Water in Passenger footwell - Focus Fanatics
Old 03-09-2009, 04:15 PM   #1
ChrisH2005
Fan#: 63391
What I Drive: 2006 Silver Focus 1.8TDCi
FF Reputation: 1 ChrisH2005 Good Standing Member
Water in Passenger footwell (Now Fixed!!)
Hopefully someone can help me out here. I bought a 2006(56) Focus 1.8TDCi in January. Noticed a water leak in the passenger footwell a few weeks later, that was soaking the carpet, just in front of the passenger seat, but.... not up into the footwell. After the carpet dried, the felt underneath is continually soaked. I have returned to dealer. They have now had the car for a fortnight, and have confirmed there is a leak, but have failed to find the origin. They have removed and resealed the windscreen, but that appears to be all they have done. I know there was a problem on the MK1s for this, but anyone any ideas on the MK2. I am close to asking for the car to be replaced as I feel this leak is never going to be found, and would appreciate some advice..
Thanks in advance
Chris
ChrisH2005 is offline
Old 03-09-2009, 04:29 PM   #2
djmontara
djmontara's Avatar
Fan#: 59303
What I Drive: 2003 Ink Blue Focus 1.8 Zetec Ghia
FF Reputation: 3 djmontara Good Standing Member
check pollen filter cover? mk1s had this problem.. it wasnt sealing properly and so they made a modified metal cover.. donno how this is on the mk2 though...
djmontara is offline
Old 03-09-2009, 04:34 PM   #3
mikebontoft
Toxx
mikebontoft's Avatar
Fan#: 58647
it may also be a warped panel by/on the AC....condenser I believe. basically though if I remember correctly, it's a warped panel somewhere down there. (on the US version, though I wouldn't be surprised if it were the same)
hope that helps
and to FF
SR #127 | '02 Focus SE "Foci" (5.0 RWD - parting) | '90 Mazda 626 GT "Greenie" (2.2L turbo T3/T4 rebuild-sold) | '75 BMW 2002 "Carby" (resto-mod racecar) | '75 BMW 2002 (donor -sold) | '98 Jeep Grand Cherokee 5.9L (lifted and fast) | '99 BMW 328is (alt. daily).
Moderating General Chat Lounge, General Technical Chat, Ford Focus & General Car Chat, and Rocky Mountain Fanatics
mikebontoft is online now
Old 03-10-2009, 12:20 AM   #4
iminhell
C2H5OH
iminhell's Avatar
Fan#: 36222
FF Reputation: 48 iminhell Great Standing Member
Buy-Sell-Trade Rating: (4)
Could also be the grommet for the heater lines. For the US spec cars that is on your drivers side close to the tunnel, assuming it would be on the passenger side for you. Might also be what Mike is talking about, dunno.
Don't "think outside the box".
There is no box.
Do it correct, or do it twice.
iminhell is offline
Old 03-10-2009, 05:24 AM   #5
bluefront
bluefront's Avatar
Fan#: 56816
What I Drive: 2006 white ZX5 SES
FF Reputation: 146 bluefront Excellent Standing Memberbluefront Excellent Standing Member
Buy-Sell-Trade Rating: (6)
Have you been running the AC much? Leaks around the evaporator housing can get on the carpet.....or a clogged drain hose can do the same thing.
But more likely....exterior water is leaking in. This can always be found.....but you may need to remove the carpet. Lay down a bunch of paper, and hose down the car, checking the paper for wet spots frequently. The leak will probably be related to the cowl area, but there are also some wire bundles that enter the car under the front fenders. Water can get past a faulty seal and enter the car.
It's fixable.....but tricky to find.
I'll keep my guns, my freedom, and my money.....you can keep the "change".
bluefront is offline
Old 03-10-2009, 08:21 AM   #6
niko
Fan#: 8267
What I Drive: 2000 ZX3 ATX, 191,000 miles so far
FF Reputation: 1 niko Good Standing Member
/\/\/\/\/\ I agree, if water was in front of the passenger seat, but not in the footwell, then the door must be leaking somehow. MAYBE the windshield at its highest point has a leak, but if they replaced that and you still have water, it's gotta be the door..
When I got my focus I had a water leak in the BACK, I would get water just behind the passenger seat, a nice puddle of it. It took two tries for them to fix it, it was something to do with the weatherstrip around the passenger door.
When I would look at it, I would think, how the heck could water get there, from here....but it just did..because even if the door was leaking it didn't look like it could get to where the water was, but hey water is a tricky thing lol.
-niko
niko is offline
Old 03-10-2009, 04:45 PM   #7
ChrisH2005
Fan#: 63391
Thanks guys. I will get them to check the door, I think they are concentrating on the front of the car. If its a warped panel, is it still repairable?? When they find the fault, I will let you know the outcome.
I am sure its external water, as it does not smell of anything, certainly not antifreeze anyhow. just smells like standing water.
Old 03-20-2009, 03:06 PM   #8
ChrisH2005
Fan#: 63391
Water LEak Fixed 2006 Focus
Hi thought I would post the fix for this...
After 3 weeks, the ford dealer finally decided to remove the dash, and found the leak in 5 mins. Seems that at manufacter, the Yellow thick sealant between the A post/Front Bulkhead/Passenger inner wing/ was not properly sealed, and there was a 2mm gap of sealant missing. This was resealed, and all well again, they have just bloody broken the drivers side heated front screen now....... at least they will fix, just bloody typical.
Similar Threads
Zetec Water Pump Removal (How to) grimple1 General Technical Chat 25 07-03-2013 08:04 AM
water on passenger rear floor topgearcutie General Technical Chat 29 05-30-2008 01:14 PM
Water in passenger compartment/ a/c drain Superdave General Technical Chat 0 02-21-2008 07:51 AM
For Sale: Passenger ZX3/SVT Door parts Slinky Archive 2 07-21-2006 10:31 PM
New Volkswagen Rabbit!! nomoreavril Ford Focus & General Car Chat 30 06-29-2006 11:55 AM
