HOW-To Light Up Your Speakers - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum > Ford Focus First Generation > MK1 Interior Mods & Upgrades
Old 03-15-2009, 01:48 AM   #1
devil_dog_switch
devil_dog_switch's Avatar
Fan#: 55359
What I Drive: 2003 Black Dodge Durango
FF Reputation: 3 devil_dog_switch Good Standing Member
I did this along with my other mods and have decided to share, I figured yes it puts my car apart from the rest but i don't want to be stingy either. So, I'll share with other Foci members how to do this and mind you, the possibilities are endless with this mod, the amoutn of LEDs is up to you.
Supplies Needed:
Wire (i used 16 gauge but that was overkill, any gauge works though)
Wire strippers
Electric tape or Heat shrink tubing
LEDs w/resistor (your choice of color, amount and size I used two 3mm super bright blue)
Soldering iron with resin core solder (acid core works but as i found out its more of a pain and the fumes are horrible smelling)
Glue (to help make this stay)
Staple gun (just a generic, a regular stapler may even work)
To Take Off The Door:
Screwdriver and torx head bits (size unknown sorry, small... )
Extension and ratchet/socket set
Here Is The Result of this mod: (not including the door handles.. or the window panel, both of those are on another how-to)
Here's How You Do It.
First off take off your door panels.. it's quite simple and there is a how-to around here somewhere if you need help.. however the short and easy explanation.. along the side and bottom there are torx screws, behind the door handle that opens the door there is one hidden and pop off the fixed door handle cover and there is two regular bolts in there(you'll need an extension
Ok now carefully disconnect everything from the door cover, you'll be using this to make some measurements.
Once it's off decide where you want you're LEDs to be places. i made it easy and placed them on the sloped side and top that way it's already half aimed.
Now that you have decided on the placement measure (doesn't need to be exact) the spacing so you know how much wire to cut.
Go inside and solder your LEDs in a series. It should go like this: (for 2 LEDs)
12v supply>>>>>>resistor>>>>>>+LED->>>>>>>+LED->>>>>>>Ground
With it soldered (AND COOLED .. I have to say it you know someone will burn themselves)insulate it as you wish.
Take that door panel and Carefully staple the lights and wires in place, taking care not to staple the wires together (shorting it out) if you want you can insulate the wires seperatly so you can pull them apart a little easier
(NOTE: DO THE STAPLING WHERE THE SPEAKER COVER ON THE FRONT SIDE OF THE DOOR WILL COVER THE LITTLE PRICKS OF THE STAPLE, IF NOT YOU WILL SEE THE STAPLES TRYING TO COME THRU)
Like so:
Now you are pretty much done. If you did this right you ill be able to aim the lights later once you have them powered. I just took off the little cover where the window buttons are and use a long flathead screwdriver to aim them after the sun went down, be gentle with them but they will bend around a little.
Also if you want to ensure the staples and wires hold in place use a dap of superglue (i used gorrilaglue) on the staples to hold them once dry.
If you want to know how to power them.. look for my other How-To i will be posting shortly after this one.
Former Home of the Blue Light Special
Ask me about Lighting
2003 Dodge Durango Sport
2002 Ford Focus SPI *SOLD* you will be missed
devil_dog_switch is offline
Old 03-15-2009, 02:09 AM   #2
lightning2nd
love my red focus
lightning2nd's Avatar
Fan#: 54938
What I Drive: 2006 Red ZX4 SES w/SAP
Points 1,324, Level 20
Points: 1,324, Level: 20 Points: 1,324, Level: 20 Points: 1,324, Level: 20
Level Up 24% Completed
FF Reputation: 3 lightning2nd Good Standing Member
looks good man
Built on 1-18-06
06' Red ZX4 SES 2.0L Duratec/ with S.A.P.
member of Focus Nation / Sedan Revolution#105 / Sap Crew#23 / Team Duratec#189 / Midwest Crew#31
lightning2nd is offline
Old 03-15-2009, 08:59 AM   #3
Waffles ZX3 Kona Sport
WAFFLEY!
Waffles ZX3 Kona Sport's Avatar
Fan#: 10426
What I Drive: 2006 Fusion SE Midnight Blue
FF Reputation: 11 Waffles ZX3 Kona Sport Great Standing Member
Buy-Sell-Trade Rating: (6)
Looks pretty cool man. Good work!
Waffles ZX3 Kona Sport is offline
Old 03-17-2009, 02:35 PM   #4
tkheaven
tkheaven's Avatar
Fan#: 59098
What I Drive: 2002 Pitch Black ZX3
Points 1,155, Level 18
Points: 1,155, Level: 18 Points: 1,155, Level: 18 Points: 1,155, Level: 18
Level Up 55% Completed
FF Reputation: 3 tkheaven Good Standing Member
Ay how sweet it is... I really love how these mods look. If only I found someone in my area to help me with these...
"possible" cloning of humans - check
"possible" evolution from non-living particles - check
"possible" time travel aka Big Bang machine - check
creating the perfect pres. candidate and send him back eight years ...impossible...
tkheaven is offline
Old 03-17-2009, 08:39 PM   #5
devil_dog_switch
Fan#: 55359
too bad you weren't around here.. i've been hooking up people i know ever since i installed this.. i have a guy this friday is gonna turn his car over to me to rewire and fix his scion TC's lighting
Old 03-18-2009, 11:56 AM   #6
tkheaven
tkheaven's Avatar
Fan#: 59098
I was just on the Oznium site. Wouldn't it be the same if I purchased their pre-wired 3mm (prewired-leds)? I could hook up (superglue/hot gun/staple/whatever) the leds:
one strip along the driver's inside speaker, door handle & possibly 2of4 vents
one strip along the passenger's inside speaker, door handle & possibly other 2of4 vents
I didn't get to see your how-to on powering them but I'm assuming red power (to where?) black ground aaaannndddd idk on hooking it up to a rocker switch or something... this make any sense? Trying to use some logic and what I'm actually able to do without burning anything out...
tkheaven is offline
Old 03-18-2009, 12:20 PM   #7
FociZX4ST
Don't read this!
FociZX4ST's Avatar
Fan#: 56232
What I Drive: 2005 Infra-Red Focus ZX4 ST
FF Reputation: 4 FociZX4ST Good Standing Member
Nice job!!! So can you help me find the door panel help??
-Jeremy, JFish or whatever you want...
Team Duratec #183, Sedan Revolution #168
What is a "free" gift ? Aren't all gifts free?
FociZX4ST is offline
Old 03-18-2009, 12:27 PM   #8
joshfink
joshfink's Avatar
Fan#: 50565
What I Drive: Black 2007 ford Focus
FF Reputation: 4 joshfink Good Standing Member
Oh wow I never thought of doing this. I need to work up the courage to do my window and lock switches at some point in blue :/ Too scared though lol
"Whoopie! That may have been a small one for Neil but it was a long one for me!" - Pete Conrad stepping off the LEM onto the lunar surface during Apollo 12.
joshfink is offline
Old 03-18-2009, 02:18 PM   #9
auto
Made In The USA
auto's Avatar
Fan#: 42455
What I Drive: Pitch Black 07 ST w/S.A.P.
FF Reputation: 89 auto Excellent Standing Member
I might do this if I get speakers worth seeing.
Thats it Mr.! You just lost your brain privileges!
auto is offline
Old 03-18-2009, 03:34 PM   #10
S2
Retired Fanatic
S2's Avatar
Fan#: 4939
What I Drive: Camaro 2SS/RS
FF Reputation: 67 S2 Excellent Standing Member
Buy-Sell-Trade Rating: (20)
Added to the 'HOW TO ARCHIVE'.....
Chad (S2)
S2 is offline
Similar Threads
SOLD: BRAND NEW Infinity Kappa Series 5x7 / 6x8 Speakers - 2 Pairs kenzx3 Archive 15 04-05-2009 08:33 PM
Emergency Brake Light Popping On? JohnMichael General Technical Chat 7 08-17-2007 04:37 PM
emission light thepaz420 General Technical Chat 4 10-06-2006 08:27 PM
After Counter Weight Delete Dash Light on tazz3131 General Technical Chat 2 09-26-2006 08:22 PM
