How To: springs and struts - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 03-14-2009, 08:46 PM   #1
ZXthrizzle05
TURBO ZX3
ZXthrizzle05's Avatar
Fan#: 24434
What I Drive: 2012 Mazdaspeed 3, TURBO ZX3
Points 51,036, Level 100
Points: 51,036, Level: 100 Points: 51,036, Level: 100 Points: 51,036, Level: 100
Level Up 0% Completed
Forum Activity 2%
FF Reputation: 6 ZXthrizzle05 Good Standing Member
Buy-Sell-Trade Rating: (11)
on march 8th i put in four roush springs and front roush struts i also did z3 fenders so if anyone wants a how to on those ic an post one of those in the exterior section, so heres some step by step things on some people that are new at it, if ive made any mistakes please pm me to fix.
Start by removing all four tires.
next thing you want to do is unscrew the three screws on the front upper mounts. then you remove the stabilizer bar link rod securing nut.also you must disconnect the brake hose line.
normally after this youll need a piece of wood to settle on your rotor assembly and use a rubber mallet and hammer down onto the rotor to detach the strut assembly from the rotor.once you do that you can slide the strut assembly with teh stock spring still attached out. grab a vise and wrap your aftermarket strut with a padded rag and dont over tighten it on your strut but make sure its tight enough to when you go to compress the spring.
grab your spring compressor and start compressing your spring, once compressed a little, loosen and remove the retaining nut. and remove the upper bearing and spring seat. then very very carefully remove the spring.
heres a picture of what your n ew strut and spring assembly should look like,
WARNING: make sure when you are installing hte new spring into the strut that you carefully very very carefully remove the spring compressor from the original spring to avoid injury. and as you know do everything backwards from there for installations. Slide the strut with new spring back in and tighten the three upper mounting bolts, but not all the way just finger tight. place the jackstand underneath the rotor alligning the stabilizer bar link rod with the hole. Re attatch the brake hose. and your good to go.
heres what my difference was in original height to roush height.
[B]And now for the rear.[B]
Well im not to sure on how to do it without compressing the rear springs so ill just show you by compressing them. Start by removing the lower arm to crossmember bolt and bolt to hub assembly.
you could just step back a bit and give it a swift kick to the hub assembly thats what we did or you can just compress the rear springs.
And again here was my difference in the rear stock springs to the roush ones.
either way when you do this putting the new springs in is simply easy. you can put a jack underneath the drum once the new spring is in no need for compressing the rears after the stock one is out. put the jack under the drum when the new spring is inand re tighten the bolts from earlier and voila.
before and AFTER
Hope you all enjoy and can use this for help.
FF MODERATOR
RISE AGAIN EGGYOLK302 WHP 274 WTQ ZETEC CREW #271
RIFF CREW
ZXthrizzle05 is offline
Old 03-14-2009, 08:51 PM   #2
Blackcatn2o
soon to be turbo!
Blackcatn2o's Avatar
Fan#: 48278
What I Drive: 06 silver ZX4 ST
Points 8,020, Level 60
Points: 8,020, Level: 60 Points: 8,020, Level: 60 Points: 8,020, Level: 60
Level Up 35% Completed
Level up: 35% Level up: 35% Level up: 35%
FF Reputation: 48 Blackcatn2o Great Standing Member
Buy-Sell-Trade Rating: (13)
Man what would i do to get a garage like your's. we move so many time.
Blackcatn2o is offline
Old 03-14-2009, 08:55 PM   #3
ZXthrizzle05
TURBO ZX3
Fan#: 24434
Forum Activity 2%
hah good thing its not my garage lol its brad whites the moderators. his garage is where allll of my modifications happen cuz it has every tool you need and all the hands to help
FF MODERATOR
RIFF CREW
Old 03-14-2009, 08:59 PM   #4
Blackcatn2o
soon to be turbo!
Fan#: 48278
I see the Beer firidge on the side in one of the pics.......PERFECT!!
Old 03-14-2009, 09:05 PM   #5
ZXthrizzle05
TURBO ZX3
Fan#: 24434
Forum Activity 2%
it is, its got beer and hard A in it, of course we use it for celebration not for during the mods lol
FF MODERATOR
RIFF CREW
Old 03-14-2009, 10:40 PM   #6
CJohn364
GoKart and Me!!!
CJohn364's Avatar
Fan#: 49277
What I Drive: 2K5 ZX4 SEt (ATX) French Blue, Met
Points 73,703, Level 100
Points: 73,703, Level: 100 Points: 73,703, Level: 100 Points: 73,703, Level: 100
FF Reputation: 119 CJohn364 Excellent Standing Member CJohn364 Excellent Standing Member
Nice work, Sean.
-Carl-
Sedan Revolution #61 / NW Posse #2
FF Moderator
Member Rules
Buy-Sell-Trade Rules
Complete 'How-To' Archive
General Racing Thread Rules
CJohn364 is offline
Old 03-14-2009, 10:44 PM   #7
ZXthrizzle05
TURBO ZX3
Fan#: 24434
Forum Activity 2%
love it but the ride is bumpy, im thining a rear upper stress bar might help?!?! anyone know of this being true?
FF MODERATOR
RIFF CREW
Old 03-14-2009, 11:43 PM   #8
trailbikerider
trailbikerider's Avatar
Fan#: 50501
What I Drive: 2002 Granny Gold ZTS, 94 2.3 Ranger
Points 10,328, Level 67
Points: 10,328, Level: 67 Points: 10,328, Level: 67 Points: 10,328, Level: 67
Level Up 70% Completed
FF Reputation: 14 trailbikerider Great Standing Member
Buy-Sell-Trade Rating: (15)
Nice how-to! Should be lower when it settles.
Originally Posted by SVT3658
I am enjoying this ice cream like Evan enjoys drinking a beer from a koozi in a beach chair across the street from a middle school
trailbikerider is offline
Old 03-15-2009, 12:24 AM   #9
ZXthrizzle05
TURBO ZX3
Fan#: 24434
Forum Activity 2%
i hope so
FF MODERATOR
RIFF CREW
Old 03-15-2009, 12:35 AM   #10
kritter
kritter's Avatar
Fan#: 57698
What I Drive: 2002 Sonic Blue SVT
FF Reputation: 7 kritter Good Standing Member
Buy-Sell-Trade Rating: (6)
Car looks good. And I will have my laptop out in the garage with this how-to close at hand when I swap my suspension here soon!
2002 SONIC BLUE SVT #3966
Performance & Handling: JR HFC, CFM dogbone, K&N panel filter, Eibach Pro-kit, Auto-X-ZTS RSB set to 24mm.
Exterior: ST170s & Euro Grill, White EAPs, more to come.
kritter is offline
Similar Threads
07 Springs and Struts??? Quanz56 Wheels & Tires 5 07-12-2007 03:28 PM
for sale or poss. trade: SVT springs, shocks & struts! focusedaddiction Archive 28 06-18-2007 11:18 AM
FT: Vogtland springs, For Sale: Struts and shocks briandg510 Archive 4 02-22-2007 03:38 PM
Tein Springs, SVT struts Malakai Wheels & Tires 11 12-16-2006 10:21 PM
eibach pro kit struts and shocks, evolution springs glenn_chapital Archive 5 12-11-2006 11:16 PM
