Fuel Pump screen - Ford Focus Forum, Ford Focus ST Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum > Ford Focus Tech Discussions > General Technical Chat
Old 04-03-2009, 03:47 PM   #1
RallieConGoggle
RallieConGoggle's Avatar
Fan#: 50774
What I Drive: 2007 CD Silver ZX4
FF Reputation: 9 RallieConGoggle Good Standing Member
Fuel Pump screen
My check engine light came on, and gave a code for random misfires, but no code for MAF or O2 sensors and the coil pack is brand new, so I took a look at the fuel pump. WHen I removed the pump, I saw two screens sitting in the bottom of my fuel tank, one large one and one that fit into the bottom of the pump.
Can anyone tell me where the big one goes? It looks like it goes in the opening for the fill line and I knocked it out when I was trying to syphin (don't buy a "transfer pump" from autozone!)
Also, there's something that looks like a breather element on the side of the pump. Where is the pump's intake? Could the fact that this screen fell out be the root cause of my problem?
I'll post pics later.
Thanks,
Rally with your goggles on!
2000 Pitch Black ZTS Auto (230,000+ miles)
2007 CD Silver ZX4 SES 5spd
Zetec Crew #190
RallieConGoggle is offline
Old 04-04-2009, 09:59 AM   #2
RallieConGoggle
Fan#: 50774
Pics
Zetec Crew #190
Old 04-04-2009, 10:05 AM   #3
Junk
Junk's Avatar
Fan#: 61320
What I Drive: 2011 lime green metallic Fiesta ses
FF Reputation: 1 Junk Good Standing Member
If I'm right, those screens are pre-filters for the fuel, if they're missing from the pump, who knows what it picked up from your fuel tank. It could be partially blocked. But I could also be wrong
If food needed pleasing, you'd suck all the seasoning off. Suck it off! - Isaac Brock
Junk is offline
Old 04-04-2009, 10:14 AM   #4
RallieConGoggle
Fan#: 50774
I'm thinking you're right. I bought the new pump from autozone for $65, but it's not the whole assembly, just the pump. So I'm going to have to take it apart and clean it out and put the new pump in. I'll try to post some more pics, but my battery is low on the camera.
Zetec Crew #190
Old 04-08-2009, 09:39 AM   #5
RallieConGoggle
Fan#: 50774
Inside of pump and sender assembly:
After I cleaned it with a Isopropyl Alcohol, a rag, q-tips, and other implements of destruction:
The terminals on the auto zone replacement pump are hard to read, but it needs to be wired as shown in this picture with the extra connector supplied with the pump:
I used Isopropyl Alcohol, but ethanol would have been better. It's best to let the alcohol dry before putting the system back together, which should only take about 10 minutes. I also fully drained the fuel tank and wiped it clean with fresh gasoline. I refilled the tank with fresh gasoline to avoid introducing any contaminants back into the system with the new pump. As soon as I reconnected the battery and started the car, there was no check engine light. It's been running for almost a week with no trouble.
I blame Michigan roads for knocking that screen out and and allowing that nastiness in my fuel pump.
Zetec Crew #190
Old 04-08-2009, 09:47 AM   #6
penguin
Fan#: 21700
What I Drive: 2005 Infrared ZXW
FF Reputation: 109 penguin Excellent Standing Member penguin Excellent Standing Member
Why do you say that?
penguin is offline
Old 04-08-2009, 09:54 AM   #7
RallieConGoggle
Fan#: 50774
Ethanol is better and cleaning oils and contaminants. It would have done a little bit better job of breaking up the grime in the nooks & crannies that I couldn't reach with my q-tips and implements of destruction. Also, ethanol is more compatible with gasoline fuel systems. It's really not a big deal, and it did a fine job, but if you can buy Everclear in your state, I would recommend using that instead of Isopropyl.
I don't recommend drinking the Everclear, I had some bad experiences with that in college. I'm planning on getting some when I go back to Indiana to use for cleaning.
Zetec Crew #190
Old 04-08-2009, 10:01 AM   #8
RallieConGoggle
Fan#: 50774
P.S. To take apart the "bucket" on the assembly, you'll need a 3/16" (I think) open-end wrench. It's pretty hard to do it with a socket, but I managed.
Zetec Crew #190
Old 11-03-2010, 10:35 AM   #9
RallieConGoggle
Fan#: 50774
FYI: I lost the the round screen with the black plastic X on it while doing this job. This fits into the end of the fill hose to prevent siphoning.
I found it about a year later while I was mowing the lawn; it was torn. Kind of a funny story, I guess.
Zetec Crew #190
Old 11-03-2010, 10:35 AM   #10
RallieConGoggle
Fan#: 50774
Zetec Crew #190
Similar Threads
Need help with this code. 9318 DomestikZx3 General Technical Chat 17 07-11-2012 09:59 AM
Using the Fuel Pump to empty the tank - carefully a_2000_se Ford Focus & General Car Chat 3 03-18-2009 12:34 AM
How To: Return Fuel System Turbo Turtle General Forced Induction 40 01-10-2009 09:00 PM
Fuel pump swap Ezpimpin General Technical Chat 4 07-28-2008 12:14 AM
A few Fuel pump pictures viney266 General Technical Chat 2 05-12-2008 09:35 AM
