ATX Manual Fluid Flush - Focus Fanatics
Old 04-10-2009, 04:03 PM   #1
Focusedat50
It's been fun.......
Focusedat50's Avatar
Fan#: 1409
What I Drive: Boosted ZX5 ATX - 179WHP/158TQ
FF Reputation: 2 Focusedat50 Good Standing Member
Buy-Sell-Trade Rating: (30)
I have read the sticky on changing/flushing the ATX fluid however one part I'm still not clear on:
Here's what I did as per Dezurtrat's recommendation/experience. I started the engine and drain was in there. once it trickled out. I stop engine, added about 2.5 quarts and start engine.. Repeat. Until the fluid started to come out clean..er cleaner.. and no more stinky smell!!
Are you supposed to be adding fluid as the engine is running and the fluid is being pumped out or as said above you run the engine until it starts to trickle out, stop...add fluid and repeat? Is there a possibility of burning anything up via this method as there would be a brief period of time that the tranny will have no fluid? This method flushes out the cooler as well as the torque converter?
You see what you want to see and you hear what you want to hear.........
Focusedat50 is offline
Old 04-13-2009, 09:39 AM   #2
Focusedat50
Fan#: 1409
Nobody??
Old 04-13-2009, 10:33 AM   #3
whynotthinkwhynot
Captain TMI
whynotthinkwhynot's Avatar
Fan#: 18416
What I Drive: 05 ZXW; 02 Windstar; 13 C-Max SEL
That method replaces the fluid in the torque converter as well. It is what my factory Ford shop manual states as a pump flow check and flush service. You can add fluid as it is being drained or not. So long as you don't just let the engine idle for hours and hours, you shouldn't damage the torque converter.
It doesn't take long to pump all the fluid out, which is why I recommended to people that they simply crank the engine with the starter to pump fluid out. You should've pumped all your fluid in about 5 seconds if you'd already changed the filter and not refilled from that exercise. If I had an ATX, I'd also consider using this method to pump out fluid before dropping the pan to change the filter.
Be eclectic.
You're special aren't you.
whynotthinkwhynot is offline
Similar Threads
ATX fluid question Focusnewb General Technical Chat 5 04-05-2006 05:55 PM
Manual Tansmision/transaxle fluid walkerjw99 General Technical Chat 7 09-08-2005 12:51 PM
Transmission Fluid ZX5 Manual 5 speed Transmission walkerjw99 ZETEC Performance (2000-2004) 2 09-07-2005 07:45 PM
Manual Trans fluid JP Ford Focus & General Car Chat 4 01-19-2004 12:30 PM
Manual Trans Fluid JP General Technical Chat 3 01-18-2004 03:06 AM
