The N/A Zetec Performance Thread - Page 13 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 02-19-2014, 12:45 AM   #121
photn02
Fan#: 116617
What I Drive: Silver
Points 535, Level 10
Points: 535, Level: 10 Points: 535, Level: 10 Points: 535, Level: 10
Level Up 70% Completed
Forum Activity 2%
FF Reputation: 1 photn02 Good Standing Member
Hmmm i was looking at rebuilding my engine for my focus and going ITB.
The Plan so far is:
Suzuki GSXR 750 TB
SVT Lower manifold
Stage 2 Kent Cams
Adjustable Cam Gears
UDP's
PNP head with 1mm larger valves.
etc etc etc
My Question is that i read that if put a 1.8 head on my 2.0 it will increase the CR to about 10.9:1 and with a milling of the head of 0.040 it shuold take me to about 11.0:1.
Is it better to use pistons and rods designed for higher CR or use the 1.8 head?
This is for a weekend car that i will use for some fun with mates who have miatas doing hill climbes.
photn02 is offline
Old 03-23-2014, 02:37 AM   #122
GhostTribute
GhostTribute's Avatar
Fan#: 107929
What I Drive: 2001 Mazda Tribute (2.0L Zetec)
Points 340, Level 6
Points: 340, Level: 6 Points: 340, Level: 6 Points: 340, Level: 6
Level Up 80% Completed
Forum Activity 5%
FF Reputation: 1 GhostTribute Good Standing Member
Anyone here ever instal a set of 30mm exhaust valves in the 2.0 head?
Just looking for some pro vs con information. Was it worth the work enlarging the exhaust seats not?
GhostTribute is online now
Old 03-23-2014, 11:35 AM   #123
1turbofocus
FF Affiliate
1turbofocus's Avatar
Fan#: 1123
Points 51,834, Level 100
Points: 51,834, Level: 100 Points: 51,834, Level: 100 Points: 51,834, Level: 100
Level Up 0% Completed
Forum Activity 32%
Activity: 32% Activity: 32% Activity: 32%
Buy-Sell-Trade Rating: (28)
I have not see any gain worth the cost of the valves unless your shooting for over 400HP I dont feel its worth it
Customer Support
AIM: hpdyno
Email: hpdyno@aol.com
Phone: 704-249-3745
Site: focus-power.com
Elder 1turbofocus
1turbofocus is offline
Old 03-24-2014, 06:33 AM   #124
GhostTribute
Fan#: 107929
Points 340, Level 6
Forum Activity 5%
Thanks for the quick response. Saved me $160.
Old 04-28-2014, 04:43 PM   #125
daspazzZX3
OneOfUs
daspazzZX3's Avatar
Fan#: 133961
What I Drive: chcl gry 02 ZX3 - 5sp
Points 5,487, Level 47
Points: 5,487, Level: 47 Points: 5,487, Level: 47 Points: 5,487, Level: 47
Level Up 69% Completed
Forum Activity 100%
Activity: 100% Activity: 100% Activity: 100%
FF Reputation: 2 daspazzZX3 Good Standing Member
Buy-Sell-Trade Rating: (18)
Wow, I wish I had read this thread before I started my "project"!
Now Im worried Im over doing it but there's no turning back now, DP is in pieces and parts are ordered and mechanic has time involved.
machined head bored 20 over
Comp stg3 Cams
Car had adjustable cams gears, not sure of the vendor....
JE 2618 Forged Aluminum Piston 85.5mm pistons 9.0.1 compression
Eagle 4340 Forged Steel H Beam rods with ARP bolts
ARP Main and head studs
C-F-M billet Oil Pump gear
Ford Racing Oil pump
Clevit Rod Bearings
FX-400 6 puck Clutch luk bearing on slave cylinder
SVT Header and CAT (Header is wrapped in red SickSpeed thermal wrap)
Bosal 2.25 Performance SS exhaust
RS Metal radiator fans
Crower springs with titanium keepers
Bostic SS Thermostat housing. 180 deg thermostat
C-F-M Tubular control arms with M00g ends
Massive speed sway bar end links
Prothane front and rear bushings
This isn't cheap, but I need a capable engine that hopefully will last, I've never had a standard so over reeving was never really an issue. Im sure that is what killed the current engine. Loss of oil and then cylinder 4 lost the rod through the block. Hole is almost the size of a quarter!
Only time will tell, and Im not looking to go 400 hp N/A, but I do want to fly sometimes, both of my stock duretecs seemed to hold their own. i just don't want to kill DP's engine while learning my 5 speed!
"You are a person, No one can forget you, even if it's Good or Bad, you make waves!" #truth #truthinadvertizing...
R.I.P. Pat :-( HN #68 - Focus Takeover #008 - principal defensor para el diablo
daspazzZX3 is offline
Old 05-11-2014, 09:37 AM   #126
GhostTribute
Fan#: 107929
Points 340, Level 6
Forum Activity 5%
Well just finished working a 40 day shutdown and decided to spend the money anyway...lol
+1mm intake and exhaust valves with a 90% valve to throat ratio.
Went with 4 angle on the intake and 3 angle on the exhaust.... have to wait and see what the old DIY flow bench says. I have to calibrate it first. Waiting for a calibration orifice plate to arrive.
Picked up a 11.5lb Fidanza and Centerforce clutch as well....
Before anyone goes off and says that this is a waste of time..... remember, this is my hobby. Any time spent in the garage tinkering is time enjoyed! If there are benefits from it, that is a bonus to all of us.
Old 05-11-2014, 10:38 AM   #127
daspazzZX3
OneOfUs
daspazzZX3's Avatar
Fan#: 133961
Forum Activity 100%
Roger that! Thats like me and guitars!!! 8-)
Old 07-19-2014, 04:55 AM   #128
MrTerryToYou
MrTerryToYou's Avatar
Fan#: 94976
What I Drive: 2001 Pitch Black ZX3
Points 980, Level 16
Points: 980, Level: 16 Points: 980, Level: 16 Points: 980, Level: 16
Forum Activity 3%
FF Reputation: 1 MrTerryToYou Good Standing Member
Buy-Sell-Trade Rating: (7)
Ok guys... I'm trying to make sure I got everything done possible before I start diving into the motor. I'm slowly working on my N/A 01 zx3. I think I'm about at my limit...
So my current setup is this:
Iceman intake, Steeda 65mm tb, (I have a cfm 3" MAF tube just not installed), Y2K ported intake manifold, EGR delete, FR plug wires, SVT Exhaust Manifold, 2.25" or 2.5" ORP (not sure of make and forgot to measure before putting it on) to 2.5" flex to 2.5" Fswerks stealth Exhaust. And I'm about to install this weekend a stage 2 clutch kit 6-puck, ClutchMasters 9.5lb flywheel, and Fidanza cam gears and new timing belt. Now I was contemplating installing a crank UDP, but I've only read that it's not worth it.... (True for N/A build or no?). Now I would love to get a set of stage 2 cams, but I'm not sure where I should go from there. I have an SCT Xcal3 and I plan on going to Tom for my tune when It's up and running before the cams. My question here is an I missing anything? Keep in mind this is my daily driver, but I am a Hobbyist who can't stop messing with his car! Lol I do all my own work and I feel like GhostTribute does about N/A. It's not about easy, it's about the pride, respect and labor of love it takes to build something and learn new things along the way!
I'd like to say thanks and also give admiration and respect to all of you who have actively posted in this thread!
Thanks in advance for any help received!
Tony
ESQUILAX-The Black Squirrel Of Death-01ZX3-Roush Suspension, 15x7 RotaRBs, SVT EM, ORP, FS FBE, EGR Del, Y2K IM 65mm, 3"MAF Tube, SteedaTB, Iceman Int, FR Wires, Cop Plugs, HP Timing Belt, Fidanza CamGears, Spec Stg2 Clutch, CM Flywheel
MrTerryToYou is offline
Old 07-20-2014, 08:20 AM   #129
1turbofocus
FF Affiliate
Fan#: 1123
Forum Activity 32%
180 deg thermostat , Motorcraft SP463 plugs
Customer Support
AIM: hpdyno
Phone: 704-249-3745
Elder 1turbofocus
Old 07-20-2014, 10:53 AM   #130
MrTerryToYou
Fan#: 94976
Forum Activity 3%
Awesome! I'll pick those up as well as a wideband this month before I give you a call for the tuning! Thanks Tom.
Oh about the Cams, should I go with a stage 2, or 3? I never plan on going FI.
Similar Threads
FS few Zetec performance parts silverbulletst170 Archive 7 04-06-2009 05:21 PM
how to get svt performance out of a zetec? chad_p71 ZETEC Performance (2000-2004) 18 11-08-2006 11:51 PM
Ford Racing Focus Parts Performance Comparison - 2.0L Zetec Goat Roper ZETEC Performance (2000-2004) 10 03-25-2006 06:44 PM
Thread dimensions of ZETEC oil cap? gthang Ford Focus & General Car Chat 0 03-31-2004 04:28 PM
Quater Mile! turbo989 DURATEC Performance (2003-2007) 24 03-03-2004 12:53 PM
