HOW-TO Replacing Rear Upper Camber Arms, and camber bolts. - Page 3 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 05-12-2011, 11:33 PM   #21
JBotone
JBotone's Avatar
Fan#: 78479
What I Drive: 2003 Pitch Black SVT 5 door
Points 1,176, Level 18
Points: 1,176, Level: 18 Points: 1,176, Level: 18 Points: 1,176, Level: 18
Level Up 76% Completed
Level up: 76% Level up: 76% Level up: 76%
FF Reputation: 1 JBotone Good Standing Member
Originally Posted by NX_Focus View Post
did you ask for spc for a focus or volvo or mazda? what part number? i went for the bolts but would like them arms
I ordered them for the Focus over the phone, but I looked them up on their website first.
Part # 67420
They are $103, but I'm going to see if they have any room to move when I go pick them up tomorrow.
2003 Pitch Black SVTF, K&N Drop in, CFM dog bone. 155,000 miles. **SOLD**
2001 Sentra SE 2.0 w/JWT Pop Charger. RETIRED with 511,000miles.
2008 Setra SE-R Spec-V 187whp. 167 lb. ft.
JBotone is offline
Old 05-12-2011, 11:36 PM   #22
JBotone
JBotone's Avatar
Fan#: 78479
Originally Posted by Djzx3 View Post
Okay well my biggest question so far, and possibly the most important..... Is the bolt on the other side of the camber arm have a welded nut too?
Other side of the camber arm? Are you talking about the upper bolts? I am not sure. I would hope so, because putting a wrench on the back side nut would be a real pain. The originator of this thread, just used an impact, so I'm guessing he did not need a second wrench, and that it's probably welded.
JBotone is offline
Old 05-13-2011, 12:14 AM   #23
Djzx3
WRX/Focus:)
Djzx3's Avatar
Fan#: 76864
What I Drive: 04 WRB WRX / 00 se zxw
Points 14,826, Level 78
Points: 14,826, Level: 78 Points: 14,826, Level: 78 Points: 14,826, Level: 78
Level Up 94% Completed
FF Reputation: 33 Djzx3 Great Standing Member
Buy-Sell-Trade Rating: (6)
So then if it is welded, do you grind it off?
Or will the new bolt be a exact fit to the old nut?
2000 SE wagon 2.0l Zetec.
HN #17
D23 crew-#1
Djzx3 is offline
Old 05-14-2011, 10:59 PM   #24
JBotone
JBotone's Avatar
Fan#: 78479
I have the camber arms being put on by a shop now, I could not take the risk of the upper bolts breaking like the lowers. I'll let you know if they are welded when I get it back. If you're taking lose the upper bolts to put on new camber arms, you'll use the old bolts to bolt it back up.
JBotone is offline
Old 05-14-2011, 11:26 PM   #25
Djzx3
WRX/Focus:)
Djzx3's Avatar
Fan#: 76864
I got it all put back together now with new bolts and nuts, but I'm going to give in and let the shop do the camber bolt, I got two camber bolts, but my air gun is not strong enough. But it looks nice, and I just got the front struts off with no big problems.
Two new lower control arms, new bolts and nuts for both ends of the control arms, which where dunked in anti seize. The inside of the bushings where coated too, everything but the threads.
HN #17
D23 crew-#1
Djzx3 is offline
Old 05-16-2011, 11:53 AM   #26
ChrisRobin
ChrisRobin's Avatar
Fan#: 46204
What I Drive: 04 silver SVT Focus
Points 6,802, Level 54
Points: 6,802, Level: 54 Points: 6,802, Level: 54 Points: 6,802, Level: 54
Level Up 26% Completed
FF Reputation: 4 ChrisRobin Good Standing Member
Good point about leaving the camber bolts in.... allows for fine-tuning without having to take apart half the camber arms to adjust.
Originally Posted by WRCwannabe View Post
...and then slap a supercharger on it and rape their tits off.
ChrisRobin is online now
Old 05-16-2011, 07:50 PM   #27
JBotone
JBotone's Avatar
Fan#: 78479
Just got my Focus back from the shop. It took the 2 hours to get the lower bolts out of the camber arms...WOW! They were rusted in something fierce. Then to get the upper bolts out the sub frame had to be dropped...They said the bolts were in backwards, definitely not the normal process. Anyways it's done, and I'm getting the alignment tomorrow with my new super adjustable rear camber.
JBotone is offline
Old 11-16-2012, 06:36 PM   #28
gondorian
gondorian's Avatar
Fan#: 105695
What I Drive: 2002 wgn (Selling) 2004 2.3 wgn 5sp
Points 1,547, Level 22
Points: 1,547, Level: 22 Points: 1,547, Level: 22 Points: 1,547, Level: 22
Level Up 47% Completed
FF Reputation: 7 gondorian Good Standing Member
Djzx3,
What bolts did you use for the outer part of your lower control arms? Did you get them from Ford or are they aftermarket?
Thanks
gondorian is offline
Old 11-17-2012, 02:25 AM   #29
JBotone
JBotone's Avatar
Fan#: 78479
I used the SPC camber bolts, which is what I was originally going to use to adjust the camber until the factory bolts broke due to rust, and didn't want to go buy more bolts. So I had super adjustable camber..lol
JBotone is offline
Old 02-17-2013, 02:15 PM   #30
RAF_S197
RAF_S197's Avatar
Fan#: 91991
What I Drive: 2014 Oxford white Sport Black Pack
Points 7,594, Level 58
Points: 7,594, Level: 58 Points: 7,594, Level: 58 Points: 7,594, Level: 58
Level Up 22% Completed
Forum Activity 17%
Activity: 17% Activity: 17% Activity: 17%
FF Reputation: 21 RAF_S197 Great Standing Member
Buy-Sell-Trade Rating: (4)
I just I stalled my SPC adjustable control arms. I can see the passenger side camber is majorly off. Am I ok to drive it for a day before getting a chance to have an alignment done?
Other than tire wear?
2014 Oxford white Focus SE Sport Black pack
Instagram: 5_POINTOH
RAF_S197 is offline
Tags
alignment , back alighnment , back suspesion , camber , camber bolts , rear alignment , rear suspension , rear tires , suspension
Similar Threads
HTP Adjustable Rear Suspension - Toe Arms HTPerformance Ford Focus & General Car Chat 20 07-09-2009 06:31 PM
FS; SVT Rear Upper Camber Arms darkstarmotorsports Archive 1 05-06-2009 11:01 AM
Do I need adjustable control arms or will camber bolts be enough? ElNotto Brakes, Suspension & Body Chassis 7 10-15-2008 12:07 PM
Focus Rear Tire Wear - Camber Bolts or Control Arms? 2003focusowner Brakes, Suspension & Body Chassis 8 04-05-2008 06:32 PM
Post Up! Did you need camber plates / rear camber bolts? DFv2 Brakes, Suspension & Body Chassis 1 06-10-2007 03:08 PM
