How To figure the compression ratio of your Zetec - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 05-19-2009, 03:32 AM   #1
iminhell
C2H5OH
iminhell's Avatar
Fan#: 36222
Points 18,868, Level 87
Points: 18,868, Level: 87 Points: 18,868, Level: 87 Points: 18,868, Level: 87
Level Up 4% Completed
Forum Activity 13%
Buy-Sell-Trade Rating: (4)
I always have trouble trying to find this info and I'm not the best with wanting to do the math. I found a good write up on a different site that I'm working off to give us good info. Here goes ...
The advertised static compression ratio for the US spec Zetec is 9.6:1, note the US spec and that we are not talking about the SVT version of the engine.
Typically to find the compression ratio you'd use this formula: but we don't know all the required information to make that formula work so we'll have to work it backwards. (we don't know the combustion chamber volume)
b = cylinder bore (diameter)
s = piston stroke length
Vc = volume of the combustion chamber (including head gasket)
We know the total engine volume is 1998 Cubic Centimeters but we only need the volume of one cylinder to complete the formula. So we divide 1998 by 4, 1998 / 4 = 499.5 Cubic Centimeters.
Now to find the Combustion Chamber volume simply divide the total chamber volume by the compression ratio, 499.5 / 9.6 = 52.03125 Cubic Centimeters.
Now remember this is a total chamber volume. That is with any relief in the piston and including the head gasket. We can remove the volume of the head gasket because we know what it is.
The standard US spec head gasket thickness for the Zetec is 0.6858 mm thick with a bore of (about) 84.8 mm. That means using the formula for the volume of a cylinder we can figure the volume and eliminate it.
Pi (3.14159 for all practicality) times the radius (half the diameter of 84.8 or 42.4 mm) squared times the height (which is our 0.6858 mm).
3.14159 X 4.24^2 X 0.06858 = 3.873281546 cubic centimeters
Now we can subtract our head gasket volume from our total volume and are left with the cylinder head volume (roughly), 52.03125 - 3.873281546 = 48.157968454 cubic centimeters.
Now lets run through the SVT version for kicks.
The SVT has a static compression ratio of 10.2:1 and uses a head gasket that is 1.0414 millimeters thick,
1998 / 4 = 499.5
499.5 / 10.2 = 48.970588235
3.14159 X 4.24^2 X 0.10414 = 5.8262884378
48.970588235 - 5.8262884378 = 43.144299798
So now we've found out where the extra compression for the SVT comes from. Now it's time to play with some more numbers and make a chart for gasket swapping and milling the head, but remember these are merely approximations and may not be actual, use caution.
Standard Zetec Raise Compression:
shaving the head (in cm),
standard head gasket (.027" or 0.6858mm)
0.0254 --- 50.596702491 --- 9.872184854
0.0508 --- 49.162154982 --- 10.16025437
0.0762 --- 47.727607473 --- 10.465640883
0.1016 --- 46.293059964 --- 10.789954269
0.1270 --- 44.858512455 --- 11.135010339
SVT Head Raise Compression:
standard SVT head gasket (.041" or 1.0414mm),
0.0254 --- 47.536040727 --- 10.507816645
0.0508 --- 46.101493218 --- 10.834790050
0.0762 --- 44.666945709 --- 11.182765960
0.1016 --- 43.232398200 --- 11.553835105
0.1270 --- 41.797850691 --- 11.950375240
with just using the .027" (standard Zetec) head gasket
0.06858 --- 47.017581344 --- 10.62368556
with Zetec head gasket (.027" or 0.6858mm)
0.0254 --- 45.583033835 --- 10.958024466
0.0508 --- 44.148486326 --- 11.314091186
0.0762 --- 42.713938817 --- 11.694074905
0.1016 --- 41.279391308 --- 12.100469124
0.1270 --- 39.844843799 --- 12.536126444
*Please be advised these are only approximations*
I figured the compression ratios by taking the displacement divided by 4 divided by the chamber size. Not sure if that is correct but I'd guess it will get you close.
Also being no one has ever CC'd the head while shaving it everything is just a guess.
Open to criticism and/ or a better chart/method.
121,000 members and still no sponsored racing.
iminhell is offline
Old 05-19-2009, 10:07 AM   #2
Fordcus Fan
Fan#: 31604
What I Drive: Blue 2014 twin turbo F150 Limited
Points 674, Level 13
Points: 674, Level: 13 Points: 674, Level: 13 Points: 674, Level: 13
Level Up 48% Completed
Level up: 48% Level up: 48% Level up: 48%
FF Reputation: 3 Fordcus Fan Good Standing Member
Buy-Sell-Trade Rating: (11)
Even though its a approximation, I need some kind of ideal of my compression ratio in my Zetec built short block w/ 9:1 pistons, SVT head. Nice work.
I don't need training wheels.
(AWD,Traction control,Stability control,Launch assist,Autotrans,Paddle shifters). Got my driving skills driving front/rear wheel drive high performance cars on the street for the last 40 years.
Fordcus Fan is offline
Old 05-19-2009, 03:05 PM   #3
mlbbaseball
Shot me 3 deer!!!
mlbbaseball's Avatar
Fan#: 53541
What I Drive: 02 SVT, 2 7.3 L Diesel Excursions!
Points 28,017, Level 98
Points: 28,017, Level: 98 Points: 28,017, Level: 98 Points: 28,017, Level: 98
Level Up 67% Completed
Forum Activity 3%
FF Reputation: 42 mlbbaseball Great Standing Member
Buy-Sell-Trade Rating: (69)
great info!!!, but i'm not sure its totally right, only reason is i was told my compression was 10.7:1 on a head shaved .060". Not saying ur wrong by any means, more than likely, my tuner is wrong, but it seems logical!
Now I rive 2 7.3 L diesel trucks!
mlbbaseball is online now
Old 05-19-2009, 11:14 PM   #4
aheroicrevolt
le kittens meow
aheroicrevolt's Avatar
Fan#: 57964
What I Drive: 92 Burnt Orange Toyota Supra
Points 8,689, Level 62
Points: 8,689, Level: 62 Points: 8,689, Level: 62 Points: 8,689, Level: 62
Level Up 80% Completed
Forum Activity 2%
FF Reputation: 2 aheroicrevolt Good Standing Member
Buy-Sell-Trade Rating: (15)
Looking for: T4 57trim or larger Turbo, Wideband Gauge with wiring and sensor, HKS VPC with 550 chip
aheroicrevolt is offline
Old 05-20-2009, 12:10 AM   #5
03OrangeSVT
LETS TURN DIRT!!!!
03OrangeSVT's Avatar
Fan#: 19169
What I Drive: MINI Cooper S TURBO
FF Reputation: 152 03OrangeSVT Excellent Standing Member 03OrangeSVT Excellent Standing Member
The biggest factor here is the size of the combustion chamber... the SVT has a smaller CC and thats why it has a higher CR.
[B]1951 McCormick FARMALL M
2007 MINI Cooper S Turbo... new project car
1998 Chevy 3500 Ext cab, long bed, 4x4, duelly, turbo diesel
2004 Harley V-Rod.... sex on wheels
2011 Harley Electra Glide Ultra Limited
[/b]
03OrangeSVT is offline
Old 05-20-2009, 08:30 AM   #6
1turbofocus
FF Affiliate
1turbofocus's Avatar
Fan#: 1123
Points 52,537, Level 100
Points: 52,537, Level: 100 Points: 52,537, Level: 100 Points: 52,537, Level: 100
Level Up 0% Completed
Forum Activity 55%
Buy-Sell-Trade Rating: (28)
Im curious if that math would work the same once pistons , deck height , valve job is done etc , I would think you would need to know CC`s of head , CC`s of deck height , CC`s of pistons
Customer Support
AIM: hpdyno
Email: hpdyno@aol.com
Phone: 704-249-3745
Site: focus-power.com
Elder 1turbofocus
1turbofocus is offline
Old 05-20-2009, 04:19 PM   #7
iminhell
C2H5OH
iminhell's Avatar
Fan#: 36222
Forum Activity 13%
^^You would. From the way these numbers are figured all we know is the total combustion chamber volume, that is head, head gasket and piston dish volume combined. If you'd CC the head you could eliminate it and would be left with the volume of the piston alone. Then and only then you could figure in actual compression from a piston change.
BTW, that Performance Hookup vendor has CC specs for all the pistons listed on their site.
iminhell is offline
Old 05-20-2009, 06:51 PM   #8
illinipo
Token Engin-nerd
illinipo's Avatar
Fan#: 37693
What I Drive: dirty wag; Party; Bavarian phallus
FF Reputation: 272 illinipo Outstanding Standing Member illinipo Outstanding Standing Member illinipo Outstanding Standing Member
Buy-Sell-Trade Rating: (19)
looks good, but it looks like some of your numbers in mm are actually in cm. .040" is about 1.016mm. not 0.1016mm.
Originally Posted by Dennis_Grant
Remember this list: Bilstein; Penske; Koni; Ohlins; Sachs; Dynamic Suspension.
Not on this list? Almost certainly crap.
SUV this!
illinipo is offline
Old 05-21-2009, 05:10 PM   #9
iminhell
C2H5OH
iminhell's Avatar
Fan#: 36222
Forum Activity 13%
^balancing equations. Kicked my arse when I was doing the math and nothing would come out right.
iminhell is offline
Old 05-21-2009, 07:16 PM   #10
mlbbaseball
Shot me 3 deer!!!
Fan#: 53541
Forum Activity 3%
I would edit it and make it sticky status!!!! very good info!!!
Similar Threads
zetec turbo comp ratio??? rst-g Drag Racing 3 12-23-2008 01:39 PM
Zetec engine guide. dlh98370 ZETEC Performance (2000-2004) 7 10-16-2008 12:58 AM
TRB 04-08-01 Flywheel Issue bfocused SVT Performance (2002-2004) 9 05-16-2004 05:27 PM
compression ratio foxhound81 General Technical Chat 19 04-13-2004 11:17 AM
Zetec compression rules of thumb johncg ZETEC Performance (2000-2004) 3 02-18-2004 11:39 AM
