How do I reset the check engine light? - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 04-22-2009, 12:58 AM   #1
babzog
Guest
Fan#:
Posts: n/a
Hey folks,
Car is an '02 Focus SE Wagon, Zetec engine. It's been seeing less use these days as we're trying to sell it. When I took it for a trip to work last week, the CEL came on. Dealer said they couldn't just read the code, that they'd have to diagnose it, road test it, yadda yadda. At least $110 just to tell me what is wrong. He said if the car is running alright (which it is) and the gas and oil are full (oil was fine and I'd just filled the gas that morning as it was quite low), then just drive it and see if it goes away (it hasn't).
Question: I would like to just reset it and see if it comes back. Is there a "pushing buttons" trick to reset the light or do I have to disconnect the battery?
Thanks!
Old 04-22-2009, 01:04 AM   #2
SkyPilot
Jetsetter
SkyPilot's Avatar
Fan#: 22350
Points 13,931, Level 76
Points: 13,931, Level: 76 Points: 13,931, Level: 76 Points: 13,931, Level: 76
Level Up 71% Completed
Level up: 71% Level up: 71% Level up: 71%
Forum Activity 8%
FF Reputation: 45 SkyPilot Great Standing Member
Buy-Sell-Trade Rating: (18)
an auto parts store should be able to read the code for you for free, call around to find out.
you can disconnect the negative side of your battery for 15-20 min and that will reset the CEL but that wont prevent it from coming back.
SkyPilot is offline
Old 04-22-2009, 08:09 AM   #3
substanger
Fan#: 63761
What I Drive: 2003 Focus/1993 Mustang 'vert 5.0
FF Reputation: 3 substanger Good Standing Member
Actually disconnecting the battery for 1-2 minutes will suffice. The PCM has what is called KAM or keep alive memory powered by the battery. Once battery power is removed, the KAM is erased.
2003 Focus. Former U.S. Navy Submariner-13 yrs. 2nd career-Ford driveability tech-8 yrs. 3rd career-vehicle service contract mechanical claims adjuster for Zurich North America (aftermarket warranty) and U.S. Air Force reservist.
substanger is offline
Old 04-22-2009, 09:33 AM   #4
justjake
Fan#: 60533
What I Drive: 2001 zx3
FF Reputation: 7 justjake Good Standing Member
^^^in order to reset the KAM you actually have to hold the positive and negative terminals together so oit will discharge the li'l bit of energy left to support the KAM. Once you do that you'll have to go through a relearn strategy (drive it about 50 miles).
The other option since you'll want to go to the parts store and have the codes read (scanner) the scanner will have an option to clear the codes, Just select that and the light will magically disapear until it's triggered again.
justjake is offline
Old 04-22-2009, 10:42 AM   #5
RallieConGoggle
RallieConGoggle's Avatar
Fan#: 50774
What I Drive: 2007 CD Silver ZX4
Points 2,146, Level 27
Points: 2,146, Level: 27 Points: 2,146, Level: 27 Points: 2,146, Level: 27
Level Up 98% Completed
FF Reputation: 9 RallieConGoggle Good Standing Member
You'll want to get that code read, it's good information to have. There's no reason to reset it if you haven't fixed the cause.
Don't hold the + and - leads together unless both are disconnected! Holding the leads together is not necessary for resetting the ECM's memory. You'll know if it's reset properly if the first time you turn the key on after reconnecting the battery, the speedo & tac go to max for 1 second, then back to 0(at least on my Zetec).
Like I said, don't reset it until you get the code read. Autozone will do it for free. Dealerships always rip you off, there is no exception.
Rally with your goggles on!
2000 Pitch Black ZTS Auto (230,000+ miles)
2007 CD Silver ZX4 SES 5spd
Zetec Crew #190
RallieConGoggle is offline
Old 04-22-2009, 11:42 AM   #6
substanger
Fan#: 63761
Sorry to the OP for the hyjack, but what experience/knowlege do you base this on?
Old 04-22-2009, 01:14 PM   #7
penguin
Fan#: 21700
What I Drive: 2005 Infrared ZXW
FF Reputation: 109 penguin Excellent Standing Member penguin Excellent Standing Member
I understand your point; however, I think it would be more accurate to say "Most dealerships usually rip you off, but there are some exceptions."
penguin is offline
Old 04-23-2009, 05:35 PM   #8
babzog
Guest
Fan#:
Posts: n/a
I reset the code today while checking the tire pressures. There is/was no reason for a code to "magically" show up so I figured I'll reset it and see if it comes back. After driving 20km, it hadn't reappeared so I'm sure it was nothing of consequence (the car was running fine while the light was on).
It's at my BIL's shop now where there is much greater public exposure to help sell it. He was telling me that many of the codes that are set are checked at intervals. Some of those intervals could be every engine start, some could be every 1000km, in which case, whatever code was set could have been cleared soon enough on its own.
Anyway, apparently he has a reader (didn't think to ask since his is a bike shop) so if it reappears, he'll check it then.
Thanks for all the advice!
Old 04-23-2009, 06:18 PM   #9
RallieConGoggle
Fan#: 50774
That's probably fair, I've just never gone to the dealership that was the exception.
I found two receipts in my glove box for the EXACT same service, one from Ford, one from Meineke.
Cost:
Meineke: $30
Ford: $136
I needed to have my AC checked to see where the leak was. Ford charged me for refrigerant to do the test, and when I asked why he acted like you can't do a leak check without it!
Ford told me that there was a leak, Meineke told me that it was in the condenser. Bottom line: anything George Forman sells is awesome.
Just one example of many, and it's pretty frustrating after awhile.
Want more? I once broke a wheel bearing... ok make that 3 times I've broken wheel bearings (MI roads suck).
Ford: $530
some brake shop: $250
did it myself: $58
I know that there are some good ones out there, but getting ripped off really pisses most of us off. It's not like I've never been ripped off by non-dealership mechanics either.
Peace
Zetec Crew #190
Old 04-23-2009, 10:08 PM   #10
penguin
Fan#: 21700
Again, I get your point and rarely use a dealer myself, but to be fair, here' my experience with a 1992 Taurus A/C repair for a rusted-out line with a recharge.
Cost $520
Period before A/C compressor seized: 12 months.
Amount of oil in the compressor after seizing: 0
Amount of freon in the system after seizing: full charge.
Obviously when Midas "fixed" it they did not put any oil in the system.
penguin is offline
Similar Threads
Engine Check Light.. missfire help plz Meitsch General Technical Chat 4 01-21-2008 09:10 PM
Check engine on: does disconecting the battery reset the engine diagnostic? hydrocynus General Technical Chat 6 12-26-2007 09:04 PM
Check Engine Light on again! Possible Lemon? bumblebee07 General Technical Chat 8 12-09-2007 01:31 AM
check fuel door/ check engine light mench General Technical Chat 7 06-01-2004 11:27 AM
