Go Back   Focus Fanatics > Focus Focus Deals > Group Buys & Hot Deals!
Group Buys & Hot Deals! This section is the place you'll find Hot Deals and Special Vendor Discounts offered by our Authorized Vendors and Approved Group Buys.
Old 03-31-2009, 08:25 AM   #1
K Dog
FF Affiliate
K Dog's Avatar
Fan#: 23554
What I Drive: Car
Buy-Sell-Trade Rating: (16)
[:)][:)][:)][:)][:)][:)]Massive Absolute Torque Plate - Duratec[:)][:)][:)][:)][:)][:)]
A must for your hardcore engine build. Another Massive exclusive!!! No one else offers these for the Duratec!!!
The torque from a properly fastened cylinder head can impart significant distortion to the bore. Rings do not seal properly and scuffing is often the case if the engine overheats. By installing the Massive Absolute Torque Plate, these problems are non existent, leading to more consistent tolerances, better sealing and more power. This plate is torqued to the identical specs while it is being machined, thus reproducing the exact same forces. This will ensure the truest machining for the best ring seal.
Made in house in the USA of 3" pure 6061 aluminum (most representent of the aluminum head is mimics). 90mm Bore size allows for ample tool space and over sized piston applications. 4340 steel inserts at dowel locations ensure long service life and accurate locating every time. Holes are countersunk allowing usage of any OE of aftermarket head bolt/stud. Plate is clearanced so pressed on water outlet on block need not be removed to mount. Massive M logo engraved on top so folks know you use the best. Anodized Massive Purple for extra wear surface durability and handsome good looks. No hardcore Duratec race shop should be without it!!!
$697
find it Here
K Dog is offline
Fan#: 1
Similar Threads
torque specs... jrc0210 ZETEC Performance (2000-2004) 5 12-14-2006 08:55 PM
DTC Codes (Detailed Descriptions) S2 General Technical Chat 13 12-11-2006 11:06 AM
Response to Tom in Focus Power Mis-Info Thread belacyrf General Forced Induction 0 09-10-2006 02:40 PM
What is the SVTF capable of part II jonrjen SVT Performance (2002-2004) 33 04-10-2005 09:19 AM
