Replacing a timing belt without screwing up....How-to. - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 05-12-2009, 07:50 AM   #1
bluefront
bluefront's Avatar
Fan#: 56816
What I Drive: 2006 white ZX5 SES
FF Reputation: 146 bluefront Excellent Standing Member bluefront Excellent Standing Member
Buy-Sell-Trade Rating: (6)
I got to see the inside of a Zetec timing cover yesterday. And I can see how easy it is to mess up the job, even using the factory tools (a cam bar and a crank location pin). Here's the problem if the engine has a VTC sprocket......when you remove the belt, even with the factory tools in place, the pulley with the VTC sprocket can move. So when you replace the belt.....you can be off a tooth or more.
Here's how to avoid that issue......before you remove the belt, mark the old belt and the cam sprockets, and the lower sprocket with paint marks (six marks)....like this picture stolen from another problem post,
After you remove the old belt with the paint marks, hold it next to the new belt, and mark the new belt with paint marks in the same place on the same teeth......be careful. Count the teeth between marks to be sure,
Now when you install the new belt, you will be back in the correct timing......no guess-work on the teeth. In fact.....using this method, you don't even need the factory tools, and you don't need to remove the valve cover. Other cars with timing belts use this same marking method.....marks on the sprockets, and marks on the replacement belt.
Timing belt replacement is critical......don't screw up by getting it off a few teeth. You'll get a CEL until you get the timing correct. Mark the belt/sprockets, before you take the belt off.
To get the belt off, loosen the idler tension pulley to get enough free play. That's the pulley toward the back of the engine between the upper VTC sprocket, and the lower sprocket. You shouldn't have to loosen the bolts on the cam sprockets at all.
I'll keep my guns, my freedom, and my money.....you can keep the "change".
bluefront is offline
Old 05-12-2009, 08:10 AM   #2
Own2Focus
Own2Focus's Avatar
Fan#: 64418
What I Drive: 05 ZX4 ST and 05 ZX4 SE
FF Reputation: 1 Own2Focus Good Standing Member
This is a great tutorial! Can we get a sticky on this?
Own2Focus is offline
Old 05-12-2009, 10:47 AM   #3
Missourileo
Captain Retard
Missourileo's Avatar
Fan#: 55980
What I Drive: 2002 Black SVT ZX3,93 SVT Lightning
Points 5,291, Level 46
Points: 5,291, Level: 46 Points: 5,291, Level: 46 Points: 5,291, Level: 46
Level Up 71% Completed
Level up: 71% Level up: 71% Level up: 71%
FF Reputation: 20 Missourileo Great Standing Member
Buy-Sell-Trade Rating: (17)
Ummmmm.....Yeah. if that's the case, then why didn't we do that and make it work?
"It's the Veteran who salutes the flag, serves beneath the flag, and whose coffin is draped by the flag."
Midwest crew #36
Hatch Nation#50
January 2010 ROTM
Missourileo is offline
Old 05-12-2009, 10:49 AM   #4
FocusOnU2
FocusOnU2's Avatar
Fan#: 49219
What I Drive: 2004 Sonic Blue SVTF 5dr
Points 932, Level 16
Points: 932, Level: 16 Points: 932, Level: 16 Points: 932, Level: 16
Level Up 32% Completed
FF Reputation: 9 FocusOnU2 Good Standing Member
I was waiting for you to chime in on this......lol
Focusfest 08 winner Best of Show and Shine
04 Sonic Blue SVTF
#141 OF 1079 BORN 10/24/03
Midwest crew #34
FocusOnU2 is offline
Old 05-12-2009, 11:51 AM   #5
MaroonZX3
Fan#: 49579
What I Drive: 2003 Red ZX3
FF Reputation: 12 MaroonZX3 Great Standing Member
I think the key phrase here is "before you remove the belt". Once you lose the timing, then it is much harder to get it back. I'm adding paint marker to my list of tools when I change my belt.
MaroonZX3 is offline
Old 05-12-2009, 12:09 PM   #6
bluefront
bluefront's Avatar
Fan#: 56816
Heh.....once you remove the belt without any marks, you're in deep water.
You can get the crank in the proper position with the factory pin tool. And you can get the cams back in the proper position using the factory cam lock bar. So.....if you put the belt teeth on the lower sprocket and on the front cam sprocket so as the belt is tight across the idler pulley......the front cam is in proper time.
Now for the problem.....the VTC sprocket teeth. Since the pulley moves somewhat independently from that cam, you could and might get the belt on the wrong teeth. I'm not certain how the factory manual explains the correct procedure.....it's probably tough to figure out.
What I'm saying......use the paint mark procedure before you remove the timing belt. And don't loosen up the bolts that attach the pulleys to the cams. You'll be fine this way.....
Old 05-12-2009, 05:51 PM   #7
FocusOnU2
FocusOnU2's Avatar
Fan#: 49219
IDK......if it were that easy you would think thats how the directions would tell you to do it. It sounds easy in theory but what do i know.
04 Sonic Blue SVTF
Midwest crew #34
Old 05-12-2009, 06:18 PM   #8
bluefront
bluefront's Avatar
Fan#: 56816
Well as far as why the manual gives you a more complicated method.....I can't say. If you break a belt, or knock off a few teeth, this paint method won't work. But if the cam timing is correct before a belt swap, if you follow this paint mark method correctly (it's easy).......your cam timing will be exactly the same after the cam belt job.
Just don't loosen the bolts holding the pulleys on the cams.......loosen the idler/tensioner to do the belt swap. Since the thing has no teeth, it doesn't matter if it spins or not.
If you take the belt off without using the Ford tools, both cams will move slightly. But as long as the paint marks are there, doesn't matter. You know exactly where the belt should go. Say the front cam moves a little......to get it to line up with your paint mark on the belt, you can move it with an open end wrench. The paint marks on the cam and belts are critical.
This technique works......period.
Old 05-12-2009, 06:38 PM   #9
Mr.Bergner
coffee, have some
Mr.Bergner's Avatar
Fan#: 32799
What I Drive: 2004 TW Blue ZX3
Points 6,353, Level 52
Points: 6,353, Level: 52 Points: 6,353, Level: 52 Points: 6,353, Level: 52
Level Up 2% Completed
FF Reputation: 53 Mr.Bergner Excellent Standing Member
Buy-Sell-Trade Rating: (12)
Sweet! I love all these tricks and how-to's coming out lately as I'm getting ready to do the belts (pretty nervous) But this I'm definitely going to do. Rep if I haven't already given it yet.
I don't have VCT but even if I don't, would you still recommend this?
2004 ZX3 MTX - Twighlight Blue_____________________________________________________________________________ _ _ _ _ _ _
Mr.Bergner is offline
Old 05-12-2009, 07:10 PM   #10
Missourileo
Captain Retard
Fan#: 55980
P.S. be aware the belt will move as you rotate the assembly..........so your marks will not line up. Yep.........
Midwest crew #36
Hatch Nation#50
January 2010 ROTM
Similar Threads
SPI Timing Belt Change How to untenops SPI Performance (2000-2004) 41 12-05-2013 08:25 PM
Timing Belt Info Spanky6935 General Technical Chat 13 09-30-2011 11:54 PM
timing belt woes cliffy86 General Technical Chat 3 10-18-2008 10:36 AM
Timing belt issues Jetphuel General Technical Chat 11 04-02-2008 03:22 PM
Timing Belt jac0b ZETEC Performance (2000-2004) 2 11-25-2003 05:52 PM
