The N/A Zetec Performance Thread - Focus Fanatics
Go Back   Focus Fanatics > Ford Focus First Generation > ZETEC Performance (2000-2004)
Old 03-24-2009, 09:32 AM   #1
blkthunder
Fan#: 34375
What I Drive: 06 G35
FF Reputation: 5 blkthunder Good Standing Member
Buy-Sell-Trade Rating: (4)
In response to all the questions about N/A Zetec performance lately
Post em if you got em boys....
Heres my recepie
Breathe Easier
- Full Intake/Exhaust w/2.5" (Inside Diameter) Piping
- 65mm Throttle Body
- 70mm MAF tube
- SVT Fuel Pump
- 24 lbs Fuel Injectors
- Tune
Engine Efficency
- Headwork (Port, Polish, Deck, 3 Angle Valve Job, Oversized Valves)
- Built engine (High Compression, Lightweight Pistons/Rods, ARP hardware)
- Reinforced Main caps
- Knife-Edged Crankshaft
- AC Delete
- PS Delete
- (Tune) Alternator cutoff at WOT
Rev Higher
- Custom Intake Manifold w/short runners
- Aggressive Camshafts (High lift, Good Overlap)
- Adjustable Cam Gears
- Valves/Springs (Lightweight and designed for high rpm)
- Billet Oil Pump Gears
- (tune) Rev limiter set to 8k
Stay in the sweet spot
- 4.06 gears
Reduce Rotational Mass
- Underdrive Pulleys
- Lightweight Rims/Tires
- Lightweight Flywheel
And as always, due to the High Revving, low tq, not daily driver friendly nature of a pure N/A build, Weight reduction is a must to help combat the lack of low end response.
LINK[/URL]
Daily Driver Friendly
Lightweight battery, Carbon Fiber Hood, Carbon Fiber Hatch, Wheels (most important), Flywheel (2nd Most important), Front Race Seats, Rear Seat Delete, Receiver only with only the front door speakers
Track Oriented
Remove the AC stuff, Remove the Powersteering stuff, Remove the Dash accept for the gauges, Swap all of the glass for Lexan, Remove the wheel well guards, Remove the rear bumper support, Remove both the air bags, scrape off all the sound barrier stuff, Remove all interior panels
thx to: mlbbaseball, besthaticouldo
06 Lakeshore Slate Infiniti G35 Coupe. Deceptively Stock!
Gone But not forgotten: 2004 SVT Focus... the way a SVT should drive.
blkthunder is offline
Old 03-24-2009, 09:39 AM   #2
Insane
Adam
Insane's Avatar
Fan#: 51468
What I Drive: 2003 Infra Red ZX3
FF Reputation: 41 Insane Great Standing Member
Well thats a NICE list you have there.
-Zetec Crew #215
Volant Intake, SVT Snorkle, By past A/C, AFX UDP, Copper Plugs, 9mm Plug Wires, Toms Tune, Roush springs/shocks/struts, Eibach Sway-Bars, C-F-M Racing Lower Engine Mount.
Insane is offline
Old 03-24-2009, 09:44 AM   #3
blkthunder
Fan#: 34375
yep looking for sticky status... feel free to contribute.
Old 03-24-2009, 12:45 PM   #4
mlbbaseball
Shot me 3 deer!!!
mlbbaseball's Avatar
Fan#: 53541
What I Drive: 01 zx3 s2 x2, 02 SVT, Jeep Cherokee
FF Reputation: 42 mlbbaseball Great Standing Member
Buy-Sell-Trade Rating: (68)
You will also want to get an SVT fuel pump. and you forgot two of the most important things!!!
High lift Cams w/ good overlap
Valvetrain capable of handling high rpms.
o, and wider valves!!
rockin 70+ hours a week at work and still trying to have a social life!!!
2004 SVT EAP partout, PM me with needs.
mlbbaseball is offline
Old 03-24-2009, 12:52 PM   #5
blkthunder
Fan#: 34375
I thought massive cams w/adjustable gears w/lightweight valves/springs just about covered it. do you have a link to something that'll work? im thinking i should provide some links as well?
Old 03-24-2009, 12:55 PM   #6
mlbbaseball
Shot me 3 deer!!!
Fan#: 53541
I could post my whole build step by step including all parts i have and parts i needed to buy. but that would take hours to type!
Old 03-24-2009, 12:56 PM   #7
Insane
Adam
Insane's Avatar
Fan#: 51468
It would be more complete if you did that or gave names of all the parts and prices.
-Zetec Crew #215
Insane is offline
Old 03-24-2009, 12:59 PM   #8
besthaticouldo
i wear no pants
besthaticouldo's Avatar
Fan#: 26970
What I Drive: '11 OBP WRX Sedan
FF Reputation: 104 besthaticouldo Excellent Standing Memberbesthaticouldo Excellent Standing Member
Buy-Sell-Trade Rating: (23)
This would be my mod list
Breathe Easier
-SVT Header
-SVT ORP
-CFM SVT Flexpipe
-2.5” Exhaust All the Way back (Magnaflow muffler is my choice)
-2000 Ported Intake Manifold
-65mm Throttle Body
-AEM Cold Air Intake
Engine Efficency
-Ported and Polished and Decked Head, with great valve train, 3 angle valve job, bigger valves
-Built motor (rods, pistons, ARP, Toms Main Caps, CFM Billet Oil Pump, knife edged crank)
-Toms Tune (with custom tweeks) (dyno tune)
-SVT Fuel Pump
-SVT Maf
-SVT Injectors
-FR Stage III Cams
-AEM Cam Gears
Stay in the sweet spot (rotational mass)
-4.06 gears
-Torsen Diff
-Lightweight Flywheel
-Spec Stg II+ Clutch
-CFM 2pc Underdrive pullies
remember that building a car shouldn’t come from parts it should come from deep inside your soul. let the car speak for all the emotions, memories and experiences youve made and the car will take a life of its own. truth over fame.
besthaticouldo is offline
Old 03-24-2009, 01:03 PM   #9
besthaticouldo
i wear no pants
Fan#: 26970
btw mine is built with the intention of daily driving it.
i would also add Steeda Motor Mounts with a SVT Pass Side, and SVT Cam Cover on that side
Old 03-24-2009, 01:10 PM   #10
blkthunder
Fan#: 34375
Breathe Easier
-SVT Header
-SVT ORP
-CFM SVT Flexpipe
-65mm Throttle Body
Engine Efficency
-SVT Fuel Pump
-SVT Maf
-SVT Injectors
-FR Stage III Cams
-AEM Cam Gears
-4.06 gears
-Torsen Diff
The only thing im not likin too much is the cost of going with full SVT header setup is considerably more than a pure race header would yield and be similar power wise. Also, the 00 intake mani will limit power over 5k. Im gonna go ahead and steal your wording on the cylinder head and SVT fuel equipment.
Similar Threads
FS few Zetec performance parts silverbulletst170 Archive 7 04-06-2009 04:21 PM
how to get svt performance out of a zetec? chad_p71 ZETEC Performance (2000-2004) 18 11-08-2006 10:51 PM
Ford Racing Focus Parts Performance Comparison - 2.0L Zetec Goat Roper ZETEC Performance (2000-2004) 10 03-25-2006 05:44 PM
Thread dimensions of ZETEC oil cap? gthang Ford Focus & General Car Chat 0 03-31-2004 03:28 PM
Quater Mile! turbo989 DURATEC Performance (2003-2007) 24 03-03-2004 11:53 AM
