How-To: 2008 - 2011 Halo Projectors Light Installation - Page 7 - Focus Fanatics
Go Back   Focus Fanatics > Ford Focus Second Generation > MK2 Focus
Old 11-07-2009, 09:23 AM   #61
RaNd0b
Fan#: 64181
What I Drive: 2009 Vista Blue Focus
FF Reputation: 1 RaNd0b Good Standing Member
i wouldnt go the hid route anyhows great how-to arasky one last question the oem headlamps they have the dot code inscripted on the bottom of the lenses do the ccfl halo headlamps also have a dot code or no? i didnt see one in the close up pics just verifying
RaNd0b is offline
Old 02-01-2010, 01:59 AM   #62
rhgop08
Fan#: 59315
What I Drive: Black Number 1
FF Reputation: 1 rhgop08 Good Standing Member
Question
Originally Posted by arasky View Post
if you want to get HIDs, you need an h13 harness and a h9 bulb, i just realized that the hard way. if you already bought a h9 kit, just go buy a h13 hid harness online. you dont need the one with the relay or fuse or anything. if that doesnt make sense i can be a little more specific.
Could u please clarify? Thanks a lot.
Im a cook I deal with rice everyday.
rhgop08 is offline
Old 02-01-2010, 10:23 PM   #63
arasky
arasky's Avatar
Fan#: 54776
What I Drive: -
FF Reputation: 7 arasky Good Standing Member
h9 hid bulb-> h13 harness-> headlamp.
arasky is offline
Old 02-12-2010, 07:32 AM   #64
Motor City Madman
Motor City Madman's Avatar
Fan#: 67832
What I Drive: 2009 silver SE Coupe
FF Reputation: 1 Motor City Madman Good Standing Member
...The bolts on the headlight are 13/32 hexheads, so you'll need that size socket...
They're actually 10mm.
...You will then need to grab the new headlamps and find the red tab coming out of the back.
If you take a closer look at it, it has two metal "things" on the left hand side of the tab.
You need to make the metal "things" be on the right side, like this
The easiest way to do this is to first use your nail to move it "flip" it over to the opposite side. Once you get it on the right side, use some pliers to push it flat to the tab (like in above picture), so it looks like it came that way. Then, plug that into the sidemarker adapter you removed earlier, like this
It may be hard to get in at first, so you might need to make the metal "thing" lay more flat, but it will go in there. I received a picture of this with my kit, but it was a little bit different.
A side note on this step. On the little red plug that you flip the wires over to the opposide side, it will plug in to the side marker light socket two ways. One way, only the halos will work, not the leds. If the leds aren't working, turn it 180 degrees and try again. I found this out the hard way. plugged one headlight in and the leds didn't work. Plugged the other one in and everything worked. Thought I was gonna have to ship one light back. Then found on the "instruction sheet", that is mostly Chinese, some half-assed explanation of having some wires the "right way". Tried the "bad light" again and it worked.
Motor City Madman is offline
Old 02-12-2010, 07:56 AM   #65
Motor City Madman
Fan#: 67832
After having been able to see the lights myself, why couldn't you use the h9 harness on the actual light, under the big rubber cover. You would unplug the bulb from it's connector and put the h9 harness between that connector and the HID bulb. By using the h13 harness on the h13 plug on the headlight, you're, essentially, disabling the high beam shutter because h13 HID harness has no means to activate the high beam on the new headlight. Just a thought.
Old 02-13-2010, 02:26 PM   #66
JustHereFTM
JustHereFTM's Avatar
Fan#: 68588
What I Drive: 2008 Focus
FF Reputation: 7 JustHereFTM Good Standing Member
all you need to know is that the black wire from the halo/led's need to go to teh black wire w/ color stripe on the parking lamp socket and the blue wire from the halo/led's goes to the purple wire w/color strip on the parking lamps.
also mine dont flash when i lock the car either but im cool with that.
JustHereFTM is offline
Old 02-13-2010, 02:26 PM   #67
JustHereFTM
Fan#: 68588
these headlamps are DOT approved :D
Old 02-14-2010, 08:17 AM   #68
slowduratec
slowduratec's Avatar
Fan#: 59069
What I Drive: 2006 Toreador Red ZX3
FF Reputation: 10 slowduratec Great Standing Member
Your projectors are bi xenon already so no need for all the h13 stuff. Your highs are probably now connected to your cut-off shield there's is a solenoid that bring your shield down
http://i253.photobucket.com/albums/h...side20of20.jpg
That solenoid will pull your shield down causing it to be your brights. So all you need is the h9 kit
IT'S SLOW (KANYE WEST IS GAY!!!)
Team Duratec #236
slowduratec is offline
Old 02-15-2010, 02:16 AM   #69
JustHereFTM
Fan#: 68588
wow, you can see the little cut off that makes the "Z" pattern on the wall in that sheild. thats crazy how that 1mm difference makes that huge difference :)
Old 02-15-2010, 12:04 PM   #70
slowduratec
Fan#: 59069
Im sorry i forgot your OEM lights were h13, so yea you may need the h13 kit or hard wire the solenoid to the brights???
Team Duratec #236
Similar Threads
Q type rear bumper + FREE halo projectors lamps toeycrack Archive 10 08-04-2007 04:12 AM
Halo Projectors for Sale - Awesome Condition SVTFRobexe Archive 10 11-17-2006 10:55 AM
Washed, waxed, and cataracts (Halo Projectors) removed! 56k, tread carefully T-V Ford Focus Builds & General Showroom 13 09-10-2006 11:24 PM
