morale of the story...... GET AN ALIGNMENT DONE!!! - Ford Focus Forum, Ford Focus ST Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum > Ford Focus Tech Discussions > Wheels & Tires - Sponsored By Tire Rack
Wheels & Tires - Sponsored By Tire Rack The place to go for answers on wheel types, tire sizes, offset, wheel patterns and more.
Sponsored By:
Tire Rack
Old 07-23-2004, 01:31 PM   #1
whiteboyslo
whiteboyslo's Avatar
Fan#: 180
What I Drive: 04 Pontiac GTO - Yellow M6
FF Reputation: 2 whiteboyslo Good Standing Member
Buy-Sell-Trade Rating: (11)
OK-
so ever since i put some Kumho 712s in 205/45/17 on my car, it had been rubbing like crazy. it didn't rub around hard corners, only on hard dips. i was trying everything to get it to go away. at first i thought my suspension was just too soft (it's the FK 35/40), but i didn't want to have to replace it because it's expensive and time-consuming. then i thought my wheel offset was wrong, but it's a +42mm offset so that couldn't be it, either. then i figured the tire was just too tall, but a 205/45/17 is the same height (roughly) as a 205/50/16, which was stock on my ride.
i did everything i could to get this thing to go away. i tried rolling the fenders (good old bat in the wheelwell routine).got rid of the rub on all but the driver rear. now i figured "great, i'm just too damn heavy and it's my fat ass that's causing it to rub." so i tried taking everything out of the back of the car (stereo) or moving it to the passenger side. still rubbed!
so finally i get into a debate with a guy over at FJ as to whether a 205/45/17 will fit with a 2" drop. he says yes, i say no. finally one of the mods gets on and suggests that i get an alignment. i thought it was a pretty dumb idea since i've already had the car aligned 3 times (once when i dropped it, another time after i put the new wheels and tires on, and a third time when it got in an accident), but i decided it couldn't hurt since it was about the next cheapest option i had to try and fix this problem.
so i get to Sears and i tell the guy why i want to get an alignment. he says "forget it, you're wasting your money." i told him that i just went from 205/40/17 to 205/45/17 about 3 months ago and that's when this problem started. he said "still shouldn't make that much of a difference." i decide to go ahead and get it done anyway, and you can probably guess the outcome....
NO MORE RUB!!!!!! WOO-HOO!!!!!
i'm so friggin stoked! turns out the camber wasn't out of spec on any of the corners, but they went ahead and set it more negative to really true it up. the REAL culprit was the toe on the driver rear (the one that was rubbing). turns out it was out of spec by all of .12 degress if i remember right, but THAT"S WHAT WAS CAUSING ALL MY HEADACHE!!!!
morale of the story: if you do ANY kind of suspension work to your car, even if it's as simple as changing tire sizes, GO GET AN ALIGNMENT DONE!!!!!!!!
Mike
just visiting now....
whiteboyslo is offline
Old 07-23-2004, 02:24 PM   #2
Egz
Sückn' n Blown
Egz's Avatar
Fan#: 442
What I Drive: 2003 2.3l ZX3
FF Reputation: 111 Egz Excellent Standing Member Egz Excellent Standing Member
How did they adjust your camber? Its not adjustible, unless you have a kit.
January 2008 Focus Fanatics ROTM
2003 Ford Focus ZX3 2.3l N/A = 221 HP, 162 ft-lbs, 13.967@100.88MPH
2006 Ford Fusion 2.3l Turbo = 244HP, 247ft-lbs
duratec.wikispaces.com - Duratec Wiki - Sign up and contribute!
Egz is offline
Old 07-23-2004, 02:45 PM   #3
Solaris
Solaris's Avatar
Fan#: 52
What I Drive: 1985 Volvo 740 GLE
FF Reputation: 1 Solaris Good Standing Member
i thought everyone knew that suspension mods = alignment?
2001 Liquid Grey S2 will be remembered as my first love.
Now driving a 1985 Light Blue Volvo 740 GLE with 95,000 miles on it
Solaris is offline
Old 07-23-2004, 03:08 PM   #4
whiteboyslo
Fan#: 180
they CAN adjust your REAR camber from stock, it's just that the stock hardware doesn't allow that much play. apparently there's some sort of TSB on this issue because when the car was in getting the collision work taken care of, they said they added new hardware to get the alignment in at no cost to me or the other party's insurance.
yes, solaris, that's ultimately what i was getting at. i just didn't think going from 205/40/17 to 205/45/17 would make THAT much difference on the alignment. apparently i was wrong.
Mike
Old 07-23-2004, 05:23 PM   #5
Egz
Sückn' n Blown
Egz's Avatar
Fan#: 442
Ah, I was thinking of the fronts only.
Egz is offline
Similar Threads
alignment???? zx5Ye Brakes, Suspension & Body Chassis 36 01-16-2009 11:42 AM
Alignment with Adjustable Upper Control Arms 2003focusowner Wheels & Tires - Sponsored By Tire Rack 10 06-24-2008 09:51 PM
Engine codes caused by alignment Red_Sonja General Technical Chat 1 05-11-2008 08:50 PM
Alignment Necissary? Kaduku Wheels & Tires - Sponsored By Tire Rack 5 12-26-2005 09:50 PM
alignment after drop - how soon? whiteboyslo Wheels & Tires - Sponsored By Tire Rack 1 09-24-2003 04:58 PM
Focus Fanatics Ford Focus Forum offers many fun ways for you to engage with other Ford Focus Owners from across the world. Whether it be about the aftermarket performance modifications, technical how-to's, European tuned suspension or awesome fuel economy similar to the Cadillac ATS-V, Ford Fusion and Acura TLX. You can find all Ford Focus and Focus ST related information here. Join our Ford Focus discussion forums and chat with local Focus enthusiasts in your area.
