2000 Focus LX running rough/ shutting off - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 03-25-2009, 09:07 PM   #1
REBELoffaLEASH
REBELoffaLEASH's Avatar
Fan#: 63741
What I Drive: 2000 Blue LX Sedan
FF Reputation: 1 REBELoffaLEASH Good Standing Member
Well, here we go. My Focus is running rough/ vibrating, and shut off on me twice on the way home today. I'm thinking it's the timing belt/ tensioner. Plugs and wires are new. Any suggestions?
DO IT BEFORE IT'S ILLEGAL!!!
2000 Ford Focus LX sedan CVH 2.0
REBELoffaLEASH is offline
Old 03-25-2009, 09:46 PM   #2
whynotthinkwhynot
Captain TMI
whynotthinkwhynot's Avatar
Fan#: 18416
Points 27,933, Level 98
Level Up 59% Completed
Forum Activity 10%
It could also be a fuel pump.
How long does it take your fuel pump to charge the fuel system? If it runs longer than 10 seconds, you have a bad fuel pump. Depending on your mileage you should check the timing belt. Just remove the inspection cover, and use a felt tip marker to mark the center of the timing belt that you've looked at. You should be able to twist the belt to look at the ribbed side of the belt between the cam sprockets. You're looking for missing ribs, cracks, or worn off ribs. On the back of the belt- what you can see easily- you're looking for cracks, and fibers showing through the belt. Mark whatever you've checked on the back side, then bump the engine with the starter to inspect more of the belt. If you find enough damage, give up and resign yourself to all that you should do when replacing the timing belt.
Be eclectic.
You're special aren't you.
whynotthinkwhynot is offline
Old 03-25-2009, 10:13 PM   #3
misfire
Moderator
misfire's Avatar
Fan#: 31379
What I Drive: 2012 SEL Hatch, 2014 Mazda CX-5
Points 17,083, Level 83
Points: 17,083, Level: 83 Points: 17,083, Level: 83 Points: 17,083, Level: 83
Level Up 47% Completed
Forum Activity 7%
FF Reputation: 31 misfire Great Standing Member
Buy-Sell-Trade Rating: (13)
i just had to replace my ignition coil. see if it's cracked or arcing
Will aka Misfire
2003 LX "traded in"/2010 SES "traded in"/2012 SEL Hatch "current"
misfire is offline
Old 03-26-2009, 11:53 AM   #4
justjake
Fan#: 60533
What I Drive: 2001 zx3
FF Reputation: 7 justjake Good Standing Member
Check you compression to see if it's a timing belt, and also the noise when you crank will sound like the engine is not "hitting".
Check the coil with a dvom. Looking for cracks won't tell you it's bad or not.
And dude that always says to check the fuel pump...it's not always the fuel pump!
justjake is offline
Old 03-26-2009, 08:36 PM   #5
greddy339
Fan#: 63304
What I Drive: 2k ford focus zx3
FF Reputation: 9 greddy339 Good Standing Member
how will checking compression show a timing belt problem? if the car starts back up upon stalling it is def not the belt in any way! either a fuel or electrical problem...seeing that you have a 2k focus..has ford done the fuel pump recall on your car yet? if not get it done and it will probably solve your problem..
greddy339 is offline
Old 03-26-2009, 08:39 PM   #6
Red01Focus
Fan#: 40437
What I Drive: 2001 Infa Red SE
Points 11,103, Level 69
Points: 11,103, Level: 69 Points: 11,103, Level: 69 Points: 11,103, Level: 69
Level Up 64% Completed
FF Reputation: 10 Red01Focus Great Standing Member
Buy-Sell-Trade Rating: (56)
check your maf sensor.
SEDAN REVOLUTION #13
Red01Focus is offline
Similar Threads
Big plans for tiny Focus remusrm Ford Focus & General Car Chat 50 08-19-2009 02:51 PM
Focus Light Bulb Guide (MOD STICKY THIS) TKE_Quailman MK2 Focus 13 11-09-2008 05:36 PM
2008 Focus SpcghostII Ford Focus & General Car Chat 55 09-17-2007 09:05 PM
Engine Still Running Rough!!! sadimus General Technical Chat 12 04-12-2007 12:33 PM
Rough idle on focus 2000 ross2k6 General Technical Chat 14 07-06-2006 10:10 PM
