For Sale: 16G turbo - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 05-29-2009, 12:43 PM   #1
brummy
Fan#: 14086
What I Drive: 2000 ZX3
FF Reputation: 1 brummy Good Standing Member
For Sale: 16G turbo
Item Description - This is an ebay special 16G turbo that I bought new. It has under 1K miles on it and it barely saw any boost as I had been driving around with it before my tune and I never got into boost without a tune. When I did get into boost after my tune, it was only about 7-8psi. It has the same bolt pattern in the exhaust flange and uses the same O2 housing as the 14bs and T25s from the 1g and 2g DSMs. It also has the same compressor outlet flange as 14bs and uses the same oil drain flange and inlet fitting as well as the same fittings for coolant lines. There is absolutely no shaft play and everything is in great shape. Don't let the bad reputation of ebay turbos dissuade you, this is a good unit. I replaced it with a DSM T25 because I wanted something with a much quicker spool as I'm not too concerned with top end power.
Asking Price - $150 OBO
Email Address - ericb@muskingum.edu
Location - Parkersburg, WV 26101
00 ZX3 DD now with over 100K miles
Old turbo: 14b @ 9ish psi: 182.93whp, 188.57wtq (blown seals)
Chinese 16G @ 7psi: 180.62whp 193.6wtq (died at 5,000 rpms)
DSM T25 at 13 psi coming soon (third time's a charm, right?)
brummy is offline
    Quick reply to this message
Old 05-29-2009, 01:11 PM   #2
zero visual
zero visual's Avatar
Fan#: 641
What I Drive: 1990 Eagle Talon AWD TSi
FF Reputation: 1 zero visual Good Standing Member
u got pm
Zetec Crew #138
zero visual is offline
Old 05-29-2009, 02:24 PM   #3
zero visual
Fan#: 641
tried pming you back but says your not receiving any right now. how are the seals on it?
Zetec Crew #138
Old 05-30-2009, 10:10 AM   #4
brummy
Fan#: 14086
I was in the process of having my email changed with the site. I didn't know FF was going to make it so that I was unable to post or even receive PMs until they decided to send me a verification email.
The seals are fine as far as I know. There was no smoke or evidence of burned oil or blown seals at all.
brummy is offline
Old 06-03-2009, 12:20 AM   #5
brummy
Fan#: 14086
bump, this is still up for grabs
brummy is offline
Old 06-06-2009, 02:35 PM   #6
brummy
Fan#: 14086
bump
brummy is offline
Old 06-14-2009, 08:10 PM   #7
brummy
Fan#: 14086
bump
brummy is offline
Old 06-15-2009, 06:15 PM   #8
NeweracapMAN
NeweracapMAN's Avatar
Fan#: 64914
What I Drive: 06 red ZX4, 04 silver SVT cobra
FF Reputation: 8 NeweracapMAN Good Standing Member
this will fit all focus right? 06 zx4? how much HP will it give u
NeweracapMAN is offline
Old 06-15-2009, 07:31 PM   #9
brummy
Fan#: 14086
It will fit with the right manifold, yeah. As far as power, that's such a huge open-ended question I couldn't possibly give you an accurate number. The internal wastegate is set at around 7-8 psi, which on a stock motor could be enough for just under 200whp, but with enough supporting mods, I'd say this could get you at least twice that.
brummy is offline
Old 06-16-2009, 08:52 PM   #10
NeweracapMAN
Fan#: 64914
ok so with this do u have everythign ready to install it. is it a direct bolt on? will i need anythign else inorder to install and run it? liek gauges?
y did u replace it? does it still work
and y is it like rusted around? if its rust.
sry for question but i have $$ i just want to make sure it will work all good
Tags
16g , evo iii , td05 , turbo
Similar Threads
Boosted Crew Updated ZX3_2NV General Forced Induction 66 01-26-2009 12:22 PM
For Sale: Garrett GT3071R Turbo pocus02x3 Archive 19 01-24-2009 06:05 PM
Evo 16g Turbo FocusZx3Oh General Forced Induction 26 06-02-2007 11:57 AM
Turbo noob's q 2Slow2Race General Forced Induction 6 05-09-2007 02:30 AM
Turbo Questions - maybe a sticky eventually? petik General Forced Induction 5 10-11-2004 03:17 PM
