Suspension noise - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 07-18-2004, 12:46 AM   #1
Sagent00x
Fan#: 9779
What I Drive: 2001 S2 ZX3, liquid gray
FF Reputation: 1 Sagent00x Good Standing Member
Suspension noise
I have an '01 S2 ZX3, and I have been experiencing a squeak/creak from the front and rear suspension lately, and it's getting worse. It sounds when I go around corners, and when the suspension flexes over buymbs at slow speeds (dirt driveway, potholes, etc.). Sometimes the noise appears to be coming from the steering column also.
I can make the rear susp. creak while it is parked by rocking the car with my hands. However, it only happens witht he parking brake applied. I took it to my local Ford repair shop, and they couldn't make it make noise when they drove it (go figure, the morons...), so they sprayed the bushings with silicone spray and that was that.
Does anyone else have this problem? What can I do? Help!
Sagent00x is offline
Old 07-18-2004, 09:52 AM   #2
downloader
Fan#: 10606
What I Drive: wagon
FF Reputation: 1 downloader Good Standing Member
try lubricating the rear brake linings, they could have rust between them and the back plate. Good luck.
www.bluewhippet.net
downloader is offline
Old 07-18-2004, 12:53 PM   #3
Sagent00x
Fan#: 9779
that could help, thanks. I'm till owndering why the suspension system makes noise all around whenit flexes. It's annoying and embarassing...
Old 07-18-2004, 02:11 PM   #4
BornAgainFordOwner
Fan#: 9408
What I Drive: 2004 Liquid Grey ZX3 PZEV 5Sp.
FF Reputation: 7 BornAgainFordOwner Good Standing Member
If you decide to lubricate the "brake linings", be sure to use a high temperature silicone grease for brake parts. There should be a couple of raised areas on the back plates that the brake shoes slide against when they move. Apply just a film of grease on those areas after cleaning off any rust.
BornAgainFordOwner is offline
Old 07-18-2004, 02:32 PM   #5
focaltech
Fan#: 490
What I Drive: 2001 Pitch Black ZX3
FF Reputation: 1 focaltech Good Standing Member
Buy-Sell-Trade Rating: (-1)
There is nothing wrong with the rear brakes most foci I have been in do this.
focaltech is offline
Old 07-18-2004, 02:48 PM   #6
downloader
Fan#: 10606
What I Drive: wagon
yes I know but he said the noise happens when the hand brake is on
Old 07-18-2004, 02:53 PM   #7
focaltech
Fan#: 490
When you park the car on a grade, put the handbrake on and get out, the suspension unloads and puts some additional tension on the rear brakes. thats where the noise comes from.
As far as the front creaking, take your car to be checked out. It can be many things.
Old 07-18-2004, 05:21 PM   #8
goinloco1
Late for Dinner
goinloco1's Avatar
Fan#: 8529
What I Drive: kermit
Points 14,748, Level 78
Points: 14,748, Level: 78 Points: 14,748, Level: 78 Points: 14,748, Level: 78
Level Up 75% Completed
Forum Activity 12%
FF Reputation: 90 goinloco1 Excellent Standing Member
check with the dealership, there's a tsb out about the suspension creeking.
tsb 03-15-3 aug 03
goinloco1 is offline
Old 07-19-2004, 08:00 PM   #9
jeanniebigham
Fan#: 10687
What I Drive: 02 blue zx3
FF Reputation: 1 jeanniebigham Good Standing Member
i have a problem with my 02 zx3 it started with a noise when you made a right hand turn while engaging the clutch and i took it to my local dealership and they have had it for a month now and said that they have replaced the hub, tie rods, spindle, brake calipes and discs and pads and axles and today when i went to dealership i pulled off the lot and it started making the noise in every move i made and when i went to go around a car the steering felt like it wasn't responding and they swear it is my aftermaket struts and springs which i just had put on 2 weeks before i noticed the problem and it is the apex sport kit does any body have any kinda insight about this because i am lost and getting mad with it please help
jeanniebigham is offline
Old 07-20-2004, 07:52 PM   #10
iamtwisted
iamtwisted's Avatar
Fan#: 10134
What I Drive: 2001 Amazon Metalic Green Ford Focus Wagon SE w/2.0 Zetec
FF Reputation: 1 iamtwisted Good Standing Member
My 01 wagon was making that same squeeky noise and I could only pin point it to somplace in the front suspension, so I took it in under warranty and the dealer ended up changing the front stabalizer links. I haven't heard the noise since.
iamtwisted is offline
Similar Threads
How how lowering your suspension affects suspension geometry tb1999 Brakes, Suspension & Body Chassis 24 07-28-2012 04:10 PM
Front Suspension damping noise omjaco Wheels & Tires 4 07-06-2009 08:30 AM
2008 Suspension Noise bhohn0 General Technical Chat 18 01-08-2009 11:31 PM
moog endlinks.../my suspension noise JiuceBox General Technical Chat 3 10-30-2008 03:00 AM
Front Suspension Noise... 01FocusMike General Technical Chat 2 05-01-2007 01:56 AM
