seat belt alarm. how do you turn it off??? - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 03-09-2009, 06:27 PM   #1
jetblk06st
Fan#: 62982
What I Drive: 2006 pitch black zx4 st
FF Reputation: 1 jetblk06st Good Standing Member
I drive an 06 focus st, and i know its safe to buckle up. but sometimes i dont feel like putting my seat belt on. i know that i could put it on and then take it off, which would disengage the alarm. but how do i turn it off for good?
jetblk06st is offline
Old 03-09-2009, 06:30 PM   #2
penguin
Fan#: 21700
What I Drive: 2005 Infrared ZXW
FF Reputation: 109 penguin Excellent Standing Member penguin Excellent Standing Member
I believe the procedure is in your owner's manual.
penguin is offline
Old 03-09-2009, 06:42 PM   #3
SVT_BMXer
SVT_BMXer's Avatar
Fan#: 11226
What I Drive: 1991 BMW 318is
FF Reputation: 20 SVT_BMXer Great Standing Member
Buy-Sell-Trade Rating: (17)
Easiest way is to wear but...I know some people don't. Seems odd they would put the procedure in the manual considering it's law in most states to wear it but I believe there is a how-to I'll go look for for you
02 Jackson Racing supercharged SVT
SOLD
Current:1991 BMW 318is: Bilstein sports, H&R springs, TMS chip, UUC short shifter, dyna-max muffler
SVT_BMXer is offline
Old 03-09-2009, 06:47 PM   #4
SquillyB
4.9L SC Stroker !!!
SquillyB's Avatar
Fan#: 45801
What I Drive: SC 5.0 FOFO BUILD IN PROGRESS
FF Reputation: 106 SquillyB Excellent Standing Member SquillyB Excellent Standing Member
not sure if you can turn it off without mechanically disconnecting the speaker itself. if there is a section in the manual it should be removed. why put the equipment in the seat to detect a driver or passenger and then not use it??
MECP 1ST CLASS
FF08 FASTEST OVERALL TRACK TIME
SquillyB is offline
Old 03-09-2009, 06:48 PM   #5
SVT_BMXer
SVT_BMXer's Avatar
Fan#: 11226
Ok so I lied maybe..lol. All I could find was the door chime eliminator. I'm sure someone has done it.
Exactly what I was getting it. I haven't looked but I doubt it's in the manual.
SOLD
Old 03-09-2009, 06:57 PM   #6
MichaelJD1980
Fan#: 55223
What I Drive: 2013 Tux SE Black Pack 5MT
Points 1,149, Level 18
Points: 1,149, Level: 18 Points: 1,149, Level: 18 Points: 1,149, Level: 18
Level Up 49% Completed
FF Reputation: 9 MichaelJD1980 Good Standing Member
I'm assuming you are talking about the "belt-minder" that goes off every 15 seconds or so (as opposed to the initial chime that goes off if you don't put your seatbelt on before starting the car - I don't think that can be disabled). The way to disable "belt-minder" used to be in the manual (don't know if it still is or not). The reason it should be in the manual is because it's not the law to have a seat belt chime. It's the law to provide seat belts and other safety equipment.
There is still something called personal responsibility in the world. If you want to choose not to wear your seatbelt, you can, and you run the risk of being fined.
Plus, there is always the chance that someone lives on a long private road and doesn't want to wear a seatbelt...
Edit: Try HERE - post #4
MichaelJD1980 is offline
Old 03-09-2009, 08:46 PM   #7
gonzorelic
gonzorelic's Avatar
Fan#: 13348
What I Drive: 2003 Pitch Black SVT Focus ZX5
FF Reputation: 31 gonzorelic Great Standing Member
The Belt Minder is the electronic warning system to remind you to use your safety belt system. It's a combination of a sounding chime and the illuminating warning light on your instrument panel. By default, the Belt Minder is active. When active, if the driver's safety belt is not buckled in about 5 seconds from the time the warning light has turned off, the warning light will again illuminate and the alarm chime will sound for 6 seconds, repeating itself every 30 seconds for the next 5 minutes, or until you buckle your seat belt.
You can De-Activate the Belt Minder two ways. First, you can deactivate it temporarily for your current "run cycle", that is after you have started your car and it's still running. Second, you completely deactivate the Belt Minder so that it never reminds you again, or at least until your reactivate it...
The first method, temporary deactivation, or one time disable: After you have started your vehicle, buckle and then un-buckle your safety belt. Be sure to buckle back up.... This will disable the Belt Minder only for that ignition cycle.
The second method, permanent deactivation: Before starting, make sure that:
The partking brake is set.
The car is in Park(automatic), Neutral(manual).
The ignition is OFF.
All doors are closed.
The driver's safety belt is un-buckled.
The parking and headlights are OFF.
1) Turn the ignition switch to ON, but DO NOT START.
2) Wait for the safety belt warning light to go OFF(1-2 minutes).
Steps 3-5 MUST be completed within 60 seconds!
3) Buckle, then un-buckle the driver's safety belt 3 times, ending with the belt un-buckled.
4) Turn on the headlights, turn off the headlights.
5) Buckle, then un-buckle the driver's safety belt 3 times, ending with the belt un-buckled.
After step 5, the Safety Belt Warning Light will be turned on for 3 seconds.
6) Within 7 seconds of the safety belt warning light turning OFF, buckle then un-buckle the safety belt. This will disable the Belt Minder if it is currently enabled, or enable the Belt Minder if it is currently disabled.
Confirmation of the disabling of the Belt Minder is provided by flashing the safety belt warning light 4 times per seconds for 3 seconds. Confirmation of the enabling of the Belt Minder is provided by flashing the safety belt warning light 4 times per seconds for 3 seconds, followed by 3 seconds with the safety belt light off, then followed by flashing the safety belt light 4 times per second for 3 seconds again. After confirmation, the deactivation/activation of the Belt Minder procedure is complete.
Jealousy is contagious,
Get well soon bitch!
WWW.PATTERNTEK.COM
WWW.SNAPOFFRACING.COM
gonzorelic is offline
Old 03-09-2009, 09:02 PM   #8
DrkKnight614
GO Green
DrkKnight614's Avatar
Fan#: 14522
Points 26,111, Level 96
Points: 26,111, Level: 96 Points: 26,111, Level: 96 Points: 26,111, Level: 96
Level Up 77% Completed
FF Reputation: 47 DrkKnight614 Great Standing Member
Very nice....now you wont be in a state of annoyance prior to dying in an accident LOL.
My 2003 Ford Focus ZX3 - Finally realized it's a 4cyl
DrkKnight614 is offline
Old 09-17-2009, 08:57 AM   #9
4ST AIR
Fan#: 64583
What I Drive: 2004 Ford Focus ZTS
FF Reputation: 3 4ST AIR Good Standing Member
Actually this mod helped me A LOT! I was looking for a way. And for all of those that might use it to disable the chime to drive without it, I personally didn't like it for another reason:
When working on the car/tuning, Dyno runs, etc, sorry fellas, but I don't wear a seatbelt while parked. THAT's when its annoying. This helps me, but I might be a select case..
4ST AIR is offline
Old 09-17-2009, 12:13 PM   #10
arlenn
Fan#: 67609
What I Drive: 2002 Silver ZX5
Points 3,454, Level 36
Points: 3,454, Level: 36 Points: 3,454, Level: 36 Points: 3,454, Level: 36
Level Up 70% Completed
FF Reputation: 16 arlenn Great Standing Member
+1, haha.
arlenn is offline
Similar Threads
HOW TO: Fix / Weld broken ZX3 Driver's seats niko MK1 Interior Mods & Upgrades 7 07-31-2013 08:47 PM
Seat belt pre-tensioners rotor-man General Technical Chat 17 12-24-2009 12:41 AM
"How To"....repair a seat belt that's slow to retract. bluefront General Technical Chat 5 03-09-2009 06:52 PM
Help With 2004 Mustang Seat Belt Alarm bluebird Ford Focus & General Car Chat 0 11-13-2008 10:47 PM
Seat Belt Warning signal not working focusonit General Technical Chat 9 09-24-2005 09:46 PM
