no fire on old computer, no crank on "new" computer - Ford Focus Forum, Ford Focus ST Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum > Ford Focus First Generation > SPI Performance (2000-2004)
Old 03-08-2009, 02:51 PM   #1
Justin svt
Justin svt's Avatar
Fan#: 58325
What I Drive: 2002 CD Silver SVT
Points 2,568, Level 30
Points: 2,568, Level: 30 Points: 2,568, Level: 30 Points: 2,568, Level: 30
Level Up 79% Completed
FF Reputation: 2 Justin svt Good Standing Member
hey ive been having problems with my car not starting and the garage said it needed a computer so i picked one up from the junk yard. with the old computer it cranks fine but has no fire at all (new coil, wires, plugs) i took off the negitive battery cable removed the old computer put the "new" one in and put the cable back on. the guy told me to turn the key to the run position 3 or 4 times then try to start it. tried and nothing at all. i did notice the gauges swept and the fake security lights was flashing fast. what else is fire realated? he said theirs like an ecm right under the coil that goes bad is this possible or is he trying to sell me more crap. and is it possible that i need the key for the new computer?
2002 silver ZX3 SVT #2318: Tom's Tune, 8.2mm Taylor Thundervolt wires, Custom ORP, Full Prothane bushing swap
"I buy things I don't need, with money I don't have, to impress people I don't know"
Justin svt is offline
Old 03-08-2009, 02:57 PM   #2
norcalfocus01
Fan#: 55603
Buy-Sell-Trade Rating: (12)
when you had the old computer did you check the fuel pump? that would have been a more likely place to start if you cranked but had no fire.
norcalfocus01 is offline
Old 03-08-2009, 03:01 PM   #3
Justin svt
Justin svt's Avatar
Fan#: 58325
it had no fire at the spark plugs i dident check preasure with a gauge but there was fuel there and it seemed alright to me. Thanks for your quick reply
Old 03-08-2009, 03:06 PM   #4
bluefront
bluefront's Avatar
Fan#: 56816
What I Drive: 2006 white ZX5 SES
FF Reputation: 146 bluefront Excellent Standing Member bluefront Excellent Standing Member
Buy-Sell-Trade Rating: (6)
I'm not sure about your 2000 model......but many new cars require you to reprogram the computer when it is changed, reprogram it so the security system doesn't think the car is being stolen.
I'll keep my guns, my freedom, and my money.....you can keep the "change".
bluefront is offline
Old 03-08-2009, 04:06 PM   #5
Justin svt
Justin svt's Avatar
Fan#: 58325
yeah that sounds about right but im not even sure my car has an alarm sustem...unless its factory becuse i dont even have power locks. but i donno
Old 03-08-2009, 07:50 PM   #6
devil_dog_switch
devil_dog_switch's Avatar
Fan#: 55359
What I Drive: 2003 Black Dodge Durango
FF Reputation: 3 devil_dog_switch Good Standing Member
i say get the part from a auto store replace it.. if it works your good, if not, put the old one back in and take the new one back to the store, tell them it didn't fit or it wasn't the problem and you already solved it or something.. i used that trick alot.
Former Home of the Blue Light Special
Ask me about Lighting
2003 Dodge Durango Sport
2002 Ford Focus SPI *SOLD* you will be missed
devil_dog_switch is offline
Old 03-08-2009, 10:07 PM   #7
joshs_2000focus
Fan#: 60441
What I Drive: 2000 blue se
FF Reputation: 1 joshs_2000focus Good Standing Member
when you put that new computer in your car did you get the black ring that gose with it? (its the one behind the plastic around your key) if you did not your car will not get fuel or fire when you change the computer i would recommend that you chang the key tumblers key for the car you got it from and that ring. if you did not do all that you got to take it to ford to get it reprogramed
joshs2000focus_se/
joshs_2000focus is offline
Old 03-08-2009, 10:29 PM   #8
Feral
Feral's Avatar
Fan#: 58350
What I Drive: 1 2002 / 2 2001 Wagons
FF Reputation: 53 Feral Excellent Standing Member
Buy-Sell-Trade Rating: (23)
All focuses use a Security key that is coded directly to the computer
the computer you picked up out of the scrap yard will need the key that belonged to the car you took the computer out of... you cannot use another persons computer in your car unless you have the ignition cylinder and key to match it (that the key was programmed into)
the rapid flashing LED means mismatched Security Code and your cars in Antitheft mode which pretty much shuts down your car
That black ring behind the column cover is nothing but a receiver changing that won't do anything
Wagon Partout - http://www.focusfanatics.com/forum/showthread.php?t=212282
My Wagon Rebuild - http://www.focusfanatics.com/forum/showthread.php?t=217009
Feral is offline
Old 03-09-2009, 04:18 PM   #9
Justin svt
Justin svt's Avatar
Fan#: 58325
so i need the whole ignition cylinder and key? is it hard to change? could ford reprogram it without having the car..like take the code off of my old one? thanks
Old 03-10-2009, 03:50 AM   #10
Feral
Feral's Avatar
Fan#: 58350
well Ford can reprogram the scrap yard ECU no prob with your original existing keys
It will run ya about 150 bux
they will tap into the computer port (OBDII), tell the ecu to wipe the previous keys then run it through the programming cycle of your existing keys
you will need to have the car itself present, with ALL your keys and remotes to the car for that process.. and no the car doesn't have to be running for them to do it
Feral is offline
Similar Threads
My 04 SVT Euro caught FIRE!!! :( Venomus SVT Performance (2002-2004) 215 05-12-2007 05:21 PM
favorite car of all time bigjordan Ford Focus & General Car Chat 65 08-03-2006 05:42 PM
