P0171 cel code? - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 04-22-2009, 04:14 PM   #1
D_R_Pinksron
Fan#: 64409
What I Drive: 2003 Ford Focus
FF Reputation: 1 D_R_Pinksron Good Standing Member
P0171 cel code?
I have an '03' focus with 92000 miles and P0171 is the code for the cel thats on. Was told that means it's running lean so I put a fuel filter on since it needed to be done anyway. The lights still on and it seems to lose power sometimes when i'm driving. Any idea what could be causing it? Newbie to this site, this is my 1st post so I appoligize if this topic has already been covered. Thanks for any help!!!
D_R_Pinksron is offline
Old 04-22-2009, 04:18 PM   #2
penguin
Fan#: 21700
What I Drive: 2005 Infrared ZXW
FF Reputation: 109 penguin Excellent Standing Member penguin Excellent Standing Member
Check for vacuum leaks after the MAF, including the PCV hoses, e.g., cracked, loose, collapsed, etc.
penguin is offline
Old 04-22-2009, 04:52 PM   #3
SVT_ME
SVT_ME's Avatar
Fan#: 53618
What I Drive: '02 Ranger XLT- '08.5 MS3 GT
FF Reputation: 7 SVT_ME Good Standing Member
Welcome to the site!
My first thoughts would be the same as stated above ^^
But here are some other potential causes:
P0171 - System to Lean (Bank 1) The Adaptive Fuel Strategy continuously monitors fuel delivery hardware. The test fails when the adaptive fuel tables reach a rich calibrated limit. For lean and rich DTCs:
Fuel system
Excessive fuel pressure.
Leaking/contaminated fuel injectors.
Leaking fuel pressure regulator.
Low fuel pressure or running out of fuel.
Vapor recovery system.
Induction system:
Air leaks after the MAF.
Vacuum Leaks.
PCV system.
Improperly seated engine oil dipstick.
EGR system:
Leaking gasket.
Stuck EGR valve.
Leaking diaphragm or EVR.
Base Engine:
Oil overfill.
Cam timing.
Cylinder compression.
Exhaust leaks before or near the HO2Ss.
A SHRTFT-1,2 PID value between -25% to +35% and a LONGFT-1,2 PID value between -35% to +35% is acceptable. Reading beyond these values indicate a failure.
Here is a link for future use. - http://www.focusfanatics.com/forum/s...ad.php?t=59286
Originally Posted by HGFireHazard View Post
Truthfully, the only person I really trust to work on my cars is me. I know when I do something right and I know when I do something wrong...
SVT_ME is offline
Old 04-22-2009, 06:16 PM   #4
Kal-EL428
Kal-EL428's Avatar
Fan#: 47337
What I Drive: 2002 SVT Sonic Blue
FF Reputation: 33 Kal-EL428 Great Standing Member
I had that code a few weeks back. I went out and got some MAF cleaner, cleaned my MAF and re-set the computer. Problem solved for me.
02 Sonic Blue SVT
#2064 of 4788
Born on: 5-14-02
Kal-EL428 is offline
Old 04-22-2009, 06:48 PM   #5
D_R_Pinksron
Fan#: 64409
Thanks for all the feedback. I checked the hoses & from what I can tell they all look good. Where is the MAF located & does it need to be removed to clean it? Will the cel go out on its own once the problem is fixed & if not how do I reset it?
Old 04-22-2009, 07:05 PM   #6
sleepyboy
FF's Night Security
sleepyboy's Avatar
Fan#: 15335
Points 140,700, Level 100
Points: 140,700, Level: 100 Points: 140,700, Level: 100 Points: 140,700, Level: 100
Level Up 0% Completed
Forum Activity 50%
Activity: 50% Activity: 50% Activity: 50%
FF Reputation: 50 sleepyboy Excellent Standing Member
Buy-Sell-Trade Rating: (11)
I just disconnect the battery and then turn my lights on or try to start the car to drain whatever was left. Then reconnect and start. Let the car idle for a few mins then drive has normal. See if the code pops back up. If it does time to do more trouble shooting. Your fuel injectors could be dirty or the MAF sensor. Try the cheaper fixes first. You can get MAF cleaner at the auto parts store. Just make sure its Mass Airflow Sensor cleaner and not electrical cleaner
Moderator for
Technical Chat
Zetec Performance Chat
Southern Fanatics Chat
sleepyboy is offline
Old 04-22-2009, 07:10 PM   #7
dirtbrown
what it be like
dirtbrown's Avatar
Fan#: 40563
What I Drive: 03 EAP
Points 41,796, Level 100
Points: 41,796, Level: 100 Points: 41,796, Level: 100 Points: 41,796, Level: 100
Forum Activity 8%
FF Reputation: 27 dirtbrown Great Standing Member
my SVT threw that same exact code and would loose power like you were describing when I had a bad front o2
dirtbrown is offline
Old 04-23-2009, 11:17 AM   #8
dorman68
Fan#: 53695
What I Drive: 1993 ford ranger 5 - speed
FF Reputation: 1 dorman68 Good Standing Member
2x, pcv hoses & elbows very prone to cracks
dorman68 is offline
Old 04-23-2009, 01:30 PM   #9
1stTimeFocus00
Fan#: 44202
What I Drive: 2000 InfaRed Zx3
FF Reputation: 27 1stTimeFocus00 Great Standing Member
Buy-Sell-Trade Rating: (9)
Im having the a similar problem with my focus... Im throwin that code but i really dont have any symptoms....
Gas Mileage is the same, no power loss, my car stumbles a taddddddd at idle.
All i have checked was my SR intake and there doesnt appear to be any problems with it.
Sleepboy mention you have to clean the maf with that type of cleaner..why not electrical cleaner?
How about running fuel system cleaner through a tank of gas?
How do i know if my front o2 sensor could be bad?
Zetec Crew #152
United States Army
1stTimeFocus00 is offline
Old 04-23-2009, 03:25 PM   #10
penguin
Fan#: 21700
Check really, really, really carefully for vacuum leaks.
Seriously, there are other reasons that code can be thrown, but the vast majority of the times it is a vacuum leak. People will do a quick check, say no vacuum leak, do a bunch of other stuff, and then as a last resort really check carefully and find a leaky or collapse hose.
Now, maybe you have really checked carefully for a leak and there isn't one. But it is worth the time to check really carefully before ruling out a vacuum leak.
penguin is offline
Similar Threads
throwing code p0171 lean code crazeboy1 General Forced Induction 5 03-18-2009 02:07 PM
Need Ford Recall, TSB, or your vehicle history? Click Here! DJ Lukdogg General Technical Chat 368 10-13-2008 06:04 PM
CEL code 135(o2 sensor) taco555 General Technical Chat 4 06-08-2008 06:57 PM
DTC code P1246 - should this set of a CEL? onebluemcm General Technical Chat 1 06-18-2006 10:28 PM
CEL OBDII code PO135 & PO141 SVTF4243 General Technical Chat 4 02-20-2006 04:15 PM
