Stealth CAI--What to expect and what NOT to do. - Page 9 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 09-14-2013, 09:54 AM   #81
DerbyCityGinger
DerbyCityGinger's Avatar
Fan#: 106672
What I Drive: 2005 Sonic Blue ZX5
Points 240, Level 4
Points: 240, Level: 4 Points: 240, Level: 4 Points: 240, Level: 4
Level Up 80% Completed
FF Reputation: 1 DerbyCityGinger Good Standing Member
Got it on last night! I always have trouble with those black screws that you have to pry out but i just pulled the fender liner back enough not to have to worry about them.
Since I didn't have the stock MAF tube and resonator on the car to begin with all I had to do was get that old airbox out. Two of the bolts were so rusted I couldn't really turn them. Solved the problem by yanking down on it hard enough to break the airbox off at the pastic held in by the bolts. It's a little unprofressional and not very clean looking but you gotta do what you gotta do.
The K&N RX-4120 filter that BlazingCopper_ZX3 reccommended on his website (see link in the OP) worked perfectly. I attached it to the stock MAF tube I got from _fifth_ using some of the filter oil (it wasn't gonna be hard to fit without it but it is suggested), screwed my old MAF sensor into it and started to bolt it onto the car with the 1/2" bolt. This is the only part that may not be done right and will have to be fixed sometime down the road. The screw didn't go into the hole all the way. I checked to make sure it was the right spot (it was) and tried again. There could be rust or debris in there but its good enough for now.
Bolted the resonator with hydrocarbon trap onto the MAF tube. The TB boot was already attached to the resonator. If anyone is going to do this mod, do the opposite and attach it to the TB first. It took a while to get it on the TB properly but eventually I just broke out the filter oil, lubed it up and twisted it on there. Got the other side on the resonator and tightened the clamps. I'm not sure exactly what it is but theres some hose or valve or something that goes into the boot.
Then I took the air dam that I melted the cracks back together (practice for the bumper cover) and started to bolt it to the front holes in the bumper, then moving towards the sides and finally the driver side fender liner (the passenger side is cut there, but i did just get a new one to put on there. Whats awesome about the air dam being on there is that since its screwed into the bumper cover, its straightened the bent and cracked parts of the bumper cover and makes it look noticeably better.
I put the drivers side tire back on and was going to replace the cut fender liner, but the car had enough modding for the night and the lugs wouldn't come off with the tire iron. Need to have someone with an impact gun help me out.
Turned on the car and it idles about the same as the old SRI, haven't taken it for a test drive yet.
EDIT: Just did the test run to take some things back to my house. I can't really tell if it has better peformance than the old shoddy custom short ram but I do love it for the simple reason of being able to hear my engine instead of WHOOOOOOOOOOOOOOOOOOOOOSH from air being sucked into the SRI. It feels a little quicker and crisper but I'm not sure if that's real or just my imagination.
Focus 1: 2005 Sonic Blue ZX5 SE auto
Focus 2: 2007 Aqua Blue ZX5 SES auto (girlfriend's)
Focus 3: 2002 Sonic Blue SVT (parts car, no engine)
DerbyCityGinger is offline
Old 08-03-2014, 04:38 PM   #82
CorgiDude
Fan#: 130442
What I Drive: 2007 Gray ZX4
Points 20, Level 1
Points: 20, Level: 1 Points: 20, Level: 1 Points: 20, Level: 1
Level Up 39% Completed
FF Reputation: 1 CorgiDude Good Standing Member
Just performed this mod today! I am quite pleased with the results. I disconnected the negative battery cable while I was working, and reconnected it when I was ready to fire her up.
I just crawled under my car and secured the cone filter to the MAF tube after I had yanked the old factory element off.
The car was a little hesitant to start the first few cold starts, but now she seems to be running smooth with no Check Engine light. :)
I can't feel much of a difference personally, but just for looking at how filthy the factory element was and how much better the engine sounds, I am pleased with the results.
CorgiDude is offline
