tps wire question - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 04-04-2009, 03:20 PM   #1
mustangt69
Fan#: 62096
What I Drive: silver
FF Reputation: 1 mustangt69 Good Standing Member
tps wire question
was testing my tps and decided to see voltages when running. one was 5.06, another was .89(fluctuates at idle between .89-.92) the third was at .06.... what is this wire for? the number changes as you open the throttle... i am trying to figure out if my tps could be bad even thought the main voltages are correct- .89 to 4.65 no blips
mustangt69 is offline
Old 04-04-2009, 03:53 PM   #2
three_X_Z
Fan#: 883
What I Drive: 2000 ZX3
Points 819, Level 15
Points: 819, Level: 15 Points: 819, Level: 15 Points: 819, Level: 15
Level Up 19% Completed
FF Reputation: 1 three_X_Z Good Standing Member
That sounds about right for throttle voltage. The only thing to keep in mind is that you cant really test a tps with a regular meter because if the voltage drops out you won't really see it unless you are using a graphing meter.
three_X_Z is offline
Similar Threads
Need help with Remote Start Alarm install briandg510 Car Audio, SYNC, MyFord Touch & Electronics 15 11-24-2012 05:34 AM
Ground Wire Project for Duratec Beatjunkie DURATEC Performance (2003-2007) 29 03-09-2008 09:49 PM
ST170's headlight wireing? 5speedZX3 MK1 Focus 19 03-21-2005 09:33 AM
Need help! Wire cover question MachSamurai MK1 Focus 1 03-07-2004 02:36 AM
Which wire For TPS HKSfocusHKS General Forced Induction 0 11-05-2003 05:46 PM
