's used OEM SVTF pistons & rods (cleaned up + new rings) if ringland problems eliminate re-ringing my pistons? If so I suppose I'd be looking at installing forged rods & 9.5 or 10:1 pistons, right?
SCT PRP FTMFW!
Old 06-06-2009, 11:44 PM   #4
1turbofocus
FF Affiliate
Fan#: 1123
Forum Activity 31%
No way at all or even close to tune the SVT with out a working VCT or VCT Elim set on a dyno
Dont even try it
Customer Support
AIM: hpdyno
Phone: 704-249-3745
Elder 1turbofocus
Old 06-06-2009, 11:52 PM   #5
mellephants
Fan#: 52400
Lame. Well looks like I have to order another VCT solenoid. Luckily I have a few friends with SVTFs that might let me try theirs.
SCT PRP FTMFW!
Old 06-07-2009, 01:45 AM   #6
focusguy87
I AM DA FOCI FANATIC
focusguy87's Avatar
Fan#: 40962
What I Drive: 03 Red EvO & 03 TURBO SVT
FF Reputation: 9 focusguy87 Good Standing Member
Buy-Sell-Trade Rating: (6)
why are you always stealing my parts? LOL
FOR SALE,
2003 Turbo SVT ZX5 318WHP (SOLD)
2003 Evolution 8 320AWHP
focusguy87 is offline
Old 06-07-2009, 02:23 AM   #7
darkstarmotorsports
darkstarmotorsports's Avatar
Fan#: 59343
What I Drive: 2003 SVT Focus
FF Reputation: 1 darkstarmotorsports Good Standing Member
Buy-Sell-Trade Rating: (22)
look for a Escort ZX2 or a Mercury cougar 4 cycl.
Also, if you remove the VCT with "tom's kit" or either "zxTurner's kit" you will still throw a CEL. you would have a special tune to have it turned off. I had one done on my race ZX2, SCT was able to do it.
darkstarmotorsports is offline
Old 06-07-2009, 03:26 AM   #8
illinipo
Token Engin-nerd
illinipo's Avatar
Fan#: 37693
What I Drive: dirty wag; Party; Bavarian phallus
FF Reputation: 272 illinipo Outstanding Standing Member illinipo Outstanding Standing Member illinipo Outstanding Standing Member
Buy-Sell-Trade Rating: (19)
Have you logged vct angle yet?
You also mentioned your vct is leaking oil, you may have bigger problems.
Posted via FF Mobile
illinipo is offline
Old 06-07-2009, 08:37 AM   #9
1turbofocus
FF Affiliate
Fan#: 1123
Forum Activity 31%
The ZX2 VCT Elim wont work on the SVT , ONLY the SVT solenoid will work on the SVT , the ZX2 and Contour are Diff from what I understand
He has the SCT PRP so he has the ability to turn off the VCT codes
It is very common for the VCT Solenoid to leak oil when they break
Customer Support
AIM: hpdyno
Phone: 704-249-3745
Elder 1turbofocus
Old 06-07-2009, 09:58 AM   #10
mellephants
Fan#: 52400
Yeah, I logged a few VCT items, none of the things I logged were active though. I'll log all of the VCT stuff next time.
I don't have any oil leaks anymore (just the crankcase vent spitting oil like crazy); VCT solenoid o-ring was shot, got a new one from Advance for 49 cents, worked perfect.
I might have to upgrade the 20oz mtn dew bottle to a 2-liter to make it over to the farm, charles... Or stop a few times to empty it.
SCT PRP FTMFW!
Similar Threads
Focus Light Bulb Guide (MOD STICKY THIS) TKE_Quailman MK2 Focus 13 11-09-2008 05:36 PM
DTC Codes (Detailed Descriptions) S2 General Technical Chat 13 12-11-2006 12:06 PM
New Volkswagen Rabbit!! nomoreavril Ford Focus & General Car Chat 30 06-29-2006 12:55 PM
Ford Focus: Suspension & Brakes hotfocus Brakes, Suspension & Body Chassis 0 02-17-2005 04:40 AM
