Non Svt VS SVT Intake - Page 2 - Ford Focus Forum, Ford Focus ST Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum > Ford Focus First Generation > ZETEC Performance (2000-2004)
Old 03-24-2009, 05:27 PM   #11
allanzx3
Fan#: 33007
What I Drive: 2001 Liquid Grey ZX3 S2
FF Reputation: 0 allanzx3 Newbie
Originally Posted by iminhell View Post
MAFS's are calibrated per orifice size. X Grams of air per Second can pass through a fixed diameter of Y. If you alter "Y" "X" will also change. Problem is X is calibrated only for Y. This is because a MAFS only takes a small sample of air and guesses at what the total air flow is, then the ECU figures out the proper amount of fuel. If the air sample is the same but the housing and associated air flow is actually larger the fuel quantities will be wrong (lean).
Short answer is do not swap MAFS housings or alter them in any way or you may incur problems.
Unless you tune it to show the proper air flow per maf voltage as i have done :D
2001 Ford Focus ZX3 S2
2002 Mazda Protege5
allanzx3 is offline
Old 03-24-2009, 09:41 PM   #12
Zx3Zetec200
Zx3Zetec200's Avatar
Fan#: 59930
What I Drive: 2000 Autumn Orange ZX3
FF Reputation: 1 Zx3Zetec200 Good Standing Member
you notice a good increase with switching the maf housing. will the SVT intake tube install onto the stock zetec TB?
*Active Duty USAF SrA* 2000 ZX3 Auto- Current Mods: Tune by Tom, OBX 4-2-1 header, Magnaflow flex back, SVT Intake. Rousch Stage 2 suspension kit, Painted stockies, Rear seat delete..located currently @ Dyess AFB Abilene Texas 79606.
Zx3Zetec200 is offline
Old 03-24-2009, 09:52 PM   #13
iminhell
C2H5OH
iminhell's Avatar
Fan#: 36222
Points 17,868, Level 85
Points: 17,868, Level: 85 Points: 17,868, Level: 85 Points: 17,868, Level: 85
Level Up 4% Completed
Forum Activity 29%
Activity: 29% Activity: 29% Activity: 29%
FF Reputation: 48 iminhell Great Standing Member
Buy-Sell-Trade Rating: (4)
Originally Posted by Zx3Zetec200 View Post
Will the SVT intake tube install onto the stock zetec TB?
No.
SVT engine:
Focus zetec engine:
Tube is completely different.
Don't "think outside the box".
There is no box.
Do it correct, or do it twice.
iminhell is online now
Old 03-24-2009, 10:02 PM   #14
Zx3Zetec200
Fan#: 59930
wow, yes it is. so how is everyone using the svt MAF housing on there non svt zetecs???? homemade 70mm plumblng or what?
Old 03-24-2009, 10:24 PM   #15
focusonthis420
focusonthis420's Avatar
Fan#: 30951
What I Drive: SGM 2012 5dr
FF Reputation: 17 focusonthis420 Great Standing Member
Buy-Sell-Trade Rating: (26)
Because the standard Zetec and SVT MAF tubes both have the same inlet/outlet outside diameters. And they will bolt up to either airbox the same. The difference is that the SVT maintains a consistent diameter inside the tube, while the standard Zetec tube has an area in the middle of it where the MAF sensor sits that is smaller. Trust me, you don't want to use the SVT MAF tube or MAF sensor (or both) without a tune. Your car will run like S H I T (except maybe at full throttle where it is getting enough fuel)!!!
Sterling Gray Metallic 2012 5dr Titanium w/ MS3 RMM
focusonthis420 is offline
Old 03-24-2009, 10:26 PM   #16
iminhell
C2H5OH
iminhell's Avatar
Fan#: 36222
Forum Activity 29%
There are actually 2 parts to the MAFS, the sample tube and the sensor itself. If you look at an AEM intake you'll understand, the sensor can unbolt from the sample tube (is the actual name for the housing the MAFS sits in).
The outer diameter is the same for either SVT or standard sample tube, in fact my 70mm is the same O.D. as my stock one.
(picture from aironjack)
The SVT sample tube does not have that step, nor does my 70mm.
There is no box.
Old 03-24-2009, 11:01 PM   #17
Zx3Zetec200
Fan#: 59930
good info, im messaging Tom back and fourth right now and getting my tune and programmer friday. since you guys make good sense of this what parts will i need to run the full svt intake? i see the svt tube from maf to TB doesnt go across valve cover it just does a 90 degree bend right off the maf, what tube can i buy for mounting the svt maf sample tube to the stock TB? thanks so much for your input sorry.
Old 03-24-2009, 11:32 PM   #18
iminhell
C2H5OH
iminhell's Avatar
Fan#: 36222
Forum Activity 29%
Your stock intake tube will fit the SVT sample tube.
The SVT sample tube will fit either the SVT or standard air box lid.
So essentially you'd want and SVT sample tube and SVT air box with the SVT snorkel.
But if your talking the whole shebang then you also need (at minimum) the SVT upper and lower intake manifolds, the SVT throttle body and the SVT intake tube. This is covered in the SVT to zetec intake manifold swap in the How-To's.
There is no box.
Old 03-25-2009, 06:26 AM   #19
Zx3Zetec200
Fan#: 59930
thanks, im clear on it now. deff more involved than what i though. ill just start grabbing parts when i see them pop up i guess :-)
Tags
airbox , intake , svt , zetec
Similar Threads
Want to buy tach / need help with tach cookiemonster52 DURATEC Performance (2003-2007) 19 08-23-2013 02:27 PM
For Sale:Custom Svt intake manifold CatMostFeared Archive 14 02-25-2008 09:49 AM
SVT Parts For Sale: Ontario, California jrgtrain Archive 98 02-11-2008 07:32 PM
For Sale: SVT Engine Parts - Pistons/Rods and Intake Manifold zincyellowfocus Archive 6 08-21-2006 12:14 PM
Svt Intake manifold on Zx3 MarkyMark General Technical Chat 4 04-20-2005 09:38 AM
