Need some help here, cant get my ecu into open loop... - Ford Focus Forum, Ford Focus ST Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum > Ford Focus Tech Discussions > Focus Tuning Chat
Old 03-24-2009, 06:10 PM   #1
illinipo
Token Engin-nerd
illinipo's Avatar
Fan#: 37693
What I Drive: dirty wag; Party; Bavarian phallus
FF Reputation: 272 illinipo Outstanding Standing Member illinipo Outstanding Standing Member illinipo Outstanding Standing Member
Buy-Sell-Trade Rating: (19)
I called my SCT dealer but theyre closed for the day and searched in the sct forums just to find out im doing things right so, figured i'd make a post because i am clueless.
The problem is quite simple, I am commanding open loop but my open loop flag stays at 0 and my stft's are all over the place (not just showing back the base table). This is at idle up to about 20 counts of throttle from start all the way until i turn off the motor (so, all conditions). Since the afr sits around 16 the longest ive gone is about 30-40 seconds like this, scared to go any longer. The stft slowly drops down until it pegs at .75, and at that point afr goes to 13.5. If I tap the throttle stft goes back to 1 and it starts over again.
I have the front o2 unplugged and the heater turned off so I could put my wideband in the stock front o2 location (to make OL tuning easier and more accurate). The idea was to just force open loop and tune off the wideband. But i cant force open loop
Things I have done in the tune:
heater switch for bank 1 sensor 1 o2 - changed to 0
TP for WOT table - all set to 0
Fuel Open Loop TP table - all set to 0
Time to Delay Open Loop (for the ECT and RPM conditions) - set to 0.125
Adaptive control switch - changed to 0
(EVAP canister) switch to allow open loop purge - changed to 1
switch to force open loop fuel - changed to 1
HELP please!
Originally Posted by Dennis_Grant
Remember this list: Bilstein; Penske; Koni; Ohlins; Sachs; Dynamic Suspension.
Not on this list? Almost certainly crap.
SUV this!
illinipo is offline
Old 03-24-2009, 07:41 PM   #2
illinipo
Token Engin-nerd
illinipo's Avatar
Fan#: 37693
fwiw I also cannot find the DMR for knock sensor retard.
SUV this!
illinipo is offline
Old 03-24-2009, 08:09 PM   #3
gokart2
Fan#: 31234
What I Drive: 2006 Silver ST w/SAP#1
FF Reputation: 14 gokart2 Great Standing Member
Almost 100% positive because your control hego is unplugged. Reinstall your "front 02" sensor and see what it does. If you have enough wire, throw your wideband in the end of your tailpipe about a foot. Thats what alot of dyno shops do, my be off if you have a leak though.
ST Crew #90
My wife---><----Me
gokart2 is offline
Old 03-24-2009, 08:32 PM   #4
illinipo
Token Engin-nerd
illinipo's Avatar
Fan#: 37693
if I wanted to use my tailpipe I would just use my rear o2 location
i need to get o2 before the cat thats all there is to that argument.
Now, as far as just plugging in the hego, I will give that a try tomorrow. it's raining, and the only way to do it right now is go under the car and get really really wet.
SUV this!
illinipo is offline
Old 03-24-2009, 10:12 PM   #5
1turbofocus
FF Affiliate
1turbofocus's Avatar
Fan#: 1123
FF Reputation: 153 1turbofocus Excellent Standing Member 1turbofocus Excellent Standing Member
Buy-Sell-Trade Rating: (28)
There is no issues with installing the o2 in the rear o2 , But you reading your books im sure you know better then me
You need the front o2 to work the closed loop why on earth would you want to force open loop ? To force open loop there is a setting in the software in 2 places that will keep your Focus in open loop all the time
Customer Support
AIM: hpdyno
Email: hpdyno@aol.com
Phone: 704-249-3745
Site: focus-power.com
Elder 1turbofocus
1turbofocus is online now
Old 03-24-2009, 10:26 PM   #6
illinipo
Token Engin-nerd
illinipo's Avatar
Fan#: 37693
im forcing open loop so I can tune off of my wideband instead of the crappy inaccurate narrowband signal
because of egt changes and many many other variables the rear o2 will read anywhere from .02-.1 lambda lean, this has been proven many times over ON THE DYNO by tuners across the country
If you read my first post you would know that I already changed both those things in my tune.
SUV this!
illinipo is offline
Old 03-24-2009, 11:01 PM   #7
1turbofocus
FF Affiliate
Fan#: 1123
You shouldnt be trying to tune the idle from the wide band , the " crappy inaccurate narrowband signal" If your talking about the stock o2 is what the ECU uses to adjust the fuel trims and what you should also be using to get yours right as well
As for the .1 to .2 Dif in the before and after of the CAT a good tuner would know what the Diff is and allow for it in the tune , as rich as your going to be running that book of yours didnt tell you that the Focus CAT design will stop up and cause engine failure if used with the target AF you will have to be using , it has a very limited life with boost
Customer Support
AIM: hpdyno
Phone: 704-249-3745
Elder 1turbofocus
Old 03-24-2009, 11:23 PM   #8
illinipo
Token Engin-nerd
illinipo's Avatar
Fan#: 37693
Not boosting yet.
I'm also NOT going straight by "my book", I bought the book as a reference not as a teacher. I learn form many sources, your past posts included. It takes a lot to put all of the information available together and on top of that I learn something new every day that I can apply to my tune.
So tomorrow I guess by your advice I will just throw it together and assume some sort of lambda difference after my cat, hopefully it goes into OL when I tell it to at higher TP...
Everyone starts somewhere Tom you gotta realize that we cant all be you on day 1
and for the record i'm not tuning a/f directly with the wideband im tuning the MTF (which as a result tunes a/f). Setting a lambda in the base table and forcing open loop then comparing the wideband output to the base table.... then apply changes to the MTF... that's tuning 101 for 99% of cars on the road that use MAF's and as far as I remember you yourself recommended we should do it that way in antoher thread... I can dig it up if you want.
SUV this!
illinipo is offline
Old 03-24-2009, 11:30 PM   #9
gokart2
Fan#: 31234
Fueling is based off the mass air flow reading, and the conrol hego readings from what i remember. Correct?
ST Crew #90
My wife---><----Me
gokart2 is offline
Old 03-24-2009, 11:32 PM   #10
illinipo
Token Engin-nerd
illinipo's Avatar
Fan#: 37693
I'm not going to answer that since apparnetly I know absofrikenloutely nothing about tuning
SUV this!
illinipo is offline
Similar Threads
Help! Driver's door wont open island_boy49 General Technical Chat 10 04-23-2008 07:13 PM
SVT ECU removal help ExitLeft SVT Performance (2002-2004) 6 03-29-2006 07:20 PM
Xcal 2 And ECU Code djmtrain SVT Performance (2002-2004) 3 03-08-2006 06:10 PM
Trunk won't open. King_of_squirrels General Technical Chat 2 02-04-2006 05:36 PM
Passenger Door Wont Open From Outside ouikikazz General Technical Chat 0 10-22-2005 06:37 PM
