#31 | ||||
To know if you have it, it should say "Job #2" on the window sticker. |
#32 | ||||
Hey Walmart has a kit for the '09 Focus for temperature AND compass! Really cheap, too!
Linky to compass Linky to thermometer, with indiglo backlight mount kit sold only in stores, not online Hope this helps p.s. sorry
"It isn't what you drive that matters, it's how you drive it" - Jeremy Clarkson, Top Gear Ford: Taurus ('91, 01) Focus ('09); Mercury: Sable ('95); Dodge: Neon ('95); Trek: 1000SL ('07) Yamaha: VStar 650 ('03) |
#33 | ||||
King of all blacks!!
(post PDI) |
#34 | ||||
It's on the window sticker. On the right hand side where it lists all the options. If it's a Job #1, there is nothing there. It will only show up if it's Job #2. If you don't have the trunk release, you don't have a Job #2. |
#35 | ||||
My SES has the trunk release and outside temperature gage, but I don't see the Job #2 on the window sticker I'm holding. Build date 02-09
2009 Focus SES, Vista Blue, ABS/ESC, Moon & Tune |
#36 | ||||
Like before, if it has the trunk release button, it's a Job#2. My buddy at the assembly plant says they started running them sometime around the end of January, beginning of February. |
#37 | ||||
You can add a trunk button by splicing into the light blue wire and a 12 volt power source. You can find the blue wire in the harness that is pictured above. (the one that has the plastic lever.
#38 | ||||
Some of the pictures are dead - where can the LB wire be found?
2008 SE Coupe MTX 2000 Contour SVT 3L MSDS Headers/Weapon-R Y-pipe Torsen T-2/Clutchnet Stage 3 Fidanza 8lb 131 of 2150 |
#39 | ||||
Just left of the fuse panel. I believe its the only plug that has a release on it. If you supply 12 volts to the light blue wire it will release your trunk latch. I've not tested it to see if it will release while transmission is in drive.
| Thread Tools | |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Trunk release button doesn't work | focusonthis420 | General Technical Chat | 29 | 11-25-2012 02:21 PM |
| New trunk release button | Phokus | General Technical Chat | 13 | 03-18-2009 02:58 PM |
| Trunk release button issues | FreightTrain | General Technical Chat | 6 | 09-08-2008 11:23 PM |
| Trunk Button on 2008 model | molson19 | Canadian Fanatics | 5 | 06-03-2008 01:54 PM |
| Automatic, Lexus style push button starter w/schematic | WuNgUnSVT | Car Audio, SYNC, MyFord Touch & Electronics | 11 | 12-02-2006 02:19 AM |
