What class would I be in? - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum > Ford Focus Racing Discussions > Autocross Racing
Autocross Racing The place to discuss information about autocross stats, tips and events. Track sanctioned events only.
Old 04-26-2009, 10:03 PM   #1
ThatOneFocusGuy
ThatOneFocusGuy's Avatar
Fan#: 59087
What I Drive: 13 RR ST3 #5427, 00 Kona Edition
Points 10,739, Level 68
Points: 10,739, Level: 68 Points: 10,739, Level: 68 Points: 10,739, Level: 68
Level Up 73% Completed
Level up: 73% Level up: 73% Level up: 73%
FF Reputation: 7 ThatOneFocusGuy Good Standing Member
Buy-Sell-Trade Rating: (29)
Question What class would I be in?
Dont' really understand what class I would be in . Want to be in ST maxed out. Heres my mods.
-FC intake with SVT snorkle
-Thermal R&D cat-back
-FC header and flex
-SVT 17'' wheels with 215/45 Trazano tires
FocusFactor FocusXtreme
ST Nation Cincy Area
IG @battle_stance_st
ThatOneFocusGuy is offline
Old 04-27-2009, 02:40 AM   #2
Tugboat
Tugboat's Avatar
Fan#: 48933
What I Drive: 2002 CD Silver SVTF
FF Reputation: 2 Tugboat Good Standing Member
If you still have your cat then you would be in ST but if that header deleted it that would put you in FSP i believe.
2002 CD Silver SVT Focus. 165k and counting!
Tugboat is offline
Old 04-27-2009, 11:26 AM   #3
wrc_fan
slow
wrc_fan's Avatar
Fan#: 11913
What I Drive: 03 ZX3 Duratec 08 WRX Hatch
Points 3,584, Level 37
Points: 3,584, Level: 37 Points: 3,584, Level: 37 Points: 3,584, Level: 37
Level Up 56% Completed
FF Reputation: 23 wrc_fan Great Standing Member
If you have a Cat in the OE location:
ST
If you have a aftermarket CAT with 6 inches of the OE location:
STX
If you have no CAT (cats are overrated:P) FSP for you. That's where all the cool Foci aspire to be anyway \/\/
Parking Lot Hero
2008 WRX daily driver
2003 ZX3 23D Autox Car 42 FSP
"Hella Functional - Raced, Not Hard Parked"
wrc_fan is offline
Old 04-27-2009, 09:15 PM   #4
ThatOneFocusGuy
Fan#: 59087
What else can I do to my car to make it better for FSP class? Pulleys? Cam gears? Cams? Anti-roll bars?
Old 04-27-2009, 09:50 PM   #5
steve35svt
steve35svt's Avatar
Fan#: 61033
What I Drive: 2012 Hyundai Genesis Coupe 2.0T
FF Reputation: 4 steve35svt Good Standing Member
Can't touch cams in street prepared.
steve35svt is offline
Old 04-28-2009, 08:11 AM   #6
wrc_fan
slow
wrc_fan's Avatar
Fan#: 11913
Wheels and tires
Parking Lot Hero
wrc_fan is offline
Old 04-28-2009, 01:09 PM   #7
wrc_fan
slow
wrc_fan's Avatar
Fan#: 11913
Also, some local regions may not care that much if you are running without a Cat, but it really depends on region to region.
Parking Lot Hero
wrc_fan is offline
Old 04-28-2009, 09:43 PM   #8
ThatOneFocusGuy
Fan#: 59087
Can someone give me a link to a FSP class restrictions chart of some kind?
Thanks
Old 04-28-2009, 11:57 PM   #9
xShiFTx
xShiFTx's Avatar
Fan#: 59110
What I Drive: 02 Sangria Red SE
FF Reputation: 5 xShiFTx Good Standing Member
Check out this list for a little bit of info, it isn't a complete list but it is a start.
http://cms.scca.com/documents/Solo_R...categories.pdf
xShiFTx is offline
Old 04-29-2009, 08:59 AM   #10
wrc_fan
slow
wrc_fan's Avatar
Fan#: 11913
Thanks
Check my FSP build thread, I am building a focus specifically for FSP.
Here's a quick breakdown/summary on allowable mods, check the rules for details:
Engine-
Any air intake, any throttle, any intake manifold, mild port matching between intake mani and head (See rules for details), any exhaust header, any exhaust that terminates behind the driver
Internals, Cams, Head, must all remain stock. Cam gears may be added to adjust cam timing. Rotating parts cannot be lightened, but they can be blueprinted (see rules for limitations). ECU can be reflashed.
Clutch and fly wheel can be changed, any shifter linkage allowed. LSD can be added, or you could weld your diff :D (only for the hardcore)
Wheels and tires:
Any DOT approved tire, no limitation on wheels. You can modify fenders and liners, but you cannot modify the hub or any other suspension component inboard of the hub flange
Suspension:
Any spring and damper, except you must use original mounting configuration. Camber plates and other alignment devices are allowed (see rules for limitations), camber plates and rear camber bolts are OK.
Sway bars are free, poly bushings are OK all around. Engine mounts can be poly, you can't increase the metal/rubber ratio in the mount.
Interior/body:
Interior to remain intact expect for the following: Front Seat replacement, steering wheel replacement, stereo delete, speaker delete
Rear spolier and front air dam allowed (rules for limitations)
Misc allowances:
Drums can be upgraded to discs, must bolt on
A/C delete
Emissions delete
Must keep E-brake
Fuel cell meeting GCR can be used
Battery location/type free
Parking Lot Hero
wrc_fan is offline
Similar Threads
Allowable Mods by Class (Autocross) DirtyDeeds Autocross Racing 32 06-17-2014 08:14 AM
all ford car show in Houston ch84 spi Fanatics: Texas 24 10-18-2008 09:09 PM
Engine mods to SVT but still class legal... tmgolden Road Racing & Rally 3 09-26-2008 03:40 PM
Auto-x class question LastRites Autocross Racing 18 10-05-2005 04:28 PM
