can a 180 degree thermostat Decrease performance? - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 04-26-2009, 05:39 PM   #1
ab0ybrush3dr3d
ab0ybrush3dr3d's Avatar
Fan#: 60222
What I Drive: 2001 Metallic Blue Zx3
FF Reputation: 2 ab0ybrush3dr3d Good Standing Member
i got a 180 degree thermostat to run it a little cooler, it gives me slightly better throttle response because its running a little richer, but can this decrease performance?
2001 Zx3 - 15.4 @ 88mph with full boltons
ab0ybrush3dr3d is offline
Old 04-26-2009, 06:16 PM   #2
illinipo
Token Engin-nerd
illinipo's Avatar
Fan#: 37693
What I Drive: dirty wag; Party; Bavarian phallus
FF Reputation: 272 illinipo Outstanding Standing Member illinipo Outstanding Standing Member illinipo Outstanding Standing Member
Buy-Sell-Trade Rating: (19)
where did you get the idea that a thermostat causes it to run richer?
cooler temps can improve your knock threshold but you cant take advantage of this unless you have a custom tune. without a tune the 180 doesnt really do anything. also your fans still wont turn on until the same temps as when you had the 192 so you really arent going to run any cooler.
Originally Posted by Dennis_Grant
Remember this list: Bilstein; Penske; Koni; Ohlins; Sachs; Dynamic Suspension.
Not on this list? Almost certainly crap.
SUV this!
illinipo is offline
Old 04-26-2009, 06:24 PM   #3
ab0ybrush3dr3d
Fan#: 60222
if you datalog it, it will show you, that your running richer, because the cooler your car is the more fuel it uses, this shown during warm up since it wont reach the 220 degrees its going to be running a little richer, till it gets up to the 120, i go to school for this and we used a scanner to look at everything, this shows,
Old 04-26-2009, 06:27 PM   #4
illinipo
Token Engin-nerd
illinipo's Avatar
Fan#: 37693
cold start enrichment in open loop is turned off after you hit 158 degrees. You shouldnt be hammering on the car until then anyway.
SUV this!
illinipo is offline
Old 04-26-2009, 06:35 PM   #5
bluefront
bluefront's Avatar
Fan#: 56816
What I Drive: 2006 white ZX5 SES
FF Reputation: 146 bluefront Excellent Standing Member bluefront Excellent Standing Member
Buy-Sell-Trade Rating: (6)
^^^^^I'm not sure I buy that logic. First off, the fans aren't running most of the time when you're moving (unless the AC is on).
So.....the 180degree thermostat is indeed opening sooner/wider, attempting to keep the coolant at 180 degrees. This is slightly below what the computer is expecting (head temperature sensor), so it's quite possible the computer may richen the mixture slightly to compensate (it thinks the engine is not warmed up sufficiently).
What effect this might have on performance.....in theory you might get a little more power, at the cost of MPG. CEL issues......maybe. And it is possible the computer may eventually "learn" the new/lower coolant temperature, and adjust to compensate. Hard to say for sure....
And I'll say this.....anybody who thinks they know everything that goes on in that little black box under the dash......think again.
I'll keep my guns, my freedom, and my money.....you can keep the "change".
bluefront is offline
Old 04-26-2009, 06:44 PM   #6
illinipo
Token Engin-nerd
illinipo's Avatar
Fan#: 37693
on the highway when the fans are off yes you might notice a bit cooler temps. but running at 65mph on the highway isnt where youre looking for performance now is it? At WOT you wont notice anything unless you have the fans turning on at lower temps.
once you hit 158 the computer doesnt change fueling based on ECT. I just ran through the entire ecu to double check.
There is also a time-based scalar to get you out of cold start fuel, on the stock ecu it is 10 seconds. This will override the ECT-based switching.
SUV this!
illinipo is offline
Old 04-26-2009, 06:47 PM   #7
illinipo
Token Engin-nerd
illinipo's Avatar
Fan#: 37693
also there is a table to tell the computer if the engine hasnt warmed up fast enough. If it goes outside this table it will throw a CEL, that is all.
SUV this!
illinipo is offline
Old 04-26-2009, 07:15 PM   #8
FociBoi121
FociBoi121's Avatar
Fan#: 53573
What I Drive: 2003 InfraRed ZX3 ATX
FF Reputation: 4 FociBoi121 Good Standing Member
EDIT: my bad the fans are on at 220
the 180 thermostat is an advantage due to the fact that it opens up sooner than the stock *192* degrees so i like to think about it as the engine gets cooled down 40 degrees sooner every time you run it than the stock thermostat i know it may not be a major longevity factor for an engines lifetime but it has to help a little
but at idle without a tune to kick the fans on earlier no the thermostat isnt helpful in this case
every morning i start my car and wait for it to pass the white bar or reach the middle before i drive so i dont burn so much fuel running the car cold
Current Mods: about me profile
ZETEC Crew #237
HATCHBACK LOVER #121
PS3 ID: LarkBoi189
Slow bolt ons added or bolt ons slowly added?
Last edited by FociBoi121; 04-26-2009 at 07:28 PM. Reason: Just for you illinipo lol
FociBoi121 is offline
Old 04-26-2009, 07:20 PM   #9
illinipo
Token Engin-nerd
illinipo's Avatar
Fan#: 37693
woah the stock is 220? i was under the impression it is 192.
Like I said I dont know how many times i have to say this, after 10 seconds there IS NOT ANY ENRICHMENT based on coolant temp, you are just wasting fuel by letting it sit there to warm up. 30 seconds is all you need to let it warm up enough and go into closed loop. Depending on the startup temp after 10-30 seconds it is in closed loop meaning 14.7:1! There doesnt appear to be any closed loop bias based on ECT.
I would post the tables if you guys still dont believe me but that would be a breach of my license agreement with SCT.
SUV this!
illinipo is offline
Old 04-26-2009, 08:39 PM   #10
bluefront
bluefront's Avatar
Fan#: 56816
"There doesnt appear to be any closed loop bias based on ECT."
Perhaps not on the Focus, but there is on other vehicles........this is a subject open to debate, and hard to prove one way or another. I'm certainly not a Focus ECU/emissions expert........but the warm-up period on my '06 takes longer than 30 seconds in cold weather (based on O2 voltage monitoring, among other things). Looks to me like closed loop takes a few minutes to kick in.
Similar Threads
190 degree thermostat scrammer ZETEC Performance (2000-2004) 21 09-28-2008 11:19 PM
For Sale: Performance Thermostat (SPI) phord_phocus86 Archive 6 08-13-2007 01:46 PM
What are the benefits of a 180 degree thermostat? 02SVTsilverstreak General Technical Chat 34 11-16-2006 05:40 PM
cars performance at 180 km. jjflores General Technical Chat 10 11-02-2005 11:20 AM
