Basic Bolt ons: Exhaust Headers/Flex Pipes - Page 8 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 03-25-2011, 12:13 PM   #71
Dung1sm
Atx PZEV FTW!
Dung1sm's Avatar
Fan#: 52323
What I Drive: 2005 Silver ZX4
Points 3,638, Level 37
Points: 3,638, Level: 37 Points: 3,638, Level: 37 Points: 3,638, Level: 37
Level Up 92% Completed
Level up: 92% Level up: 92% Level up: 92%
FF Reputation: 4 Dung1sm Good Standing Member
theres a o2 cheater you can do... or just drive with the check engine light on like me...lol
So Cal Crew#43
Sedan Revolution #130
Moderator for:
South West Fanatics
Ford Focus & General Car Chat
Ford Focus Build Showroom
Dung1sm is offline
Old 04-10-2011, 10:58 AM   #72
icase81
Fan#: 84780
What I Drive: 2011 White SEL
FF Reputation: 1 icase81 Good Standing Member
Originally Posted by S0C0nFused View Post
The most restrictive part of any exhaust is the cat. Remove it/them and the rest is comparatively fine tuning. You may also look at it the other way. Mounting a header with a trailing cat, gain would be effectively zero, as any potential gains from the header would be negated by the cat.
Not necessarily true. This all depends 100% on the cat. I'm from the 1.8T/VW world originally, and we've done tests with a 700+hp 20v motor that with the OEM VW cat vs a straight downpipe. The cat caused an effective loss 7hp on an engine dyno, which would be even less at the wheels. If you're pushing even less air through the motor, you're not even going to see THAT much loss. However, as I am fairly new to the Focus world, I don't know what the situation is with the factory cat. If you wanted to pony up for an appropriate high quality metal substrate cat, you would probably not lose anything. Especially since a mildly modded 2 or 2.3L n/a motor isn't flowing all THAT much in comparison to a forced induction motor. The main reason to not run a cat is either because of cost of putting a proper one in, or the complexity of the install making it unfeasible.
icase81 is offline
Old 04-10-2011, 11:00 AM   #73
icase81
Fan#: 84780
Originally Posted by BowerR64 View Post
It was a cat case or somthing but it was stripped of all the stuff in it. It was just a pass threw.
Is this what you mean?
http://www.siliconeintakes.com/produ...290a0f9afd2114
icase81 is offline
Old 04-10-2011, 01:16 PM   #74
S0C0nFused
S0C0nFused's Avatar
Fan#: 39405
What I Drive: 2007 TorD-Red ZX5 SES
Points 12,348, Level 72
Points: 12,348, Level: 72 Points: 12,348, Level: 72 Points: 12,348, Level: 72
Level Up 75% Completed
FF Reputation: 77 S0C0nFused Excellent Standing Member
I have to agree with you, only in that the devil is in the details. 1st. Please post a link to an appropriate "high quality metal substrate cat". I tried once before to find one and came up short. But the point was/is. Assume stock build. The D2.0 makes it's torque low in the RPM range. This negates somewhat the overall performance hit of the cat (low volume as you mentioned). Mount a header though, and you move the curve 2K upwards (to around 4500RPM), So now you trying to push a whole lot more volume, and it runs into the cat. So right when the benefits of the header should be coming in, there getting killed. Hence, A header (no cat) is worth about 7-10hp (real world), A header with a cat? Maybe 2-3HP? So it would prob be best to state that it is just not cost effective.
Steeda SRI w/CAI intake. Trubendz SS 2.5" . FR Susp/Struts. Tune by Tom (FocusPower). Rota Grids. SAP rear spoiler. Custom front air dam, rocker panel bits and Rear valance.
Last of the Hatches #28
S0C0nFused is offline
Old 04-10-2011, 03:02 PM   #75
BowerR64
BowerR64's Avatar
Fan#: 78699
What I Drive: 2007 ZX3 SE
Points 12,318, Level 72
Points: 12,318, Level: 72 Points: 12,318, Level: 72 Points: 12,318, Level: 72
Level Up 67% Completed
Forum Activity 3%
FF Reputation: 12 BowerR64 Great Standing Member
What if you get a setup that is designed for a larger engine, like say a 6 or 8?
You put on a header but then everything else is like 3" (or for a larger engine)you have all the stuff, cat, muffler, resonator but everything is so large it flows as good as a 2" race setup?
Or does it not work that way?
I would think with a setup larger then whats designed for the car emmisions wise would pass but be so much more un restrictive it would help the engine breathe better.
It's not important to win, it's important to make the other guy lose.
BowerR64 is offline
Old 04-10-2011, 03:05 PM   #76
BowerR64
BowerR64's Avatar
Fan#: 78699
Forum Activity 3%
Well i never really seen one my brother was talking about them when he ha da honda and was doing mods to his. At the time i didnt even really know what a cat was or what they did actualy.
BowerR64 is offline
Old 04-10-2011, 03:16 PM   #77
BowerR64
BowerR64's Avatar
Fan#: 78699
Forum Activity 3%
Originally Posted by felixthecat View Post
You need the flex pipe, for the movement the motor has being sideways. All FWD cars have to use some sort of flex for the exhaust, even w/ vf engineering mounts or similair mounts. As far as muffler shops, could put a header on, they would want some kind of conver added to. Legalley I don't think they can. Any how you would be missing out of all the fun you would have, adding a new mod, to your car, don't you think!
Thats what i thought but i seen a post were a guy put a bracket on the end of the header and bolted it to the tranny or somthing. Made everything rigid.
Maybe the header being more solid is better but after that?
Ill try and find a picture.
So where is the flex in this setup?
BowerR64 is offline
Old 04-10-2011, 06:27 PM   #78
S0C0nFused
S0C0nFused's Avatar
Fan#: 39405
Correct! It does not work that way.
Old 04-11-2011, 04:08 PM   #79
BowerR64
BowerR64's Avatar
Fan#: 78699
Forum Activity 3%
Can you explain? not sure i understand why.
BowerR64 is offline
Old 04-11-2011, 05:33 PM   #80
Buickboy
br/o/stang
Buickboy's Avatar
Fan#: 28542
What I Drive: 72 Skylark, '12 Mustang
Points 28,322, Level 98
Points: 28,322, Level: 98 Points: 28,322, Level: 98 Points: 28,322, Level: 98
Level Up 98% Completed
FF Reputation: 39 Buickboy Great Standing Member
Buy-Sell-Trade Rating: (29)
Pic above is a zetec/svt car- different from ours. the flex is the part that goes over the front subframe (cant see it).
also, a few posts up there was a question about the ebay OBX header having two flexpipes. It has two and theyre different lengths to fit both auto and manual cars
==2012 Kona Blue Mustang V6==
==1995 Light Iris Neon Coupe==
==1972 Skylark==
Buickboy is offline
Similar Threads
Basic Bolt Ons: Intakes And Induction focaltech ZETEC Performance (2000-2004) 108 08-01-2014 07:39 PM
Basic bolt ons: Cat back systems and flexpipes focaltech ZETEC Performance (2000-2004) 102 11-18-2013 09:34 AM
Basic Bolt ons: Exhaust Headers focaltech ZETEC Performance (2000-2004) 77 11-16-2011 08:21 PM
Basic bolt ons: Underdrive Pulleys focaltech ZETEC Performance (2000-2004) 82 07-05-2011 09:39 AM
Basic bolt ons: Hi Flow cats and Off Road pipes focaltech ZETEC Performance (2000-2004) 82 08-27-2010 09:17 PM
