brakes - Ford Focus Forum, Ford Focus ST Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum > Ford Focus Tech Discussions > General Technical Chat
Old 04-16-2009, 04:54 PM   #1
rickster6144
Fan#: 64412
What I Drive: 2000 focus tddi blue
FF Reputation: 1 rickster6144 Good Standing Member
brakes
any one got any idea about brake systems...i.ve just fitted new pads to my focus 1.8 tddi estate 2000..now the pedal is soft and goes to the floor when pressed with the engine running when pumped goes hard and.. when engine turned off the foot pedal is hard...i.ve checked a number of times but no fluid leak...all the symptoms of a leak in the fluid system but nothing can be seen any where thanks
rickster6144 is offline
Old 04-16-2009, 06:04 PM   #2
substanger
Fan#: 63761
What I Drive: 2003 Focus/1993 Mustang 'vert 5.0
FF Reputation: 3 substanger Good Standing Member
What you are describing actually sounds normal to me. Your pedal will initially be soft and it will go to the floor as you pump the brakes after installing new pads until the pistons are firmly seated against the new pads and the new pads make contact with the rotors. Once that happens, your brake pedal should be hard. If I'm reading your post correctly, this is what is happening. Once you stated your pedal was hard, you didn't mention again the soft pedal that went to the floor.
Basically what happened is when you pressed in the caliper pistons to install the new pads, you placed the pistons all the way into the caliper housing. Upon pressing the brake pedal after installation, that piston has to reseat against the pads and then the rotors which is what caused the pedal to go to the floor.
Are your brakes STILL soft and spongy when depressing after SEVERAL pumps?
2003 Focus. Former U.S. Navy Submariner-13 yrs. 2nd career-Ford driveability tech-8 yrs. 3rd career-vehicle service contract mechanical claims adjuster for Zurich North America (aftermarket warranty) and U.S. Air Force reservist.
substanger is offline
Old 04-17-2009, 02:35 AM   #3
rickster6144
Fan#: 64412
thanks for he reply....yes they are pumped up to the piston to take in to account for the pads and piston moving back in to place when renewed..and are still soft/spongy after a lot of pumping..got the same symptoms as a fluid leak without any signs of a leak have checked for a leak through out the whole system 4 times.
Old 04-17-2009, 01:33 PM   #4
substanger
Fan#: 63761
The only thing I can think is that when you compressed the pistons, you forced the fluid out of the calipers and back into the master cylinder, but it was overfilled and leaked out. When you pushed down on the brake pedal, the calipers filled back up, but somehow got some air into the system.
If you somehow introduced air into the system, the only way to correct is to bleed the entire system.
Old 04-17-2009, 02:54 PM   #5
rickster6144
Fan#: 64412
sorted thanks it was the master cylinder rubbers damaged when the pistons forced back in to caliper thanks again for your time
Old 04-17-2009, 04:23 PM   #6
substanger
Fan#: 63761
Thanks for the update. Glad you got it figured out.
Old 11-13-2012, 11:29 AM   #7
Morpete
Fan#: 105976
What I Drive: 2013 Performance Blue ST
FF Reputation: 1 Morpete Good Standing Member
Hey guys, I'm new here and joined to talk about the problem I am having with this too. (2006 with 140 000 KM)
What rubbers in the master are you referring to? When I look online I can only find replacement masters. Thanks for the help,
Pete
Morpete is offline
Similar Threads
brakes :/ subtleshift Brakes, Suspension & Body Chassis 2 09-06-2008 11:47 AM
Problem when power bleeding brakes tt460 Brakes, Suspension & Body Chassis 12 11-07-2007 01:21 AM
Four Wheel Disc Brakes? GregsWhiteFocus Brakes, Suspension & Body Chassis 6 07-08-2005 10:52 AM
Disk brakes gitar111 Brakes, Suspension & Body Chassis 1 06-08-2005 10:37 PM
SVT Big Brakes - 2 piston caliper SVT ewx ca SVT Performance (2002-2004) 3 07-08-2004 05:56 PM
Focus Fanatics Ford Focus Forum offers many fun ways for you to engage with other Ford Focus Owners from across the world. Whether it be about the aftermarket performance modifications, technical how-to's, European tuned suspension or awesome fuel economy similar to the Cadillac ATS-V, Ford Fusion and Acura TLX. You can find all Ford Focus and Focus ST related information here. Join our Ford Focus discussion forums and chat with local Focus enthusiasts in your area.
