Timing belt and valve cover gasket questions - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 04-27-2009, 07:04 PM   #1
bringler26
FUBARCUS
bringler26's Avatar
Fan#: 59705
What I Drive: 03 ZX3 & 07 Impreza 2.5i
Points 9,391, Level 65
Points: 9,391, Level: 65 Points: 9,391, Level: 65 Points: 9,391, Level: 65
Level Up 14% Completed
Forum Activity 5%
Hey guys well my car is nearing 90k miles and I was wondering how hard it is to do the timing belt my self Ive not really ever done anything like this before. Also my valve cover gasket has an ultra slow leak. By ultra slow I mean In 5,000 miles I don't even have to add oil to the car cause it never gets to the fill mark. I may have an install day depending on what answers I get from you guys. Thanks for the help.
2007 Subaru Impreza 2.5i - current DD
I always moderate naked!
bringler26 is online now
Old 04-27-2009, 09:18 PM   #2
FociBoi121
FociBoi121's Avatar
Fan#: 53573
What I Drive: 2003 InfraRed ZX3 ATX
FF Reputation: 4 FociBoi121 Good Standing Member
valve cover gasket is fairly easy but make sure you clean the inside of valve cover gasket lining i used a toothpick with bits of paper towel on it and on the head itself i used a terry towel and rubbed the old gasket lining off but dont get debris snagged or attached to the cams and valvetrain
when you tighten up the bolts start from center out
when finished start the car let it warm up check for mainly leaks by the t-stat housing and the side facing you where exhaust manifold is you'll most likely find yourself loosening and tightening till u get it seated (redid mine 3 times)really helps to have a torque wrench if u can find one with settings lower than i think 19-24 ft lbs dont overtighten snapping a bolt in the head is never good
as far as timing belt i hear it can be tricky im not sure i think you'll need this tool that keeps the cams and timing in place someone else step in on this
Current Mods: about me profile
ZETEC Crew #237
HATCHBACK LOVER #121
PS3 ID: LarkBoi189
Slow bolt ons added or bolt ons slowly added?
FociBoi121 is offline
Old 04-27-2009, 09:26 PM   #3
bringler26
FUBARCUS
bringler26's Avatar
Fan#: 59705
Forum Activity 5%
Thank you for the response! I think I know what tool you are referring to.
Old 04-27-2009, 10:49 PM   #4
focusmaniaczx3
I need BOOOOST!!!!!!
focusmaniaczx3's Avatar
Fan#: 55157
What I Drive: zx3 turbo, kia soul, 71 chevy c/10
Points 14,960, Level 79
Points: 14,960, Level: 79 Points: 14,960, Level: 79 Points: 14,960, Level: 79
Level Up 22% Completed
Forum Activity 11%
FF Reputation: 35 focusmaniaczx3 Great Standing Member
Buy-Sell-Trade Rating: (14)
just did a contour valve cover swap on my pile today. valve cover is very easy just make sure you clean everything up really well and make sure its seated well. timing belt im not going there. never done one on a focus with the motor still in the car.
focus-power P&P head $1100
focus-power DIY turbo kit $1495
tom's first time in Vegas? PRICELESS!
Originally Posted by 1turbofocus
I love this big little city HOOTERS !
Every time you drink a beer somewhere an ugly woman becomes beautiful, so get to it!
focusmaniaczx3 is online now
Old 04-28-2009, 01:21 AM   #5
Sarif2029
Sarif2029's Avatar
Fan#: 33430
What I Drive: 2003 Pitch Black SVT #3844
Points 1,757, Level 24
Points: 1,757, Level: 24 Points: 1,757, Level: 24 Points: 1,757, Level: 24
Level Up 57% Completed
Level up: 57% Level up: 57% Level up: 57%
FF Reputation: 7 Sarif2029 Good Standing Member
Buy-Sell-Trade Rating: (8)
ur gona need at least 6 -8 hrs to do the timing belt. I highly recommend removing the PS strut assy but thats just me. You will need to remove the PS wheel well. I also recommend alot of ziplock bags, masking tape and sharpie, b/c of all the bolts. Getting the cam alignment tool from CFM isnt a bad idea either(<<-- GET THIS). While you are doing the timing belt, replace the TB pullies as well i think the set from is 80 from autozone IIRC, and the serpintine belt as well.
There are 3 covers for the TB. The plastic one by the VC, a metal one in the middle, and a lower plastic one. The crank and water pump pullies will have to be removed to get the covers off (lower) and to get to a torx bolt (WP).
Replacing the belt isnt difficult its just time consuming. I'd be happy to discuss it with you or to answer any questions you might have. just shoot me a PM or hit me up on my cell it should be in my profile.
-Sarif2029
2003 Pitch Black SVT 3844 of 3985
RIP: 2000 Red ZX3 Born: Feb, 2000 Died: May 23, 2009
Garage Sale --> http://www.focusfanatics.com/forum/showthread.php?p=3522123#post3522123
Sarif2029 is offline
Old 04-28-2009, 10:16 AM   #6
FociBoi121
FociBoi121's Avatar
Fan#: 53573
yeah also if your valve cover isnt leaking on the sides after replacement go ahead and drive but pull your plug wires evey so often to make sure oil isnt leaking into the seats of your spark plugs
ZETEC Crew #237
PS3 ID: LarkBoi189
Old 04-29-2009, 07:29 PM   #7
guitarseth
Fan#: 7887
What I Drive: 2003 French Blue Metallic ZX3
FF Reputation: 3 guitarseth Good Standing Member
Bring it over and we'll swap it out for you. It'll probably only take a few hours. I've got the Zetec timing gear toolset. Pick up a new belt, timing belt tensioner and idler as well as a valve cover gasket from Hillbish or someone.
Mild NA build - modded for driving enjoyment
guitarseth is offline
Old 04-29-2009, 09:58 PM   #8
bringler26
FUBARCUS
bringler26's Avatar
Fan#: 59705
Forum Activity 5%
that would be great
Similar Threads
The Ultimate 03-09 Focus Thread, SUPER LARGE AMOUNTS OF INFO. honhon DURATEC Performance (2008-2011) 59 08-04-2013 11:41 PM
Timing Belt Info Spanky6935 General Technical Chat 13 09-30-2011 11:54 PM
Timing belt problem matthewsvt General Technical Chat 22 07-16-2007 04:00 PM
General Specs on the 2.0L Duratec b16sir1991 General Technical Chat 0 04-18-2007 11:22 AM
General specs on the SPI b16sir1991 General Technical Chat 0 04-18-2007 11:20 AM
