DIY Replacing SVT Shocks/Struts? - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 04-24-2009, 12:47 AM   #1
Kalos
Fan#: 1733
What I Drive: '04 SVT, Silver
FF Reputation: 1 Kalos Good Standing Member
I went to a tire dealer to investigate wheel/tire noise. He says I need new struts/shocks and tires. Fair enough — the currents struts/shocks are originals and have ~96K miles. The tires (Nitto Neo Gen) are unevenly worn front and back. Now that I notice it, the back end seems to slide out too easily going over bumps in the road.
The dealer wants $1,000+ to replace front struts and rear shocks!!
I have access to a garage and lift, so I think I can replace the rear shocks. So how difficult it is? I've seen to procedure details. Looks pretty simple, but am I going to be surprised by something nasty - such as difficulty getting the shocks out, or bushings that need replacement and I can't get them Sunday afternoon? Is this a one-person job? Anything else likely need replacing while I'm replacing the rear shocks? Do the rear wheels need "alignment" after I replace the shocks?
Looks like I should go to a pro shop to replace the front struts (?).
Where can I buy stock struts and shocks cheap? Who makes the Ford OEM shocks? Can I get them cheaper under another part number?
Kalos is offline
Old 04-24-2009, 01:09 AM   #2
wickedgreyzx3
Fan#: 34204
What I Drive: 2006 ZX3 Liquid Grey
FF Reputation: 17 wickedgreyzx3 Great Standing Member
remove the struts yourself and take them somewhere.
Modifying cars is retarded. Buy a bike instead.
wickedgreyzx3 is offline
Old 04-24-2009, 01:14 AM   #3
Honorsystem
Fan#: 28383
What I Drive: 2004 Pitch Black SVT EAP
FF Reputation: 1 Honorsystem Good Standing Member
You might check in the marketplace here to see what you may find, however, you might kill two birds with one stone. Check out the KYB AGX adjustable dampers. A Full set will run you about 350-450$, iirc, but you'll get an even better ride control, and the ability to customize the handling a bit. I used 'em on my old Zetec sedan with some H&R race springs, and they worked beautifully.
In response to how to do it, I know there's a how-to around here somewhere, I'll see if I can't dig it up for you. Its not overly difficult, and there're no really nasty surprises a bit of elbow grease won't solve, but you'll need a set of spring compressors (Autozone may still rent them out, if not, Sears sells Craftsman ones for about 50$), and about 4-5 hours time if you're by yourself and its your first time through. I would also suggest finding a way to get access to an impact wrench, it speeds up the job and will make your life a helluva lot easier. One final bit, you will need an alignment once you are done (you should get one anytime you change things in the suspension, with the exception of changing swaybars.)
(Here's the aforementioned How-To's)
http://jason.hodges.cc/suspension.htm
http://www.focushacks.com/index.php?modid=54
Zetec Crew #105
I lay awake in my bed the other night, staring at the stars and wondered, "Where the heck did my roof go?!"
Honorsystem is offline
Old 04-24-2009, 01:46 AM   #4
Kalos
Fan#: 1733
In response to how to do it, I know there's a how-to around here somewhere, I'll see if I can't dig it up for you. Its not overly difficult, and there're no really nasty surprises a bit of elbow grease won't solve, but you'll need a set of spring compressors (Autozone may still rent them out, if not, Sears sells Craftsman ones for about 50$), and about 4-5 hours time if you're by yourself and its your first time through. (Here's the aforementioned How-To's)
4-5 hours? Spring compressors? Seems to me too much hassle to do a DIY front struts replacement. Rear shocks replacement should be easy though, right? I just need cheap stock struts and shocks to get me through the next 25K miles.
Kalos is offline
Old 04-24-2009, 09:47 AM   #5
gukin
gukin's Avatar
Fan#: 12777
What I Drive: 2003 Orange SVTF
Points 1,716, Level 24
Points: 1,716, Level: 24 Points: 1,716, Level: 24 Points: 1,716, Level: 24
Level Up 16% Completed
Level up: 16% Level up: 16% Level up: 16%
FF Reputation: 1 gukin Good Standing Member
You have a lift and say it's too much trouble? Wow, dang a lift would make sooo many things a lot less of a hassle.
HOWEVER, don't go cheap on the struts! Lots of places (like Midas etc.) like to push struts and shocks because the parts don't cost much but it is somewhat labor intensive; and they can always pay their people lousy but still charge a lot.
Struts and shocks are a DYI proposition, I did a set with a mechanic once and it's not terribly hard but you WILL need a spring compressor or, like someone else suggested, yank the struts off your car (since you have a lift, this is really no big deal) take them to Midas with the struts you bought from tirerack.com or wherever and have them swap the struts. Then throw them back on your car, buzz down to Midas or Discount Tire and get a four-wheel alignment and you're done.
Now that I've taken a look at tirerack.com, maybe your Stealership isn't ripping you off as badly as you thought. Tire rack wants $163 x2 for the fronts and $144 for the rears. That's over $600 in parts alone then throw in labor, an alignment and hooking your car up to the machine that goes "Bing!" $1000 isn't far off; plus you've got a "warranty" (depending on your stealership) on the parts and labor for a year or so (or that 25,000 miles).
Sorry bro, you're just going to have to pony up the pesos.
gukin is offline
Old 04-24-2009, 09:50 AM   #6
1stTimeFocus00
Fan#: 44202
What I Drive: 2000 InfaRed Zx3
FF Reputation: 27 1stTimeFocus00 Great Standing Member
Buy-Sell-Trade Rating: (9)
for instructions, go to google, type in svt suspension install. Detailed instructions for install a full suspension.
Zetec Crew #152
United States Army
1stTimeFocus00 is offline
Old 04-24-2009, 12:05 PM   #7
Geezer
Fan#: 1427
What I Drive: 99 miata, 05Mazda6, 09GTI, 12Imprez
FF Reputation: 141 Geezer Excellent Standing Member Geezer Excellent Standing Member
A new set of SVT struts can be purchased for less than 200.00 from several FF vendors. As you found out they can last a long time and are very well matched to the SVT and its stock springs. The only problems you may experience are rusted bolts. Start applying PB Blaster several days before you do the work. Access to a lift (and hopefully air tools) WILL make it a lot easier. Don't screw around with rusted bolts if they can't be removed. Break or cut them off. I suggest getting an alignment after install if no other reason than to protect the new tires.
Geezer is offline
Old 03-19-2012, 11:37 AM   #8
MegaJoltSVT
MegaJoltSVT's Avatar
Fan#: 94148
What I Drive: 2002 Sonic Blue SVT
FF Reputation: 1 MegaJoltSVT Good Standing Member
I know this thread has been inactive for a while but I found these just searching online:
SVT Focus Replacement Shocks/Struts
MegaJoltSVT is offline
Similar Threads
Parting SVT Lots of Stuff cafociguy Archive 100 07-07-2008 02:19 AM
SVT on DIY channel drzoidberg SVT Performance (2002-2004) 13 11-08-2005 11:57 AM
DIY Network airing show with SVT modifications lunarc SVT Performance (2002-2004) 17 10-22-2005 11:15 PM
lowest drop on SVT shocks/struts ?? nickelpayday Wheels & Tires 1 04-29-2004 09:09 PM
WTB: SVT Shocks/Struts Jaston Archive 2 09-13-2003 05:18 PM
