2001 zetec rough idle when cold. - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 04-18-2009, 11:40 PM   #1
torsotext
Fan#: 64452
What I Drive: 2002 white wagon
FF Reputation: 1 torsotext Good Standing Member
Hey guys I have a 2001 focus with a zetec engine and auto trans. It has a rough idle when I start it (only on cold starts), also drives kinda rough until the engine warms up. Once the car is warmed up it starts/ drives great. I am not getting any relevant engine codes (only "EVAP small leak detected") which I have been getting long before the rough idle problem. any ideas?
torsotext is offline
Old 04-18-2009, 11:49 PM   #2
mlbbaseball
Shot me 3 deer!!!
mlbbaseball's Avatar
Fan#: 53541
What I Drive: 02 SVT, 2 7.3 L Diesel Excursions!
Points 28,017, Level 98
Points: 28,017, Level: 98 Points: 28,017, Level: 98 Points: 28,017, Level: 98
Level Up 67% Completed
Forum Activity 3%
FF Reputation: 42 mlbbaseball Great Standing Member
Buy-Sell-Trade Rating: (69)
What cams do you have?? lol, jk, but in all seriousness, what weight oil are you using?
Now I rive 2 7.3 L diesel trucks!
mlbbaseball is offline
Old 04-19-2009, 04:33 AM   #3
lintlars
Fan#: 19550
What I Drive: 2000/ford focus(winter beater) Toyota Supra (Summer car)
FF Reputation: 1 lintlars Good Standing Member
The PCV hose on the back of the intake probably has a hole in it a common issue for the zetec just reach around the intake while it is running and feel the 3/4 inch hose for any leaks
lintlars is offline
Old 04-19-2009, 06:13 AM   #4
emsvitil
Fan#: 50210
What I Drive: 2000 SE Wagon
Points 3,113, Level 34
Points: 3,113, Level: 34 Points: 3,113, Level: 34 Points: 3,113, Level: 34
Level Up 43% Completed
Forum Activity 3%
FF Reputation: 9 emsvitil Good Standing Member
Pop the cap off the passenger side motor mount and see if there's a gushy bubble of fluid under the rubber in the cavity.
If it's hard, it sounds like your passenger side motor mount.
Ed
emsvitil is offline
Old 04-19-2009, 06:14 AM   #5
emsvitil
Fan#: 50210
Forum Activity 3%
see
http://www.focusfanatics.com/forum/showthread.php?t=193287
Ed
emsvitil is offline
Old 04-19-2009, 09:56 PM   #6
torsotext
Fan#: 64452
I started it up and checked the pcv hose, it was collapsed at the pcv valve, I also inspected the passenger side motor mount and there seems to be oil around its base? I'll replace the pcv hose/ valve tomorrow, and take a look at the motor mount, thanks
Old 04-21-2009, 09:34 PM   #7
torsotext
Fan#: 64452
PVC hose was the problem, FYI the dealer doesn't recognize the part as a PVC hose (that's a different part), they call it the crankcase hose. Also what appeared to be oil around my pass side engine mount turned out to be coolant leaking from a seem on the coolant reservoir. Thanks for your help.
Tags
cold , rough idle , zetec
Similar Threads
Low idle - 2000 Zetec pmarsili General Technical Chat 14 03-22-2009 10:50 AM
bad idle when cold sbowling General Technical Chat 7 10-15-2008 11:39 AM
2001 SOHC - 2002 Zetec Engine Swap ? DBFoster Engine & Transmission Swap 2 08-03-2008 05:43 PM
Runs rough only when cold... dowata General Technical Chat 12 03-02-2008 05:09 AM
Difference between 2001 2.0 zetec and 2.3L PapoSwing DURATEC Performance (2003-2007) 11 08-03-2004 02:41 PM
