Camber and Spring question on 3yr old sportlines - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 04-04-2009, 02:18 AM   #1
johnsonw84
Fan#: 21048
What I Drive: 2002 Liquid Gray zx3
FF Reputation: 1 johnsonw84 Good Standing Member
Question Camber and Spring question on 3yr old sportlines
Alright i have a couple of question i pretty much know for a fact that my sportlines have sagged over the years as ive had to move a couple of times with my car and it being loaded down with a lot of weight on shot struts and shock cant be good. So im getting ready to replace my shocks and struts and was looking at my front camber and it far from stock with 1`degree alignment kits full adjusted out, so i geuss the question is anyone runin with that much negative camber up front id say 1.5 to 2.5 degrees? also anyone ever use either of these camber kits? also if i get the chance tomorrow il post a pic of my front end
http://www.advancespeedshop.com/prog...40-p-4805.html
http://www.wildponymotorsports.com/p...IDCategory=667
johnsonw84 is offline
Old 04-04-2009, 10:27 AM   #2
RobZX3_2006
Fan#: 36811
What I Drive: 2006 Dark Toreador Red ZX3 SES
FF Reputation: 3 RobZX3_2006 Good Standing Member
I'm pretty low on H&R coilovers without front camber correction and -1.8* camber. Wear seems to be pretty even across the tire. As long as you get your toe set to 0 for both sides, you can run a little over 2 degrees negative without seeing additional wear on your tires.
RobZX3_2006 is offline
Old 04-04-2009, 10:55 AM   #3
Insane
Adam
Insane's Avatar
Fan#: 51468
What I Drive: 2003 Infra Red ZX3
FF Reputation: 41 Insane Great Standing Member
Hell I have -2.1 on all for corners of my car with -0.03 toe front and 0.03 toe rear. It rides great and wear seems to be just fine.
-Zetec Crew #215
Volant Intake, SVT Snorkle, By past A/C, AFX UDP, Copper Plugs, 9mm Plug Wires, Toms Tune, Roush springs/shocks/struts, Eibach Sway-Bars, C-F-M Racing Lower Engine Mount.
Insane is offline
Old 04-04-2009, 12:57 PM   #4
1-ST
1-ST's Avatar
Fan#: 53127
What I Drive: various duratec powered vehicles
Points 721, Level 14
Points: 721, Level: 14 Points: 721, Level: 14 Points: 721, Level: 14
Level Up 21% Completed
FF Reputation: 10 1-ST Great Standing Member
Plenty of autocrossers are running around with -2.5 on their daily drivers. It's only a problem is you have lots of toe with it.
05 ZX4 ST - parts donor. Daily driver until a rock found the oil filter and locked the motor.
08 S Coupe - autocross toy. Less weight and more tire.
06 Ranger - lowered commuter and parts hauler.
1-ST is offline
Old 04-04-2009, 01:46 PM   #5
johnsonw84
Fan#: 21048
thanks guys,the only toe problem i have right now is bent tierod on the pas side that il be fixing monday. still anybody used either one of those alignment kits
Tags
alignment , camber , eibach , sportlines
Similar Threads
SVT spring question focusTNR29 Brakes, Suspension & Body Chassis 2 07-02-2006 12:47 PM
suspension/ camber kit question gump1114 General Technical Chat 2 03-13-2006 06:10 PM
H&R Spring Question HPFocus85 Brakes, Suspension & Body Chassis 11 07-29-2004 07:37 PM
