2008 Halo Projector Headlights Install - Page 15 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 05-22-2013, 10:07 PM   #141
iamwreckless
Fan#: 114929
What I Drive: 2008 Black Focus
FF Reputation: 1 iamwreckless Good Standing Member
Originally Posted by Miztaken1312 View Post
What do the wires for the halos plug into? Or do you have to tap into something else? That's really the only thing I'm curious about, other then the bulb size for the headlight.
The halos plug straight into the adapter for the parking lights.
LIKE A BOSS :D
iamwreckless is offline
Old 04-21-2014, 05:44 PM   #142
Miztaken1312
Miztaken1312's Avatar
Fan#: 74993
What I Drive: 2008 Black Coupe SES
Points 1,389, Level 20
Points: 1,389, Level: 20 Points: 1,389, Level: 20 Points: 1,389, Level: 20
Level Up 89% Completed
Level up: 89% Level up: 89% Level up: 89%
FF Reputation: 2 Miztaken1312 Good Standing Member
So I'm going to revive this thread to share with you all that you CAN have high beams with these, and I do. Currently one of the pins coming from the projector housing on the driver side has a loose pin that makes contact only 50% of the time. I will be rectifying the problem tonight hopefully and I will show you all how to do it.
FSWerks Turbo Kit @ 8psi , Stealth Exhaust, & Lower Stress Bar | Projectors w/5000K HIDs, LED Tails with Lamin-X Tint
Steeda Short Throw & Upper Strut Bar| FRPP Suspension & CFM Lower Mount |
Miztaken1312 is offline
Old 04-21-2014, 09:06 PM   #143
Death Site DSI
Death Site DSI's Avatar
Fan#: 62763
What I Drive: 08 Focus SE, 2014 Honda CTX700ND
Points 1,507, Level 22
Points: 1,507, Level: 22 Points: 1,507, Level: 22 Points: 1,507, Level: 22
Level Up 7% Completed
FF Reputation: 2 Death Site DSI Good Standing Member
I have had 2 bulbs Melt to the connector on 2 different sets of these headlights. which that could be the problem or some else. the only way i can get the right connector is from Sabersport any other one online will not fit due to the tight fit of the wires when twisting the bulb into the locked position.
Sedan Revolution #34 -/- NW Posse #14
Death Site DSI is offline
Old 04-21-2014, 09:10 PM   #144
Miztaken1312
Fan#: 74993
Are you using Halogens or HIDs? I've had HIDs in them for the entire time they've been on my car, with the exception of 3 days (the HIDs were late getting to me). I've never had anything melt on me. I do have to replace a connector on part of the HID harness since it's 4 years old and was crud to begin with and now makes intermittent connections.
Old 04-22-2014, 01:59 AM   #145
blade08
blade08's Avatar
Fan#: 104798
What I Drive: 2008 Silver Focus SE Sedan
Points 273, Level 5
Points: 273, Level: 5 Points: 273, Level: 5 Points: 273, Level: 5
Level Up 46% Completed
FF Reputation: 1 blade08 Good Standing Member
Any idea if the socket that the halos and LEDs plug into could go bad and only make one set of LEDs turn on? (In a single headlight, other one works fine)
blade08 is offline
Old 04-22-2014, 05:39 AM   #146
Miztaken1312
Fan#: 74993
Doesn't sound like a socket issue. I take it the halo works fine still?
Old 04-22-2014, 02:02 PM   #147
iamwreckless
Fan#: 114929
I had 2 halogens burn up as well, i now have HID and have had no problem, but as far as the high beams go, the driver side malfunctions, when i turn the brights on, and then go to turn them off, the driver side will stay on high beam, i have to turn them on and off a few times for it to go back to low beam. The peace that moves inside that controls the light output for the low/high beams is not working properly.
LIKE A BOSS :D
Old 04-22-2014, 02:11 PM   #148
blade08
blade08's Avatar
Fan#: 104798
Points 273, Level 5
Yeah halos work fine. Swapped out the inverters and same thing.
blade08 is offline
Old 04-22-2014, 02:45 PM   #149
Miztaken1312
Fan#: 74993
Mine work just fine. They never get stuck. The halogens suck in these housings. Not enough heat dissipation at all. The HIDs run cooler and therefore don't burn and melt anything.
I believe you could have an internal issue with the LEDs then. I don't know how long you've had your lights but you could always try an RMA with them. Even if you contact them through eBay you won't have any issue. I did that for my tail lights from them when I had several LEDs out. You will have to put down a deposit if you don't have your OEM housing still, and they will refund it minus the cost of shipping.
Old 04-22-2014, 03:03 PM   #150
blade08
blade08's Avatar
Fan#: 104798
Points 273, Level 5
I was hoping that wasn't it but 80% sure you're right.
The led will come on randomly but it hasn't happened in a while. I got these off someone on her about a year ago! :/
blade08 is offline
Similar Threads
2008 Halo Projectors fishissexy MK2 Focus 27 05-25-2009 04:28 PM
MBRP Install...and how to 05yellowd20 DURATEC Performance (2003-2007) 25 05-13-2009 12:53 AM
Marathon: Life After Halo dazada Gaming Fanatics 0 11-20-2007 07:46 PM
how hard are these to install? ebay halo projectors. 1sloho MK1 Focus 10 11-26-2006 09:01 AM
how much for install of jrsc and a clutch? R00ST650 General Forced Induction 3 10-12-2006 01:56 PM
