Autometer Wideband Datalogger wiring ? - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 03-11-2009, 04:20 AM   #1
BMARTIN03ZX3
BMARTIN03ZX3's Avatar
Fan#: 23931
What I Drive: 2004, Infra-red EAP SVT Turbo
FF Reputation: 2 BMARTIN03ZX3 Good Standing Member
Buy-Sell-Trade Rating: (6)
I searched the SCT forums and can't get a straight answer. Do do I wire up the data logging inputs from my autometer wideband to the 9-pin mini-din connector? Is it wired up the same as a Innovative wideband, and also which wires go to which pins? Thank for the help in advance.
Auto-X enthusiast.
Turbo build being tuned as we speak
BMARTIN03ZX3 is offline
Old 03-11-2009, 07:35 AM   #2
Blivit
Blivit's Avatar
Fan#: 51292
What I Drive: 2013 ST
Points 2,359, Level 29
Points: 2,359, Level: 29 Points: 2,359, Level: 29 Points: 2,359, Level: 29
Level Up 40% Completed
FF Reputation: 118 Blivit Excellent Standing Member Blivit Excellent Standing Member
You connect the OUTPUTS of your autometer to the INPUTS which would be on the 9 pin cable (you do have an X2 correct? The X3 uses a different cable)
The autometer should have 1-2 signal wires and then 1 or more grounds. Connect all of the grounds together then connect to one of the ground pins of the 9 pin cable. Connect the signal from the autometer to one of the signal pins of the 9 pin. The pin out should have come with the cable if you bought it from us. If not, you may need to pin it out yourself.
Blivit is offline
Old 03-11-2009, 10:13 PM   #3
BMARTIN03ZX3
Fan#: 23931
I do have the xcal 2. So the pins that come out of the wideband are blue wire + signal input and blue/black - signal input and so do i wire them into the xcal and make a ground from the connector to chassis? A diagram of some sort would be nice thanks.
Auto-X enthusiast.
Old 03-11-2009, 11:43 PM   #4
Wagamos
Stock
Wagamos's Avatar
Fan#: 21396
What I Drive: 2001 Malibu Blue ZX3; 03 ZX3 PZEV
Points 9,489, Level 65
Points: 9,489, Level: 65 Points: 9,489, Level: 65 Points: 9,489, Level: 65
Level Up 47% Completed
FF Reputation: 13 Wagamos Great Standing Member
Buy-Sell-Trade Rating: (4)
I did a how to on wiring it up widebands, its just little different b/c yours is a 9 pin and mine is xcal3 so its 6pin. The wire colors might be a little different on yours too. It'll at least get you started. The wideband should have instructions/manual that tells you what your wires are for, my innovate did.
http://www.focusfanatics.com/forum/showthread.php?t=177202
Bone Stock
223whp/218wtq
Wagamos is offline
Old 03-12-2009, 01:12 AM   #5
BMARTIN03ZX3
Fan#: 23931
Yes the Autometer has instructions that tell you what the wires go to http://www.autometer.com/download_instruction/1143.pdf
I wanna do this right cuz I don't want to fry something, and yours has 2 analog pins and mine only has 1 pin and two grounds but I don't know if the ble/black gets a pin ground or chassis ground. Thanks
Auto-X enthusiast.
Old 03-12-2009, 07:44 AM   #6
Blivit
Blivit's Avatar
Fan#: 51292
It doesn't really matter on the ground; It is a 0-5v signal. Because it goes through the obdII port it is technically a chassis ground though.
Connect your two grounds from the autometer together then connect both to one of the grounds on the 9 pin. Connect your signal to one of the signal pins on the 9 pin and you are done.
Blivit is offline
Old 03-12-2009, 11:06 PM   #7
BMARTIN03ZX3
Fan#: 23931
LOL OK. Sounds simple when you put it that way everything I've read has been more technical for some reason. Thanks.
Auto-X enthusiast.
Old 08-12-2009, 12:28 AM   #8
mellephants
omn-nom-nomnomnomnom
mellephants's Avatar
Fan#: 52400
What I Drive: 12 SE, 91 DR350S, 74 CL360
Points 11,083, Level 69
Points: 11,083, Level: 69 Points: 11,083, Level: 69 Points: 11,083, Level: 69
Level Up 59% Completed
FF Reputation: 12 mellephants Great Standing Member
Buy-Sell-Trade Rating: (15)
more info on Autometer wideband -> XCAL2 here
http://www.focusfanatics.com/forum/showthread.php?t=207339
SCT PRP FTMFW!
mellephants is offline
Old 08-12-2009, 01:16 AM   #9
illinipo
Token Engin-nerd
illinipo's Avatar
Fan#: 37693
What I Drive: dirty wag; Party; Bavarian phallus
FF Reputation: 272 illinipo Outstanding Standing Member illinipo Outstanding Standing Member illinipo Outstanding Standing Member
Buy-Sell-Trade Rating: (19)
Definitely be careful which pins youre using on the 9-pin, friend of mine fried my wideband by putting it in the 12V LCD power source that "never materialized" but for some reason still puts out 12V
If you look at the top of the x2 with the screen facing you, the correct pins are all the rightmost of each row. top right is ground, middle right is analog 1, bottom right is analog 2. So just match those up to your cable, use an ohmmeter to figure out which wires those are, and hook it up.
edit, or look at this fancy pic. FINALLY someone else posted one on the web, lol. The one correct pic on the SCT forum is hard to find, and there is an incorrect one in the sticky!
Originally Posted by Dennis_Grant
Remember this list: Bilstein; Penske; Koni; Ohlins; Sachs; Dynamic Suspension.
Not on this list? Almost certainly crap.
SUV this!
illinipo is offline
Similar Threads
Need wiring help...European sedan tails. loudfocus01 MK1 Focus 21 07-18-2008 04:46 PM
Stock Gauge Replacement with Aftermarket Gauges!! (wiring gurus please!) honhon MK1 Interior Mods & Upgrades 114 04-10-2008 10:17 AM
Need Wiring Loom/ECU Advice! the_rainman ZETEC Performance (2000-2004) 0 06-07-2007 12:10 AM
autometer tach wiring Question Stolle MK1 Interior Mods & Upgrades 0 08-12-2006 01:27 AM
wiring guide needed help sskable Car Audio, SYNC, MyFord Touch & Electronics 1 01-08-2006 12:14 AM
