HOW-TO Replacing Rear Upper Camber Arms, and camber bolts. - Page 4 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 02-17-2013, 02:29 PM   #31
forddorf
Fan#: 31248
What I Drive: 2001 malibu blue zx3 / turbo-2004
Points 919, Level 16
Points: 919, Level: 16 Points: 919, Level: 16 Points: 919, Level: 16
Level Up 19% Completed
FF Reputation: 3 forddorf Good Standing Member
Sure, why don't you use the adjustable arms to take out some of the camber. You don't need an alignment for adjusting camber. You can use a framing square as a guide to match each side or just go by eye.
forddorf is offline
Old 02-17-2013, 02:38 PM   #32
RAF_S197
RAF_S197's Avatar
Fan#: 91991
What I Drive: 2014 Oxford white Sport Black Pack
Points 7,541, Level 57
Points: 7,541, Level: 57 Points: 7,541, Level: 57 Points: 7,541, Level: 57
Level Up 96% Completed
Forum Activity 15%
Activity: 15% Activity: 15% Activity: 15%
FF Reputation: 21 RAF_S197 Great Standing Member
I was thinking that but to be honest I don't know how to adjust them. I just lined up the new control arms to the stock ones before installing them
2014 Oxford white Focus SE Sport Black pack
Instagram: 5_POINTOH
RAF_S197 is online now
Old 02-20-2013, 09:43 AM   #33
JBotone
JBotone's Avatar
Fan#: 78479
What I Drive: 2003 Pitch Black SVT 5 door
Points 1,176, Level 18
Points: 1,176, Level: 18 Points: 1,176, Level: 18 Points: 1,176, Level: 18
Level Up 76% Completed
Level up: 76% Level up: 76% Level up: 76%
FF Reputation: 1 JBotone Good Standing Member
[QUOTE=RAF_S197;4593011]I just I stalled my SPC adjustable control arms. I can see the passenger side camber is majorly off. Am I ok to drive it for a day before getting a chance to have an alignment done?
Other than tire wear?[/QUOT
My camber was WAY out after the install...like -4.2 and it was fine taking it to the shop the next day.
2003 Pitch Black SVTF, K&N Drop in, CFM dog bone. 155,000 miles. **SOLD**
2001 Sentra SE 2.0 w/JWT Pop Charger. RETIRED with 511,000miles.
2008 Setra SE-R Spec-V 187whp. 167 lb. ft.
JBotone is offline
Old 02-20-2013, 09:58 AM   #34
RAF_S197
RAF_S197's Avatar
Fan#: 91991
Forum Activity 15%
[QUOTE=JBotone;4598158]
I ended up taking the one bolt off again and adjusted the camber arm before going for an alignment. I ended up being really close with -0.6 camber.
Also I'd like to ad that this how to is wrong if you are not installing camber bolts. I learned that the hard way
Old 06-20-2013, 06:19 PM   #35
Mrfarmer
Fan#: 115960
What I Drive: 2004 panther black mk1
FF Reputation: 1 Mrfarmer Good Standing Member
Little bit confused here. I have been told that if I want adjustable camber then I need to drop out the sub frame to change the upper bolt. Is this true or can it be done easier that that. ? Thanks.
Mrfarmer is offline
Old 06-20-2013, 06:51 PM   #36
rambleon84
So mote be it
rambleon84's Avatar
Fan#: 51521
Points 7,752, Level 59
Points: 7,752, Level: 59 Points: 7,752, Level: 59 Points: 7,752, Level: 59
Level Up 1% Completed
Level up: 1% Level up: 1% Level up: 1%
Forum Activity 19%
FF Reputation: 23 rambleon84 Great Standing Member
Buy-Sell-Trade Rating: (15)
just need an extension for your wrench. Upper bolt on my rear camber arm wasn't too hard
rambleon84 is online now
Old 06-21-2013, 03:51 AM   #37
Mrfarmer
Fan#: 115960
Ok thanks. So as long as the bolt comes out ok things shouldn't be to hard.
Mrfarmer is offline
Old 06-21-2013, 08:36 AM   #38
rambleon84
So mote be it
rambleon84's Avatar
Fan#: 51521
Forum Activity 19%
Right, I doubt you see as much road salt as I have either so the camber arm bolts shouldnt be much of an issue, just need some elbow grease to get those out. Dont ask me about the bolts on the rear toe arms though, those were the devil.
Old 06-21-2013, 08:49 AM   #39
Mrfarmer
Fan#: 115960
Yh. Well hope I haven't. I will bear that in mind when I take it apart. Thanks for the help.
Mrfarmer is offline
Old 09-08-2013, 01:59 PM   #40
FordNLNR
Fan#: 96745
What I Drive: '03 Comp Orange SVT / '03 ZTW
Points 263, Level 5
Points: 263, Level: 5 Points: 263, Level: 5 Points: 263, Level: 5
Level Up 26% Completed
FF Reputation: 2 FordNLNR Good Standing Member
Originally Posted by SkyPilot View Post
Now make your new adjustable arms the same length as the stock, makes sure BOTH nuts are fully screwed into the arm, then twist the big nut to adjust the length, once it is at the desired length twist the small nut back town to the big one.
Hmm, that's either some bad instructions or they've changed the design... The larger nut is a hollow collar and the eye-ended portion threads through it with reverse threads. You can loosen the allen-headed pinch bolt and adjust the arm on-the-car by turning the large nut/collar without unfastening anything.
FordNLNR is online now
Tags
alignment , back alighnment , back suspesion , camber , camber bolts , rear alignment , rear suspension , rear tires , suspension
Similar Threads
HTP Adjustable Rear Suspension - Toe Arms HTPerformance Ford Focus & General Car Chat 20 07-09-2009 06:31 PM
FS; SVT Rear Upper Camber Arms darkstarmotorsports Archive 1 05-06-2009 11:01 AM
Do I need adjustable control arms or will camber bolts be enough? ElNotto Brakes, Suspension & Body Chassis 7 10-15-2008 12:07 PM
Focus Rear Tire Wear - Camber Bolts or Control Arms? 2003focusowner Brakes, Suspension & Body Chassis 8 04-05-2008 06:32 PM
Post Up! Did you need camber plates / rear camber bolts? DFv2 Brakes, Suspension & Body Chassis 1 06-10-2007 03:08 PM
