Transmission Mount? - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 03-17-2009, 10:11 AM   #1
bigb7000
bigb7000's Avatar
Fan#: 8982
What I Drive: '04 SVT
FF Reputation: 1 bigb7000 Good Standing Member
Question Transmission Mount?
If you replace the motor mount and now it is hard to get the car into gear could the transmission mount need to be adjust to make sure it is still properly alligned? If that mount was too high would it cause any problems or since the motor and transmission are bolted together it does not really matter just helps hold it in place?
bigb7000 is offline
Old 03-17-2009, 12:10 PM   #2
faster_than_u
anti svt
Fan#: 41017
What I Drive: focus
Points 4,412, Level 42
Points: 4,412, Level: 42 Points: 4,412, Level: 42 Points: 4,412, Level: 42
Level Up 31% Completed
Level up: 31% Level up: 31% Level up: 31%
FF Reputation: 12 faster_than_u Great Standing Member
Buy-Sell-Trade Rating: (6)
you cant adjust the lower trans mount there are bolts that hold it in place.
ZC#200
faster_than_u is offline
Old 03-17-2009, 12:14 PM   #3
bigb7000
bigb7000's Avatar
Fan#: 8982
the top bolt that goes into the rubber mount can you just not thread it down so far? not adjusting the bottom near the trans but at the top by the rubber mount...
bigb7000 is offline
Old 03-17-2009, 01:28 PM   #4
faster_than_u
anti svt
Fan#: 41017
What I Drive: focus
not really understanding what you are saying. do you have any pictures?
ZC#200
Old 03-17-2009, 02:08 PM   #5
bigb7000
bigb7000's Avatar
Fan#: 8982
here is my trans mount. so the big nut in the middle goes to the shaft connected to the trans can you keep tightening this to lift the trans up higher or not tighten so much to lower it? I know this would not be a huge adjustment but could it lead to a bind from the motor if it was lifting it too high?
bigb7000 is offline
Similar Threads
Every trouble code defined 03OrangeSVT General Forced Induction 9 05-25-2011 01:53 PM
2003 SVT Motor Mount ??? so confused ??? dappie_99 SVT Performance (2002-2004) 23 08-22-2010 10:40 PM
Focus Light Bulb Guide (MOD STICKY THIS) TKE_Quailman MK2 Focus 13 11-09-2008 05:36 PM
Broken Transmission Mount melbzetec ZETEC Performance (2000-2004) 4 07-16-2007 10:19 AM
Transmission Mount failure Dragwn General Technical Chat 9 08-20-2006 09:01 PM
