Full-recline mod to stock seats.....56k friendly. - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum > Ford Focus First Generation > MK1 Interior Mods & Upgrades
Old 04-29-2009, 03:48 PM   #11
bluefront
bluefront's Avatar
Fan#: 56816
What I Drive: 2006 white ZX5 SES
FF Reputation: 146 bluefront Excellent Standing Member bluefront Excellent Standing Member
Buy-Sell-Trade Rating: (6)
The mod worked!!!!! Total cost $0......even better. Total time not including contemplation....maybe five minutes. Simple enough most of you could do it in your driveway, without even removing the seat.
I simply drilled out the single pin.....used a #2 drill bit. Mask the area so the metal doesn't get in the seat track, and put a flat piece of metal behind the hole so you don't drill into the seat cushion.
If you drill right, you'll go through the center of the pin, and out the other side. Pry out the hollowed out pin. You can see the top of the toothed "J" bracket which no longer has a stop-pin to prevent reclining.
With the head-rest removed, and the seat pushed forward.....here's what it looks like. Unfortunately the seat-back is too tall to recline completely.....it rests against the edge of the rear seat bottom when fully reclined.
As I thought might happen.....the teeth on the "J" bracket don't go down far enough to lock the seat back when fully reclined. But you can recline and lock the seat back maybe 30 degrees further than stock.
What I didn't expect......with the seat fully back and reclined, it makes a very nice sleeping surface. All you need is a pillow. The seat back is supported by the bottom of the rear seat cushion. (In the photos my rear seat bottom is removed and replaced with a thin pad, covered with vinyl).
I'm still wondering if I should make something to lock the seatback fully reclined. Right now it will spring up without any weight on it.....but it will only go so far till it locks. When you're laying on it, you don't notice a thing.
Another nice part of this mod....if you don't like it when you're done, you could replace the drilled-out pin with a small bolt and a loc-nut. Back to stock. With this seat mod completed, you won't notice a single thing different.......except your seat will now recline. You could do this mod to the driver seat also, but the steering wheel may hit your knee if you try to recline fully.
Happy modding.
I think this may be a completely original mod on a Focus.....be the second on the block to do it.
I'll keep my guns, my freedom, and my money.....you can keep the "change".
bluefront is offline
Old 04-29-2009, 03:51 PM   #12
bluefront
bluefront's Avatar
Fan#: 56816
Photobucket is screwed up today...the pictures aren't showing yet.
Fixed now..
Old 04-29-2009, 06:23 PM   #13
bluefront
bluefront's Avatar
Fan#: 56816
Here's the quick/easy to hold the seat-back fully reclined. I ran an 8mmx.125 bolt into the unused rear seat hing hole (sticking out about 2"). Then I bent the ends of an adjustable strap slightly. It works.....since is will be used only occasionally, it doesn't have to be too fancy.
Old 04-30-2009, 05:39 PM   #14
bluefront
bluefront's Avatar
Fan#: 56816
Little update to this project......I was painting the seat trim piece while I was working on the seat. Well I found out I had to trim the inner edge slightly, at the point the toothed "J" arm now goes up further than stock. Here's what it looks like now with the trim back on. Takes only a few minutes extra.
And while I was painting the driver side trim, I did this mod to that side also. Glad I did. Now if you get tired driving, you can pull over somewhere and rest awhile, even if you have a passenger. A safety mod.......
Old 05-03-2009, 10:55 AM   #15
bluefront
bluefront's Avatar
Fan#: 56816
I got a chance to test out the carrying capacity of this recline mod.....that's a 7' long piece of molding in there......without even reclining the rear seat back. Measuring....there's enough room left that it looks like you could carry at least six (maybe more) 8' 2x4s in the same spot. This is exactly what I was hoping for....
Old 05-04-2009, 07:05 PM   #16
pistolgripbmx
pistolgripbmx's Avatar
Fan#: 49331
What I Drive: 86 ranger, 2007 focus zx3 s
FF Reputation: 38 pistolgripbmx Great Standing Member
Buy-Sell-Trade Rating: (8)
nice, gotta bust out my drill!
teamduratec #143!
focus sport cool-flo, f2 v.3 header, trubendz 2.5 SS, frpp 1.5" front sportline rear, vf rear engine mount, 93oct Focus Power tune
pistolgripbmx is offline
Old 05-06-2009, 01:28 AM   #17
Xornok
Fan#: 61963
What I Drive: 2013 IS Focus ST2
Points 291, Level 5
Points: 291, Level: 5 Points: 291, Level: 5 Points: 291, Level: 5
Level Up 82% Completed
FF Reputation: 1 Xornok Good Standing Member
Bluefront, you are easily my favorite person on this site.
Xornok is online now
Old 05-06-2009, 06:14 AM   #18
bluefront
bluefront's Avatar
Fan#: 56816
Thanks...
Old 05-07-2009, 02:14 AM   #19
FocusedEnergy
FocusedEnergy's Avatar
Fan#: 48574
What I Drive: 2006 Liquid Gray ZX4SE
FF Reputation: 3 FocusedEnergy Good Standing Member
Nice write-up. I had heard of someone doing this before on this site (sorry) but I'm too lazy to find it here. This should go into the how-to archive.
SEDAN REVOLUTION #51
The tighter the budget, the slower the mod progress. Estimated completion date: September 2057
FocusedEnergy is offline
Old 05-11-2009, 01:23 AM   #20
ChuckDee
Ehh...
ChuckDee's Avatar
Fan#: 43589
What I Drive: 02 SC SVT
Points 17,687, Level 84
Points: 17,687, Level: 84 Points: 17,687, Level: 84 Points: 17,687, Level: 84
Level Up 68% Completed
FF Reputation: 48 ChuckDee Great Standing Member
^^^i agree, i wanna try and do this mod also .
unique(adj): to break off from the crowd and do your own thing
ChuckDee is offline
Similar Threads
help- cheap replacement for stock seats bretth SVT Interior Mods & Upgrades 3 02-17-2009 02:43 AM
Anyone from the area done the $20 HP increase Chip MOD? higgszx3se Great Lakes Fanatics 5 07-18-2008 04:16 PM
Lowering the stock seats jbondjr MK1 Interior Mods & Upgrades 39 05-24-2005 10:28 PM
For Sale: Stock OEM Seats Read+Help? ouikikazz Archive 8 12-19-2004 11:30 AM
For Sale: Stock ZX3 seats Lil PZEV Archive 6 08-15-2004 03:49 AM
