Sponsored by Tire Rack
Go Back   Focus Fanatics > Ford Focus Tech Discussions > Wheels, Tires, Brakes & Suspension - Sponsored By Tire Rack
Wheels, Tires, Brakes & Suspension - Sponsored By Tire Rack The place to go for answers on wheel types, tire sizes, suspension issues and more.
Sponsored By:
Tire Rack
Old 04-20-2009, 11:28 AM   #1
moe411
Fan#: 64490
What I Drive: 2003 Dark Blue ZTW
FF Reputation: 1 moe411 Good Standing Member
Angry Stripped Caliper Bolt-AM I SCREWED ??
Hello and thank's for your help, I changed my rotors and pads this weekend, when I screwed the lower bolt on the passenger side caliper I somehow stripped the hole. Now I can't tighten this bolt anymore. I noticed the threading on the bolt is a bit rough so I guess I will need to get another one.
My question is what could I do to fix the stripped hole ? Can it be fixed somehow WITHOUT having to replace the whole boot ?
I will probably have a REAL mechanic do the job this time but I want your advice on what can and should be done.
THANK YOU !!
moe411 is offline
Fan#: 1
Old 04-20-2009, 11:32 AM   #2
norcalfocus01
Fan#: 55603
FF Reputation: 132 norcalfocus01 Excellent Standing Membernorcalfocus01 Excellent Standing Member
Buy-Sell-Trade Rating: (12)
you mean the hole for the allen wrench is what you stripped?
if so peel back the rubber sleeve and put a pair of vise grips on the bolt and take it out then get a new one.
norcalfocus01 is offline
Old 04-20-2009, 11:38 AM   #3
moe411
Fan#: 64490
Thank's for the quick reply, my caliper has 2 bolts covered by a plastic cap. I can get the bolts out but I can't get the lower one screwed back in since I stripped the hole somehow. I swapped the bolts to see if it was the bolt or the hole which had a problem and both of them cannot be tightened anymore so I gess I stripped the hole somehow... Any ideas ?
moe411 is offline
Old 04-20-2009, 11:41 AM   #4
norcalfocus01
Fan#: 55603
im still not following what you stripped.
did you strip the threads the bolt goes into?
or the head of the bolt?
Old 04-20-2009, 11:48 AM   #5
moe411
Fan#: 64490
Sorry for the confusion, english is a second language.... The caliper bolt seems fine, I stripped the hole this bolt goes in... I can't thighten it anymore. The top one is thight, the lower one is loose and won't grip in the hole amymore.
moe411 is offline
Old 04-20-2009, 11:57 AM   #6
Peregrine
I.S.A.I.K.I.
Peregrine's Avatar
Fan#: 6009
What I Drive: '03 CD Silver SVT, '11 Mazda CX-9
FF Reputation: 112 Peregrine Excellent Standing MemberPeregrine Excellent Standing Member
Buy-Sell-Trade Rating: (23)
If the bolt head is stripped, you can tap a six point Torx bit into it to loosen or tighten it.
Sounds like you'll have to rethread the hole or replace the entire caliper bracket altogether.
Peregrine is offline
Old 04-20-2009, 12:03 PM   #7
moe411
Fan#: 64490
The bolt is not stripped, the hole is though. You think I could get this rethreaded ? Would it be strong enough ?
moe411 is offline
Old 04-20-2009, 12:08 PM   #8
norcalfocus01
Fan#: 55603
yeah it maybe can be re threaded. it would be plenty strong enough. the caliper really just slides on the bolt.
check the local junk yards for a new bracket, it would be a very simple install and cheap. the nice thing is you learn a junk car on what to take off before you take the bracket off your car.
Old 04-20-2009, 12:09 PM   #9
JPSCOTT713
JPSCOTT713's Avatar
Fan#: 60801
What I Drive: 2009 Black SE Sedan 5sp.
FF Reputation: 5 JPSCOTT713 Good Standing Member
yes you can rethread, its pretty simple but if you are not confident in it you can take it to a local machine shop and they can even put a sleeve in there to tap to keep the same bolt size if needed, how bad you stripped it will decide wether or not you will have to tap it out to a larger size
SR/TEAM DURATEC #156
JPSCOTT713 is offline
Old 04-20-2009, 12:37 PM   #10
moe411
Fan#: 64490
OK thanks, I'll have a machine shop do the rethread,
moe411 is offline
Similar Threads
Oh No, Stripped water pump bolt plmac7880 General Technical Chat 6 12-04-2011 10:07 PM
Sway bar bracket bolt in engine cradle/subframe Gregorzzz Wheels, Tires, Brakes & Suspension - Sponsored By Tire Rack 0 03-24-2009 01:33 AM
Help with SVT rear caliper removal racer1735 Wheels, Tires, Brakes & Suspension - Sponsored By Tire Rack 4 01-25-2009 08:45 AM
How-to: Vf Rear Motor Mount Install [picts] HaveBlue83 Ford Focus & General Car Chat 9 03-20-2006 04:46 PM
URGENT!!! Oh [:)][:)][:)][:)][:)][:)]**........Broke an engine cover bolt ferraristyle SPI Performance (2000-2004) 22 08-11-2004 09:22 PM
