Where has CaysE's SVT been? Build thread time! - Page 20 - Focus Fanatics
Old 06-04-2009, 10:49 AM   #191
NemesisEnforcer
Force-Powered Focus
NemesisEnforcer's Avatar
Fan#: 48598
What I Drive: LIQUID GRAY 2005 ST
FF Reputation: 352 NemesisEnforcer Outstanding Standing MemberNemesisEnforcer Outstanding Standing MemberNemesisEnforcer Outstanding Standing MemberNemesisEnforcer Outstanding Standing Member
did you do some fuel upgrades though, that the ecu cannot compensate for?
GIVE DUE REP!! ST Crew #78 /Duratec Crew #91
Go Pats!! Go Green!! Go Sox!! Go B's!
Seeker of Wisdom, LG Crew #1
Resident Sith Lord & Jedi Master, MMA
Thx to those in the military.
NemesisEnforcer is offline
Old 06-04-2009, 11:47 AM   #192
mellephants
omn-nom-nomnomnomnom
mellephants's Avatar
Fan#: 52400
What I Drive: 12 SE, 91 DR350S, 74 CL360
FF Reputation: 12 mellephants Great Standing Member
Buy-Sell-Trade Rating: (15)
the focus uses PWM to control its fuel injectors. you said you're on a base tune from McNews? perhaps you should call them... make sure you're using the injectors they set up the tune for.
SCT PRP FTMFW!
mellephants is offline
Old 06-04-2009, 12:53 PM   #193
CaysE
EDM Specialist
CaysE's Avatar
Fan#: 22059
What I Drive: Blown red SVT
FF Reputation: 80 CaysE Excellent Standing Member
Buy-Sell-Trade Rating: (13)
Compression is 30psi! I don't know how I did it, but the crank must of somehow gotten 180* out of phase. All the pictures I'm looking through show cylinders 1 and 4 at TDC though, and the cams appear to be in the correct position.
If I did somehow manage to get the crank 180 degrees off, I fear I have bent valves.
CaysE is offline
Old 06-04-2009, 02:21 PM   #194
NemesisEnforcer
Force-Powered Focus
Fan#: 48598
ohhh nooooooooooo....aughhhhhhhhhhh
Old 06-04-2009, 02:39 PM   #195
mellephants
Fan#: 52400
an even 30 psi on all cylinders? wow... not good.
did you use the OEM Ford SVT headgasket (not some silly thick one)?
You could try a few drops of oil to see if that bumps your compression up to normal.
Also, double-check your valve lash - Are you sure you got all of them right? If your lash is too tight (or zero), then you won't get good compression.
I'm not sure if it should start with only 30psi... anyone else seen theirs that low?
SCT PRP FTMFW!
Old 06-04-2009, 04:27 PM   #196
illinipo
Token Engin-nerd
illinipo's Avatar
Fan#: 37693
What I Drive: dirty wag; Party; Bavarian phallus
FF Reputation: 272 illinipo Outstanding Standing Memberillinipo Outstanding Standing Memberillinipo Outstanding Standing Member
Buy-Sell-Trade Rating: (19)
just some random thoughts, Matt sent me in here and I thought I'd throw in my somewhat experienced 2 cents...
30psi is probably due to fuel washing down the cylinder walls.
if you are on the stock tune using bigger injectors, that is your problem.
The Focus does not have a fuel pressure regulator. There is the pulse damper and also the delta pressure sensor. The pressure sensor uses the vac line to tell the difference (delta) between the rail side and manifold side of the injectors. Then the ECU uses this to tell the fuel pump how much pressure to put in the rail to achieve 40psi across the injectors.
make sure your crank position sensor is plugged in.
have you checked spark yet?
i have some more random thoughts but answer those first and we'll go from there.
Originally Posted by Dennis_Grant
Remember this list: Bilstein; Penske; Koni; Ohlins; Sachs; Dynamic Suspension.
Not on this list? Almost certainly crap.
SUV this!
illinipo is offline
Old 06-04-2009, 06:05 PM   #197
CaysE
EDM Specialist
CaysE's Avatar
Fan#: 22059
Where do I put the drops of oil?
CaysE is offline
Old 06-04-2009, 07:05 PM   #198
mellephants
Fan#: 52400
in the cylinder you're testing, right before you test it (via spark plug hole)
Someone correct me if I'm wrong, but no more than a teaspoon or so should do it.
The oil should fix the problem if its a ring issue (from gas on them, or because they are shit, or whatever)
SCT PRP FTMFW!
Old 06-04-2009, 07:06 PM   #199
illinipo
Token Engin-nerd
illinipo's Avatar
Fan#: 37693
Spark plug holes.
With as much gas as you've put in there you're going to need a full teaspoon or two.
Posted via FF Mobile
illinipo is offline
Old 06-04-2009, 09:30 PM   #200
NemesisEnforcer
Force-Powered Focus
Fan#: 48598
ugh, how is this coming along?
Similar Threads
My work in progress 2004 PZEV sedan mjmallon Ford Focus Builds & General Showroom 53 10-04-2009 04:14 AM
**Vote for Focusfanatics.com Ride of the Year 2008** Chick Ride of the Month 85 07-31-2008 07:11 PM
Wiring up Recarro Seats Focusedat50 MK1 Interior Mods & Upgrades 9 02-25-2008 09:12 PM
SVT Build #? Jerk SVT Performance (2002-2004) 14 12-23-2006 10:02 PM
Mopar power that Ford needs to imitate hbm1 General Forced Induction 72 09-20-2004 04:57 PM
Focus Fanatics Ford Focus Forum offers many fun ways for you to engage with other Ford Focus Owners from across the world. Whether it be about the aftermarket performance modifications, technical how-to's, European tuned suspension or awesome fuel economy similar to the Acura TLX. You can find all Ford Focus related information here. Join our Ford Focus discussion forums and chat with local Focus enthusiasts in your area.
