Nitrous: FI or NA? - Focus Fanatics
Go Back   Focus Fanatics > Ford Focus Discussions > Ford Focus & General Car Chat
View Poll Results: Do you think nitrous falls under FI or NA?
FI 31 68.89%
NA 14 31.11%
Voters: 45. You may not vote on this poll
Old 05-13-2009, 07:45 PM   #1
SMITHBOY76908
Boost Junkie!
SMITHBOY76908's Avatar
Fan#: 56301
What I Drive: 2007 Turbo ZX3
FF Reputation: 18 SMITHBOY76908 Great Standing Member
Buy-Sell-Trade Rating: (4)
Nitrous: FI or NA?
The debate came up in the duratec performance chat. Do you think Nitrous Oxide falls under FI or NA?
Badger! Badger! Badger! Badger! Badger! Badger! Badger! Badger! Badger! Badger! Badger! Badger!
MUSHROOM! MUSHROOM!
SMITHBOY76908 is offline
Old 05-13-2009, 07:56 PM   #2
Schroeder02
Moderator
Schroeder02's Avatar
Fan#: 53191
What I Drive: 2013 Red ST & 2009 Focus Race Car
FF Reputation: 62 Schroeder02 Excellent Standing Member
Buy-Sell-Trade Rating: (7)
I was going to say more NA but by the definition I’m going with FI
Nitrous oxide is made up of 2 parts nitrogen and one part oxygen (36% oxygen by weight). During the combustion process in an engine, at about 572 degrees F., nitrous breaks down and releases oxygen. This extra oxygen creates additional power by allowing more fuel to be burned. Nitrogen acts to buffer, or dampen the increased cylinder pressures helping to control the combustion process. Nitrous also has a tremendous "intercooling" effect by reducing intake charge temperatures by 60 to 75 degrees F.
My rides a 2002 SVT track car, & Boosted 2007 ST with the SAP.
The helmet has a special meaning for many drivers. How important is it to you? - It protects my head.
Do you have any special rituals when the helmet is concerned like many have? - I wipe it so that I can see better.
Schroeder02 is offline
Old 05-13-2009, 08:00 PM   #3
SMITHBOY76908
Boost Junkie!
Fan#: 56301
Actually, I guess it would depend on whether it's a wet shot or dry shot. Nice definition Brian.
MUSHROOM! MUSHROOM!
Old 05-13-2009, 08:25 PM   #4
iminhell
C2H5OH
iminhell's Avatar
Fan#: 36222
FF Reputation: 48 iminhell Great Standing Member
Wet or dry doesn't matter. If it is Oxygen added to the system that the motor can not naturally pull in, it's FI.
Don't "think outside the box".
There is no box.
Do it correct, or do it twice.
iminhell is offline
Old 05-13-2009, 08:25 PM   #5
jetrinka
jetrinka's Avatar
Fan#: 45622
What I Drive: 88 5-speed XR4TI
FF Reputation: 180 jetrinka Excellent Standing Memberjetrinka Excellent Standing Member
Buy-Sell-Trade Rating: (6)
It may allow more fuel to be burned but you aren't "forcing" anything more into each cylinder. The motor is still only sucking in a max of the surrounding atmopsheric pressure whereas in a true FI setup (turbo or supercharger) you are forcing additional volume above atmospheric pressure into each cylinder. This is why its called forced induction because you are forcing more air in. NA volumetric efficiency can vary going from car to car as some heads will flow a bit better, or a set of cams will allow for a bit more valve overlap than others. This doesn't change with nitrous, you are just allowing more fuel to be burned within the cylinders which does increase cylinder pressures, but does not in eccence stuff anything more into the cylinders.
jetrinka is offline
Old 05-13-2009, 10:56 PM   #6
blackoutSVT
Lurking
blackoutSVT's Avatar
Fan#: 52102
What I Drive: 86 sportster1100, 12 Focus SE Sedan
FF Reputation: 9 blackoutSVT Good Standing Member
Buy-Sell-Trade Rating: (15)
nitrous falls under the FI category. it doesn't matter if you have a wet or dry kit on it, it is the same dam thing.. think of it as a bottle turbo....
Originally Posted by Nytryder View Post
I've no doubt that the Marquise de Sade is alive and well and is designing Focus seats.
blackoutSVT is offline
Old 05-13-2009, 11:23 PM   #7
turboguy327
Fan#: 55065
What I Drive: 2002 Sonic Blue SVT Focus
FF Reputation: -1 turboguy327 Poor Behavior Needs Improvement
Nitrous is FI. Go racing in a NA class on the bottle and see what happens
#2194 out of 4788. Born on May 16th 2002
turboguy327 is offline
Old 05-13-2009, 11:32 PM   #8
jetrinka
jetrinka's Avatar
Fan#: 45622
It may put you in another class but that doesn't mean in any way it is technically a forced induction application. With an NA application you are relying purely on the pressure differentials beween the cylinder and the outside atmosphere to fill the cylinder. Why do you think the same car will make slightly less power in the mountains of Colorado than it would in Seattle at sea level? NA with nitrous involved relys on exactly the same principle of pressure differentials. You are just adding something to the mix which allows more fuel to be burned and thus more power. You aren't "forcing" anything extra in there. The cylinder will still only accept the same amount of (for lack of a better term) stuff and you cannot change that without some sort of mechanical advantage such as a turbo or a supercharger.
jetrinka is offline
Old 05-13-2009, 11:49 PM   #9
iminhell
C2H5OH
iminhell's Avatar
Fan#: 36222
... or a chemical additive that contains more Oxygen that the intake air. Atmospheric pressure can only put X grams of O2 into the chamber, NO2 adds Y to the already X mixture. So anything atmospheric pressure can not put into the cylinder is forced induction IMO.
There is no box.
iminhell is offline
Old 05-14-2009, 12:08 AM   #10
SMITHBOY76908
Boost Junkie!
Fan#: 56301
I agree, when you push on that button (whether it's behind the pedal or on the wheel) you're "forcing" something other than the naturally aspirated air into the engine. Therefore, IMO it's classified as FI.
MUSHROOM! MUSHROOM!
Similar Threads
Nitrous Questions..read here first. viney266 General Forced Induction 396 06-28-2012 11:26 PM
For Sale: Full Zex wet nitrous setup netdrgoon Archive 0 05-08-2007 01:42 PM
For Sale: Nitrous stuff... CHEAP** flake_silver_zx3 Archive 4 04-29-2005 10:08 AM
